Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 01-21-2006, 10:43 PM   #1
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Default Radiator fans not turning on
Well today was the day to fire up the car. Just finished a jdm v7 engine/drivetrain swap. Hooked up the Hydra and the motor fired right up. With the help of a friend we got the idle pretty steady but noticed the radiator fans weren't kicking on. After having the car sit and idle for awhile the temps were coming up and the fans still woundn't kick on. I have stock fans with a PWR radiator and crucial t-stat. When unplugging the radiator fans before the swap, i couldnt get the connector off on the drive side and the leads all came out of the connector. I put them back in what I thought was the right order but i think this might be the problem. Does anyone have a diagram showing which color leads go in which slots or if anyone has a picture of theirs on the driver side. Thanks!
dan avoN7 is offline   Reply With Quote
Old 01-21-2006, 11:25 PM   #2
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Copy the other fan......
sixpack subaru is offline   Reply With Quote
Old 01-21-2006, 11:32 PM   #3
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
thats what i did the first time, so either its not plugged in all the way or the hydra needs something changed so they will come on.
Old 01-21-2006, 11:37 PM   #4
sixpack subaru
Member#: 64974
Ok, I am assuming that a hydra is some kind of a/market ECU? does it have the same failsafe that the OEM ECU has, that is, when you disconnect the coolant temp sensor the fans will run constantly? If so, try that....
What coolant temp are you getting to before you shut it down?
Do the fans work when you turn the aircon on?
Sixpack
Old 01-21-2006, 11:50 PM   #5
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Sixpack
hydra is a standalone ems. i havent disconnected the temp sensor to see if they will click on. I dont have AC in the car but when i hit the AC button I hear a clicking noise near the fans but they dont come on. The highest temp i've seen was 105 C* but that was after idling for awhile.
Old 01-23-2006, 05:45 AM   #6
sixpack subaru
Member#: 64974
They should switch on before that!! If you disconnect one, (the one that had the pins pulled out), does the other one work? it should.
ALso, does the hydra control the fans, coz the std ECU does.
Have you set the Hydra up to switch thermo's on? and if so at what temp?
Is the coolant temp sensor working OK?
Sorry for all the questions, but sometimes they lead to answers
Cheers
Sixpack
Old 01-23-2006, 01:29 PM   #7
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Cheers
Sixpack
yes i know they should switch on before that, thats why i made this post The fan on the passenger side does not even come on. That connector is perfectly fine also, so this almost leads me to believe its something to do with the EMS. I will have to look into that tmrw when I have time to work on the car. Temp sensor is working fine from what I can tell, never had issues with it ever. I will report back once i fool around with the hydra some more.
Radiator fans not turning on aurelius Newbies & FAQs 6 02-25-2010 06:45 AM
Car overheating & radiator fans not turning on SlowPoke00 Service & Maintenance 10 02-08-2005 03:19 AM
Radiator Fans wont turn on SlowPoke00 Electrical & Lighting 4 01-25-2005 09:45 AM
Radiator fan not coming on. So it seems. ebeck Electrical & Lighting 15 12-21-2004 12:40 PM
Radiator fans not coming on with link plus Midwayman Engine Management & Tuning 6 09-15-2002 02:28 AM
