10-04-2000, 02:50 PM | #1 |
Member#: 1039
Oem\fatory alarm\front parking light and turn signal glitch
I installed my factory alarm system last
sunday and I believe that I reconnected everything back to spec. Next day I dis- covered that the front turning indicators were not working at all. The rears are working but are blinking real fast now. My parking lights work but the front turn signals are not working. The alarm works like a charm. Anybody have any thoughts or ideas. Thanks in advance!!!!! Web |
10-04-2000, 06:23 PM | #2 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
Did you put those two wiring looms back into the fusebox behind the dash?
10-04-2000, 06:44 PM | #3 |
Member#: 1039
Ridinlow,
Are you referring to the 2 main harness's? If so, yes. If you are referring to the little wire jumper that is supplied with the OEM alarm it is connected securely as well. I'm stumped. I retraced the whole procedure tonight again to make sure that I did not miss any step but I can not get the front turn signals to function properly. Webber |
10-04-2000, 06:50 PM | #4 |
Member#: 329
Yeah, that's what I was referring to. I forgot to put them back in this weekend & my car did the same thing, except the ABS light was also on.
Could it be possible that you blew a signal light fuse? Although I don't think that the front lights run on a separate circuit from the rears... hmm... |
10-05-2000, 10:51 AM | #5 |
Member#: 1039
bump
Similar Threads | ||||
parking light---> Turn signal | jaypt802 | Electrical & Lighting | 0 | 11-19-2008 02:22 PM |
parking lights and turn signals | alex.rides.bikes | Electrical & Lighting | 3 | 08-28-2007 01:29 AM |
WTF: MY brake lights and front signal lights won't turn off | 05ImprezaRS | General Community | 7 | 04-10-2007 06:59 AM |
04 STI parking light and turn signal | STi - IMPREZA | Electrical & Lighting | 4 | 04-07-2004 12:01 AM |
Switching parking lights with turn signals | imprezive | Interior & Exterior Modification | 22 | 02-14-2002 10:09 PM |
