Welcome to the North American Subaru Impreza Owners Club Friday September 24, 2021
Old 07-16-2021, 09:50 PM   #351
Fino
Member#: 417685
'03 V7 EJ207, 6MT
Sonic Yellow
Thanks for the guide. Since my 207 doesn't have TGV's I wired the +12V and signal both off the rear O2 sensor. Tuned it using the Carberry ROM and have been running flex fuel for the past year with no problems.
Fino is offline   Reply With Quote
Old 07-29-2021, 12:29 PM   #352
BartNJ
Member#: 448544
I'm just curious what is your failure rate with "Flex Fuel Sensor GM Part Number 13577429".
First one died after 3 years. The replacement didn't last too long (about 5 months). It actually died during track day. Driving home 100miles was fun! It looks like this should be a spare part I should always have with me.
BartNJ is offline   Reply With Quote
Old 07-29-2021, 02:34 PM   #353
Rexy18
Visiting NASIOC Timeout
Member#: 500337
Make sure you buy original conti sensor from gm. Not china made copies.
Mine is lasting still, 39k miles and counting. I made it in 2019 so 2.5yrs so far.
Not one issue. I got two for sale by the way, if anyone interested. Old production, cleaning my diy bench so I found them. PM if interested. Does NOT include flex sensor which can be had for 50-60$ on rockauto or amazon. But it does include fuel lines for fa20dit.
Rexy18 is offline   Reply With Quote
Old 07-29-2021, 08:03 PM   #354
BartNJ
Member#: 448544
During this particular track day two aftermarket sensors died: Ethanol and OIL Pressure by AEM. Temps were way up there in 265F for oil. It was hot!!! That lead me to believe, operating temps played the role. I may try to move E sensor away from engine bay...
I bought E sensors from amazon by amazon, so I assume it's legit.....
Old 08-03-2021, 09:54 AM   #355
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Also take vibration into consideration.
Old 08-04-2021, 11:20 AM   #356
BartNJ
Member#: 448544
That's a good point. I'll try to mount it better way, as it's pretty much not attached to anything other that fuel lines itself.
Old 09-16-2021, 10:11 PM   #357
Bara83
Member#: 397052
Would someone help me with the arduino side please? My Arduino IDE will not get through the compiling. Throws following:
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "Arduino NANO 33 IoT"
E85:53:5: error: expected constructor, destructor, or type conversion before '(' token
ISR(TIMER1_CAPT_vect) // PULSE DETECTED! (interrupt automatically triggered, not called by main program)
E85:59:5: error: expected constructor, destructor, or type conversion before '(' token
ISR(TIMER1_OVF_vect) // counter overflow/timeout
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino: In function 'void setupTimer()':
E85:46:3: error: 'TCCR1A' was not declared in this scope
TCCR1A = 0; // normal mode
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:46:3: note: suggested alternative: 'TCC1'
TCC1
E85:47:3: error: 'TCCR1B' was not declared in this scope
TCCR1B = 132; // (10000100) Falling edge trigger, Timer = CPU Clock/256, noise cancellation on
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:47:3: note: suggested alternative: 'TCC1'
TCC1
E85:48:3: error: 'TCCR1C' was not declared in this scope
TCCR1C = 0; // normal mode
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:48:3: note: suggested alternative: 'TCC1'
TCC1
E85:49:3: error: 'TIMSK1' was not declared in this scope
TIMSK1 = 33; // (00100001) Input capture and overflow interupts enabled
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:49:3: note: suggested alternative: 'MISO1'
MISO1
E85:50:3: error: 'TCNT1' was not declared in this scope
TCNT1 = 0; // start from 0
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:50:3: note: suggested alternative: 'TCC1'
TCC1
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino: At global scope:
E85:53:4: error: expected constructor, destructor, or type conversion before '(' token
E85:59:4: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino: In function 'void setPwmFrequency(int, int)':
E85:152:7: error: 'TCCR0B' was not declared in this scope
TCCR0B = TCCR0B & 0b11111000 | mode;
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:152:7: note: suggested alternative: 'TCC0'
TCC0
E85:154:7: error: 'TCCR1B' was not declared in this scope
TCCR1B = TCCR1B & 0b11111000 | mode;
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:154:7: note: suggested alternative: 'TCC1'
TCC1
E85:167:5: error: 'TCCR2B' was not declared in this scope
TCCR2B = TCCR2B & 0b11111000 | mode;
C:\Users\rbara\OneDrive\818C\Ethanol sensor\E85\E85.ino:167:5: note: suggested alternative: 'TCC2'
TCC2
Multiple libraries were found for "LiquidCrystal.h"
Used: C:\Users\rbara\Documents\Arduino\libraries\LiquidC rystal
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x 86__mdqgnx93n4wtt\libraries\LiquidCrystal
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Bara83 is offline   Reply With Quote
Old 09-17-2021, 05:00 PM   #358
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
Possible copy and paste fail?
fbi is offline   Reply With Quote
Old 09-17-2021, 08:53 PM   #359
Bara83
Member#: 397052
Hi fbi, this is the fail. The whole thing I posted basically.
Old 09-17-2021, 08:57 PM   #360
Bara83
Member#: 397052
TCC1
TCC1
TCC1
MISO1
TCC1
TCC0
TCC1
TCC2
exit status 1
Old 09-17-2021, 08:58 PM   #361
Bara83
Member#: 397052
TCC1
TCC1
TCC1
MISO1
TCC1
TCC0
TCC1
TCC2
exit status 1
Old 09-17-2021, 09:06 PM   #362
benflynn
Member#: 515308
I think the interrupt version of the code to be easiest to get wrong. Why do u need the interrupt?
benflynn is offline   Reply With Quote
Old 09-17-2021, 09:08 PM   #363
Bara83
Member#: 397052
I copied this code from the first page from here, wanted to write it to the arduino, so I can make the flex fuel converter. I dont do programming, Im a technician. Nobody seems to complain about the code not working, so I dont understand what im doing wrong. Could you guys help me please?
Old 09-17-2021, 09:37 PM   #364
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
I see the end error, as (
Possibly meaning there's a missing bracket. I was wondering if you missed or added something with a bad copy and paste.
Old 09-17-2021, 10:11 PM   #365
benflynn
Member#: 515308
There is a much simpler code halfway through this thread. Pm me your email and I will send you one of the versions I use.
Did you load the library definitions?
Old 09-18-2021, 09:30 AM   #366
Bara83
Member#: 397052
I messaged You. What library am I loading?
Old 09-18-2021, 10:07 AM   #367
Bara83
Member#: 397052
Arduino nano iot 33 is not compatible, because its not an AVR board anymore. FIgured it out! Went and bought a regular nano. Also hooked up the 12+ and gnd backwards on the ethanol sensor. After reversing and re soldering the board, it started reading. Sadly im getting 99% in the serial monitor ( arduino is powered through TGV 5V ). I guess I could have killed the sensor. Great success!
