Welcome to the North American Subaru Impreza Owners Club Saturday November 17, 2018
Alaskan Impreza Club
Old 04-19-2007, 11:22 PM   #1
kemosabe
Member#: 143641
1999 mitsubishi gsx
black
Default fan wont turn on?
like the title says...one of my fans isn't turning on...and i dont know why...i'm hoping one of you guys will be able to give me some sort of trouble shoot or answer ...
kemosabe is offline   Reply With Quote
Old 04-19-2007, 11:26 PM   #2
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
fuse? loose/disconnected wire?
internal fan (I.e. HVAC) or external radiator fan?
Also a bum temp switch perhaps.
AKSubie is offline   Reply With Quote
Old 04-19-2007, 11:29 PM   #3
kemosabe
Member#: 143641
1999 mitsubishi gsx
black
check the connections already...i was goin to check fuses but...i figured i'd post anyway...and its external radiator fan...burn temp switch?...unfortunatelly i'm not as mechanically inclined as i'd like to be...which is why i posted this up haha
Old 04-19-2007, 11:32 PM   #4
AKSubie
Member#: 6214
01.5 Audi S4
bum not burn.
ya, not sure on the DSM's, but a bad temperature switch/sensor COULD make it not turn on. I knwo a few Audi heads were installing lower temp sensors to kick the fan on sooner.
Coolant temp sensor... I mean. imagine a "bad" one might not allow it to turn on, or read period.
Old 04-19-2007, 11:35 PM   #5
kemosabe
Member#: 143641
1999 mitsubishi gsx
black
well...that makes me think...if that was the case...then wouldn't neither fan turn on?...one is turning on...the other isn't....
p.s.(sorry i haven't changed the settings on my comp yet...reading txt isn't as easy as it should be...)
Old 04-19-2007, 11:41 PM   #6
AKSubie
Member#: 6214
01.5 Audi S4
oh... ok.... so wait, You have 2 fans on the radiator correct? and one turns on occasionally? in seemingly common intervals? is that one still tuning on and off at those intervals? And you are not overheating right?
Old 04-19-2007, 11:43 PM   #7
kemosabe
Member#: 143641
1999 mitsubishi gsx
black
yes...one of them turns on regularly as it should...the other one...doesn't do ****
Old 04-19-2007, 11:46 PM   #8
AKSubie
Member#: 6214
01.5 Audi S4
ok.. well sounds like its working fine to me. The other IIRC is for additional load on the car, like AC, defrost, yada yada. I think its fine, flip on hte AC and see if it kicks on.
Old 04-20-2007, 12:02 AM   #9
kemosabe
Member#: 143641
1999 mitsubishi gsx
black
hmm...well i guess your right...well my car didn't sound happy on the way home...i was trying to figure out why...i wont found out till i drive her if i fixed the boost leak or not...i'm hoping that that is the only reason why she sounded unhappy...thanks
learn sumn new everyday
Old 04-20-2007, 12:17 AM   #10
Nix_Evo
Member#: 131304
2008 Rabbit
Black on Anthracite
lol i saw the title... first thought *turn on the switch*
Nix_Evo is offline   Reply With Quote
Old 04-20-2007, 02:53 AM   #11
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
i used to have a 90 eclipse turbo, same story. only one fan runs 90% of the time. every once in a while when i'd drive the crap out of it and stop right away one would kick on, then a minute later the other would also, which was much louder. when both turn on it sounds crazy.
ibnormal
00Maddog is offline   Reply With Quote
Air conditioner turns on when fan is turned on dpk General Community 1 07-28-2009 10:58 PM
HVAC Fan wont turn on after gauge install HighAspirations Electrical & Lighting 14 07-28-2008 06:52 PM
After Changing fuses, radiator fans still wont turn on... SlowPoke00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-27-2005 08:36 PM
Radiator Fans wont turn on SlowPoke00 Electrical & Lighting 4 01-25-2005 09:45 AM
Gauge cluster on 94 GC8 wont turn on? Impreza94L Service & Maintenance 1 09-11-2002 10:36 AM
