01-08-2007, 01:14 PM | #1 |
Member#: 91431
Vehicle:2003 WRX Black |
Cobb catted downpipe or invidia catted downpipe
Im trying to decide if I should go with a cobb catted downpipe or invidia catted downpipe. Im also going to get a uppipe, saw a cobb uppipe with or without EGT Bung what advise could you guys give me on downpipes and uppipes and what does EGT mean. Are these products good products. What suggestion could you guys give me about downpipes and uppipes.
01-08-2007, 03:48 PM | #2 |
Member#: 85990
Vehicle:2003 WRX 240hp/240tq WRB |
Personally I would recommend getting the COBB as they make a lot of good products for Subarus. There really isn't a need for the EGT bung unless you want to retain the factory sensor. However, if you are going to mod the car correctly, then you will need some kind of EM once you purchase a complete exhaust system. If you go with an Access Port then it will cancel out the CELs you get if you don't hook up the EGT sensor. For the time being there is a "CEL fix" that you can do to eliminate the CEL. Try doing some searching to see what I'm talking about.
Also, EGT means exhaust gas temperature. |
01-08-2007, 03:48 PM | #3 |
Member#: 78074
Vehicle:2005 STi Aspen White |
egt = exhaust temp
what catback do u plan on getting? the cobb is a taper to 2.5 with a dounut flange to work with ur stock catback or any catback that tapers. the invidia doesnt mate up to the stock so well. it leaks and its a 3" flat flange. i suggest the cobb dp cause it doesnt sound like u know much so i dont think youll be modding ur car with lots of power and ppl seem to think the cobb system holds back power when over a certain amount |
01-08-2007, 04:35 PM | #4 |
Member#: 2902
TXIC
01-08-2007, 06:05 PM | #5 |
Member#: 47426
Vehicle:2003 Impreza WRX Black |
If you want a true 3 inch exhaust go with the invidia. I would buy the cobb though nothing but good things are said about the downpipe, but it does bottleneck.
01-08-2007, 09:14 PM | #6 |
Member#: 107361
South East
Vehicle:Now, with 100% less trunk space! |
I seriously, seriously doubt that a 0.5" bottleneck, over a length of maybe 3", would cause any repeatable power restriction. Buy your exhaust based on A) the volume of the catback and B) whether or not you want to retain at least one cat for emissions reasons. And a 3" flat flange won't leak if you install it properly.
01-08-2007, 11:50 PM | #7 |
Member#: 82242
Vehicle:2005 wrx wagon wooh wooh!!!!! |
invidia make beautiful products! i had their dp and just ordered a g200 too. can't go wrong with either, but i'm a fan of invidia.
01-09-2007, 12:47 AM | #8 |
Member#: 119970
South East
Vehicle:2006 WRX Wagon Grocery Getter! |
its all personal preference...
01-09-2007, 01:50 AM | #9 |
Member#: 123159
VIC
Vehicle:Now with 75% more spite. |
The Cobb DP is just so bloody expensive. I would personally go with the invidia, the only reason I didnt is because I have a CObb catback that tapers to 2.5'' and it wouldnt mate up perfectly. I went with a PDE catless myself.
WTB= cobb,helix v2, or invidia V2 Downpipe | awdguy | Private 'Wanted' Classifieds | 1 | 12-21-2008 08:03 PM |
WTB: Cobb catted dp or Invidia catted dp! | jyi | Private 'Wanted' Classifieds | 0 | 12-07-2007 11:02 AM |
WTB COBB TBE with High Flow Cat/Helix or Invidia Catted | ix8vii | Private 'Wanted' Classifieds | 2 | 06-13-2006 07:39 PM |
WTB Cobb Catted Downpipe or other catted downpipe | smackedownz | Private 'Wanted' Classifieds | 2 | 05-05-2006 08:00 PM |
WTB: HELIX OR INVIDIA Catted DP and Helix UP, COBB AP2 | AOD_SNOWMAN | Private 'Wanted' Classifieds | 0 | 03-24-2006 02:38 AM |
