Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 07-17-2019, 11:24 AM   #1
gw7
Member#: 490887
2007 STI
Urban Grey Metallic
Default Laggy, choppy at low RPM ó cause for concern?
Hey guys.
Bought a 2007 STI tuned on Speed Density with a built EQ Stage 1 block, bowl bend valves, BC cam, 1000cc top feeds, Grimmspeed TGV deletes, ATP GT3076R, Tial 44mm EWG, KS Tech 73mm CAI, Perrin FMIC, etc. etc. etc.
The car rips at WOT on both the 18psi 93 oct tune and the 21psi e85 tune.
However, at low RPM (at idle in neutral, for example) the throttle response is REALLY slow/laggy and "chops" or "stumbles" a bit when revving in neutral.
Similarly, if I'm coasting to a stop (car is in neutral) and I give it a little "blip", it's choppy and hesitates to rev back up if I want to rev match, for example.
Both of these things only really happen under 3k RPM. Driving around in low RPMs, it can be a little wonky/choppy at light throttle until the car is fully, FULLY warmed up. I baby the car until it's been driving around for at least 10 minutes, and even then, I RARELY get into boost. I drive slow 99% of the time.
Even once it's smooth at low RPM and fully warmed up, it still feels "hesitate-y" in low RPMs until it's up around 3.5k.
Do I just chalk this up to "big turbo, CAI/FMIC, speed density tune" probs?
Had a compression/leakdown test done before buying the car about a year ago and everything came back good.
However, the motor was built YEARS ago (I think like 9-10 years ago). It was re-tuned in the last 3-4 years. Does this sound like something a re-tune or adjustment could fix?
I'll be moving to a higher-elevation state soon, so I was going to have the car retuned anyway, but don't want it going on the dyno if **** could potentially blow up.
gw7 is offline   Reply With Quote
Old 07-17-2019, 12:45 PM   #2
GravyRobber
Member#: 205568
2017 WRX STi
Would you be able to post a data log? That would be a fairly easy way to check on the general health of things.
GravyRobber is offline   Reply With Quote
Old 07-17-2019, 01:00 PM   #3
JSR84
Member#: 469585
Logs....
JSR84 is online now   Reply With Quote
Old 07-17-2019, 05:16 PM   #4
gw7
Member#: 490887
2007 STI
Urban Grey Metallic
I can certainly post a log! Didnít know you guys were able to decipher them. Iím certainly not. What parameters should I log, and what kind of driving should I do?
Old 07-17-2019, 05:17 PM   #5
Fahrezz
Member#: 501383
+1
Fahrezz is offline   Reply With Quote
Old 07-17-2019, 06:53 PM   #6
Haevn
Member#: 495950
Do you have TGV deletes? I know after i did my deletes my car studders sometimes between 2-3k rpm at light throttle
nvm just re read your post and seen you do have them lol
Haevn is offline   Reply With Quote
Old 07-17-2019, 07:17 PM   #7
JSR84
Member#: 469585
Originally Posted by gw7 View Post
I can certainly post a log! Didn’t know you guys were able to decipher them. I’m certainly not. What parameters should I log, and what kind of driving should I do?
AF Correction 1
AF Learning 1
AF Ratio (Both the factory sensor and a wideband if you're able)
AVCS (Exhaust and intake if you have dual)
Boost
Calculated Load
Dynamic Advance Mult.
Knock Learning
Feedback Knock
Injector PW
MAF
MAF Voltage
MAP Abs
Primary Ignition
Throttle Position
VE
That's all I can think of now. Do a couple of sweeps through the problem areas.
