Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 05-08-2003, 05:21 AM   #1
kidatari
Member#: 10441
Default What is the purpose of dual valve stems?
Just like the title says, what is the purpose of dual valve stems? Something like these Enkei wheels (link). I think I also saw a set of Volks like this. Anyone know?
Josh
kidatari is offline   Reply With Quote
Old 05-08-2003, 01:39 PM   #2
JonnySubaru
Member#: 17901
Exclamation Just a guess!
The second stem could possibly be for tire pressure monitors? I don't know if they typically mount on the inside or outside of the wheel?
JonnySubaru is offline   Reply With Quote
Old 05-08-2003, 03:29 PM   #3
kidatari
Member#: 10441
Default Re: Just a guess!
Hmmm. not sure on that one. Anyone else know? BUMP!
Old 05-08-2003, 04:20 PM   #4
dbrier
Member#: 6598
2017 Golf R
Limestone Grey
Weird...
I would have put them opposite of each other for balance instead of next to each other.
dbrier is offline   Reply With Quote
Old 05-08-2003, 05:34 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I know some racing wheels have a second stem for an inner liner.
Like an innertube which is pressured and then pressure between it and the actual tire.
Old 05-08-2003, 05:35 PM   #6
Center Line Wheels
Member#: 20504
The dual v-stem system is actually to insert nitrogen as well as air into the tire. It keeps the pressure at a more constant p.s.i. as I was informed. Track use of course.
Center Line Wheels is offline   Reply With Quote
Old 05-09-2003, 12:21 AM   #7
yosemitemtb
Member#: 23437
'02 WRX Wagon
Original owner blue pearl
I know Nascar uses an inner liner, like a tire within a tire, at larger tracks and these rims use two valve stems. As for one valve for air and one for nitrogen, why would you need two stems?
yosemitemtb is offline   Reply With Quote
Old 05-09-2003, 08:12 AM   #8
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
To be unique. Inner liner stem isn't at that location. If you use nitrogen you might as well use 100%. Moisture is your enemy.
WRX03 is offline   Reply With Quote
What is the purpose of steel brake lines? impreza2002 Brakes, Steering & Suspension 26 12-19-2002 12:43 PM
what is the purpose of gauge pack? gypsymoth Newbies & FAQs 6 08-07-2002 04:38 PM
What is the purpose of improving these parts? sherifx Brakes, Steering & Suspension 13 05-14-2002 01:40 AM
What is the purpose of an oil pressure gauge? redobs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-01-2002 01:59 AM
What is the purpose of an angled top mount intercooler? latinskllz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-10-2001 11:07 PM
