Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2020
Old 10-03-2017, 11:02 AM   #151
CursezZz
Member Sales Rating: (3)
Member#: 414974
2006 Subaru WRX STi
Obsidian Black Pearl
I had these headers on MY05 WRX for about a year before I sold the car, I liked it for the price. it did touch the filter, at first I dented the filter, then I did an oil change and re-dented the next filter but not enough and it rubbed a pin hole in the filter. I had to swap it out in a massive rain downpour lol. then the filter I replaced it with got yet another pin hole in it less than 100 miles. So after that I just heated the header with a torch and beat the crap out of it until there was enough clearance to never have to worry about it again. if I ever had to do it again, I would just spend a little more and get HKS ELH.
CursezZz is offline   Reply With Quote
Old 10-04-2017, 09:17 PM   #152
1VIPWRX
Member Sales Rating: (21)
Member#: 107554
yellow
Originally Posted by bmxhotsauce View Post
Photos ?
Sorry no photos . I hardly drive the car . When I do an oil change i will take pics .
1VIPWRX is offline   Reply With Quote
Old 10-05-2017, 03:16 PM   #153
bmxhotsauce
Member Sales Rating: (10)
Member#: 127099
02 IMPERZA WRX
BLACK
you can see our header was touching the OEM filter they told us to use. i would never run it this way.
IMG_1867 by bmxhotsauce, on Flickr
IMG_1866 by bmxhotsauce, on Flickr
IMG_1865 by bmxhotsauce, on Flickr
IMG_1864 by bmxhotsauce, on Flickr
bmxhotsauce is offline   Reply With Quote
Old 03-16-2018, 09:04 AM   #154
Darkpira7e
Member#: 369405
03 WRX
Sedona Red
Not quite apples to apples, but I've been running CNT UEL headers on my 13 frs; not coated or wrapped, there's a good amount of discoloration but they're running strong. I'm in VT and daily the car through snow and salt. 30,000 miles on them, no issues. I've had CNT exhaust on a bugeye as well; no issues
Darkpira7e is offline   Reply With Quote
Old 05-08-2019, 12:15 PM   #155
theoutbackdream
Member#: 301179
2013 WRX Limited
Sorry to bump this old thread, but i'm thinking about purchasing a set of CNT headers for my 13 WRX.
From the looks of it, it seems like the only issue with these headers are the fitment, and they only seem to be on the Blobeye/hawkeye wrx's?
Can anyone confirm that? Or does anyone with an 11+ WRX have these and have fitment issues?
theoutbackdream is offline   Reply With Quote
Old 05-11-2019, 12:57 PM   #156
Gally316
Member Sales Rating: (1)
Member#: 494541
2009 wxr
wrb
Just installed a set of CNT headers for my 2009 wrx. Fitment was spot-on with plenty of clearance for the oil filter.
Gally316 is offline   Reply With Quote
Old 05-12-2019, 02:38 AM   #157
theoutbackdream
Member#: 301179
2013 WRX Limited
Can you post pics of the clearance?
Also, do you have the v2 or v3?
Old 05-12-2019, 10:07 AM   #158
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Might not be a great comparison to others. The 2009 WRX came from the factory with one of three different oil cooler options from the factory, or none at all. Some of the coolers significantly change the oil filter location compared to other model years and especially the STi.
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is online now   Reply With Quote
Old 05-14-2019, 08:50 PM   #159
H_wells3000
Member Sales Rating: (14)
Member#: 322035
if im not mistaken 08-14 wrx have no oil cooler at all. v2 cnt will not fit with factory oil coolers. be it the straight one or angled. They may have fixed it with the latest revision but IDK.
H_wells3000 is offline   Reply With Quote
Old 05-15-2019, 08:15 AM   #160
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
09 is the worst with one of 4 possibilities (angled, offset, STi or none), after that it's typically the same part number as the STi. It's almost as if Subaru ran out of a specific part number and kept using up whatever they had until they ran out,
__________________
vs.
Old 07-27-2019, 04:13 PM   #161
JIB
Member#: 135051
2006 WRX Waggy
Default V3 Cnt
My v3 cnt el header will be in later this week for my 06 wrx wagon. Curious about what Iíll be needing to make my existing oil cooler fitment work with these headers. Some say use sti cooler and filter bolt. Iíve heard about using what is already there by eliminating the angled plate adapter and modifying my oil cooler lines to fit (preferred if possible).
Anyone have any experience in my situation? Thanks fellas
JIB is offline   Reply With Quote
Old 09-02-2019, 12:08 PM   #162
1VIPWRX
Member#: 107554
yellow
how did the v3 work out?
Old 09-02-2019, 12:45 PM   #163
JIB
Member#: 135051
2006 WRX Waggy
Default Cnt El V3
It took some doing but it worked out excellent! I was able to make my existing oil cooler work plus some gates heater hose from Oíreillyís. One straight piece and one pre formed 90 degree section. Very happy with the way it turned out!!
I deleted the angled plate adapter and bolted the oil cooler directly. Had to make necessary adjustments to the coolant lines on the oil cooler for clearance but it all came together. I can try and put up some pics if needed.
Old 09-02-2019, 10:27 PM   #164
JIB
Member#: 135051
2006 WRX Waggy
Old 09-02-2019, 10:31 PM   #165
JIB
Member#: 135051
2006 WRX Waggy
Old 09-02-2019, 10:32 PM   #166
JIB
Member#: 135051
2006 WRX Waggy
