Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 04-06-2007, 01:04 AM   #1
chokin
Member#: 124739
02 wrx
black
Exclamation Radiator fans wont kick on
my car 02 wrx was overheated,but after i replaced the thermostat, the guy and i noticed that the fans werent on at all, havent driven the car till 3 days ago, the fans suddenly kick back on, but today. while i was letting the car run, it overheated, and i noticed again the fans werent on ....
any ideas guys? wiring or sensor? reply fuses?
chokin is offline   Reply With Quote
Old 04-06-2007, 01:00 PM   #2
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Kinda sounds like the coolant temp sensor.
Ryan
MYfirst00 is offline   Reply With Quote
Old 04-06-2007, 03:50 PM   #3
chokin
Member#: 124739
02 wrx
black
it kicked on today at normal temp. serious WTH ?? i think it just kick on sometimes
Old 04-06-2007, 03:56 PM   #4
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
When the coolant temp sensors get old, they start to get coated and not sense the temp correctly all the time. It may work fine sometimes and not at others. That'd be the first place to start. If I recall, they're not too expensive.
Ryan
Old 04-07-2007, 11:45 AM   #5
chokin
Member#: 124739
02 wrx
black
is it hard to replace?
Old 04-07-2007, 04:06 PM   #6
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Not really. It might be tricky to get to, but it's usually on the intake manifold I believe. Not sure where it is on the WRX.`
Old 04-07-2007, 04:47 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I doubt it's a bad CTS. There is no separate sensor for the fans, the ECU uses a single coolant temp sensor to set fueling, run the fans, and for other temp-related functions. If the sensor was that far out of range you'd notice the car running poorly, bad mileage and probably a CEL.
You may have air pockets in the cooling system, try burping the system (even if you have already done so after replacing the t-stat).
Old 04-07-2007, 08:49 PM   #8
mikeythejew
Member#: 141672
You also have a cooling fan relay that can go bad. I replaced a few as a mechanic at a honda dealership.
mikeythejew is offline   Reply With Quote
Old 04-08-2007, 01:58 AM   #9
chokin
Member#: 124739
02 wrx
black
fans relay? so i just have to replace those relay fuses?
Fans wont kick on?? gotawd Electrical & Lighting 1 06-10-2009 12:47 PM
HVAC Fan wont turn on after gauge install HighAspirations Electrical & Lighting 14 07-28-2008 06:52 PM
fans dont kick on DUFFMANAUDIO Service & Maintenance 2 06-05-2007 02:51 PM
fan wont turn on? kemosabe Alaskan Impreza Club Forum -- AKIC 10 04-20-2007 02:53 AM
Radiator Fans wont turn on SlowPoke00 Electrical & Lighting 4 01-25-2005 09:45 AM
