Welcome to the North American Subaru Impreza Owners Club Saturday November 17, 2018
Old 05-15-2018, 02:32 AM   #1
dokalanyi
Member#: 471478
Default No Tap. Can I drill and force nozzle in?
Hello,
I have an STI intercooler. Would like to install meth, don't have 1/8" tap. Can I drill the right size hole, and just force in the nozzle? Will it create its own threads?
dokalanyi is offline   Reply With Quote
Old 05-15-2018, 03:30 AM   #2
combatspace
Member#: 485855
It's gonna be a lot easier just to take it to someone who can tap it properly for you than to try and force it. See if there's a machine shop around you that can do it. Toss em a few bucks. Besides, you'll get all those metal bits down inside the IC which is no bueno...
combatspace is offline   Reply With Quote
Old 05-15-2018, 10:51 AM   #3
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
buy a tap set. they are like $40
Titter is offline   Reply With Quote
Old 05-15-2018, 05:35 PM   #4
stevieturbo
Member#: 20366
A single tap would be a fraction of that.
stevieturbo is offline   Reply With Quote
Old 05-16-2018, 05:43 AM   #5
dokalanyi
Member#: 471478
Would have to wait atleast 2 weeks to get the correct tap. I'm not in the US. I guess that's going to be my only alternative
Old 05-16-2018, 06:21 AM   #6
stevieturbo
Member#: 20366
I'm sure there are local suppliers of such parts in most places in the world ?
You could of course try and force it in....but if in doing so you mess it up and end up with a damaged jet and hole that is too large....you've just created more problems that will be harder to rectify.
Old 05-16-2018, 03:32 PM   #7
pcampbell
Member#: 437670
2005 2.5 SC OB
buy a tap and the correct size drill bit for the tap. as mentioned, be careful of metal shavings... don't want that in your engine.
if you force it, it's going to leak.
pcampbell is offline   Reply With Quote
Old 05-16-2018, 05:04 PM   #8
dokalanyi
Member#: 471478
I decided to risk it. It was a PITA. But looks very snug. Looks unlikely to leak. All my tools were the wrong sizes. Including the drill bits. I guess it's Metric Vs Imperial. I actually couldn't find a local 1/8" NPT tap. In fact, no NPT taps at all. There were some BSPT though
Old 05-16-2018, 05:55 PM   #9
stevieturbo
Member#: 20366
BSPT is almost identical and would be fine to use.
Old 05-17-2018, 07:53 PM   #10
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
How much boost are you running? Be sure and report back when it fails.
Old 05-21-2018, 03:48 AM   #11
dokalanyi
Member#: 471478
I'm running 18psi. Will report back when it fails.
Old 06-18-2018, 07:04 PM   #12
pcampbell
Member#: 437670
2005 2.5 SC OB
You can try e6000 glue in the hole to seal it up. It is what the manufacturers call for.
