Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 06-30-2019, 04:56 PM   #1
Acaicia
Member#: 503775
Default My rods won't fit on my crankshaft
Howdy!
I'm rebuilding my EJ25 engine and my rods won't fit on my crankshaft anymore. I took a micrometer to everything and it's in spec, I did get new bearings and they're the exact size as the old ones (Just for kicks I tried fitting the rod on the crank with the old bearings, still nothing)
More specifically, I can get the rod on but the cap and the rod won't meet without creating a whole ton of friction to the point I physically can't move them when they're torqued correctly.
Acaicia is offline   Reply With Quote
Old 07-01-2019, 10:42 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
What? Pics please.
Old 07-01-2019, 11:04 AM   #3
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Are you using assembly lube, or oil at the very least?? Pretty confused why you're having such problems.
viper_crazy is online now   Reply With Quote
Old 07-01-2019, 12:14 PM   #4
Barney145
Member#: 376219
Sounds like wrong caps on the wrong rods
Barney145 is offline   Reply With Quote
Old 07-01-2019, 12:53 PM   #5
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Oh, good call. Not only are the caps rod specfic, and also bolt hole specfic.
Old 07-02-2019, 01:25 AM   #6
Acaicia
Member#: 503775
It's alright fellas I figured ou the problem.
I used lube and I used the correct caps, but my bearings were 020 instead of standard
kill me
Old 07-02-2019, 02:21 AM   #7
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
Originally Posted by Acaicia View Post
Howdy!
I hope you were just in a rush, but please slow down. Looking forward to your successful build story.
JDMJNKY is offline   Reply With Quote
