Welcome to the North American Subaru Impreza Owners Club Sunday June 24, 2018
Old 07-25-2008, 07:34 PM   #1
HighAspirations
Member#: 167626
Default HVAC Fan wont turn on after gauge install
I recently installed a Defi gauge package on my 07 STI and initially installed the link box with the ignition wire connected to the A/C green/red tracer. After this, the fan didnt work - I thought I cut the wires with the solderless connector, I took it out today and I hadnt cut the wire, also, I swapped the ign wire over to the green/orange tracer. Any idea what I should check?
HighAspirations is offline   Reply With Quote
Old 07-25-2008, 07:38 PM   #2
PureTorque
Member#: 157281
07 VF39'd WRX TR
WR Blue
fuses?
PureTorque is offline   Reply With Quote
Old 07-25-2008, 07:43 PM   #3
HighAspirations
Member#: 167626
Originally Posted by PureTorque View Post
fuses?
I checked almost all the fuses in the fuse box under the hood infront of the driver, nothing blown.
Old 07-25-2008, 08:14 PM   #4
PureTorque
Member#: 157281
07 VF39'd WRX TR
WR Blue
hmmm 99% of the time its a fuse i prolly shorted something out. re look at it otherwise wait for more responses
Old 07-25-2008, 08:17 PM   #5
HighAspirations
Member#: 167626
Are there any other fuses then the ones under the hood near the battery?
Old 07-25-2008, 08:21 PM   #6
PureTorque
Member#: 157281
07 VF39'd WRX TR
WR Blue
i think for the hvac its under the dash, ifi remember its one to the top row, just chk the diagram on the back of the tray and itll tell u which is for which. maybe you didnt see that the fuse was popped and put it back in, i did that once but then then re checked it
Old 07-25-2008, 09:12 PM   #7
HighAspirations
Member#: 167626
Checked fan blower 1 and 2 fuse and both look ok. Any other possibilities?
Old 07-25-2008, 09:30 PM   #8
HighAspirations
Member#: 167626
Are there any wiring diagrams available? Id like to whip out the MM and start checking things.
Old 07-25-2008, 10:37 PM   #9
PureTorque
Member#: 157281
07 VF39'd WRX TR
WR Blue
not sure of anything else expect it might not be plugged in...
Old 07-26-2008, 09:56 AM   #10
HighAspirations
Member#: 167626
Ive checked the 2 plugs on the back of the HVAC controls, they are both in. Any idea where the fan blower is located?
Old 07-26-2008, 10:36 AM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Try fuse left side near drivers door. Fan located on passanger side behind glove box.
Old 07-26-2008, 12:34 PM   #12
HighAspirations
Member#: 167626
Yeah I checked the 2 fan blower fuses near the drivers door. in a few minutes Im going to check all fuses. Is there a resistor that I might have cooked that does fan control? or a relay?
Old 07-26-2008, 05:11 PM   #13
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I think the fans are controlled by the ECU via a coolant temp sensor tied to the ECU also.
Old 07-26-2008, 06:01 PM   #14
HighAspirations
Member#: 167626
Are you talking about the HVAC fan, or the engine fan?
Old 07-28-2008, 05:52 PM   #15
SpankySuby
Member#: 122305
2002 wrx half breed
Hey man i dont know if the 07 is close to my 02 but when you said the green red wire it kinda does but any way for my car the blower motor is controlled through the ground by a risistor pack that is behind the glove box in the air ducts (for cooling purposes). what i would do is pull the glove box out and get to the blower motor there should only be two wires (ground and power) now on my car that motor should always get power when the blower speeds are selected if it doesnt have any power then its either a fuse or the blower motor relay. if it does have power then check the ground.
SpankySuby is offline   Reply With Quote
Car wont turn over after Gauges BugeyedWREX Electrical & Lighting 3 01-03-2010 12:02 AM
fan wont turn on? kemosabe Alaskan Impreza Club Forum -- AKIC 10 04-20-2007 01:53 AM
fuel pump wont turn on after motor install. oldbluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-15-2005 11:01 AM
Radiator Fans wont turn on SlowPoke00 Electrical & Lighting 4 01-25-2005 08:45 AM
Help! Fog lights won't turn on after HID install aspenwhitewrx Electrical & Lighting 17 03-30-2004 01:48 AM
