Welcome to the North American Subaru Impreza Owners Club Saturday August 17, 2019
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 08-05-2008, 07:06 PM   #1
Cautionjump
Member#: 135459
Default Will I pass NC inspection with a catless downpipe?
Hi guys!
Im looking at going stage 2 Cobb, and was curious for anyone else in NC that is running with no cats had troubles passing smog.
Im running a skidplate, so they wont even be able to see under the engine, so I just worry about the smog.
And what about catless uppipe as well? Just curious how taking these off will affect ability to pass, since I dont feel like taking if off again.
And finally, anyone running a Vf34 in the area, since Id love to eventually go that route!!!
Thanks for the help, and this is for the 03 WRX obviously.
Cautionjump is offline   Reply With Quote
Old 08-05-2008, 07:12 PM   #2
Glenn Hough
Member#: 111276
2009 07 SWP WRX Wag
and 09 SWP Forseter XT
They just plug into the OBD port, right? No more sniff test. If you have COBB AP -> no codes -> pass test. If they see no cat, then maybe a problem. Someone please correct me if I'm wrong here.
Glenn Hough is offline   Reply With Quote
Old 08-05-2008, 08:14 PM   #3
NC02Bugeye
Member#: 185990
2002 Impreza WRX
I'll ask someone at work, I haven't been here long but a lot of people at my job have been here awhile =p
NC02Bugeye is offline   Reply With Quote
Old 08-05-2008, 08:18 PM   #4
scoobynewbie1
Member#: 150406
2006 wrx wgn
wrb
there is no more sniff test... as long as there is no check engine light, it'll pass the obd2 tester... techs are suppose to lift your car up and inspect for cats... if you can find somone that won't lift your car up like i did, then you are good to go...
scoobynewbie1 is offline   Reply With Quote
Old 08-05-2008, 08:57 PM   #5
rek888v2
Member#: 71287
S202 #387, Type RA
#169 and an 04 STi
Ive passed with an AP for the past 4 years. Catless and never fails.... Have failed a visual oncxe though....
rek888v2 is offline   Reply With Quote
Old 08-05-2008, 09:04 PM   #6
Bourque77
Member#: 101084
2002 wrx
blue cf hood blue wheels
You will pass unless they decide to do a visual
Bourque77 is offline   Reply With Quote
Old 08-05-2008, 09:28 PM   #7
Cautionjump
Member#: 135459
Hmm I was thinking they still did the sniff test with the OBD2. My last inspection had the emissions all broken down I believe... Ill have to check...
Visual shouldnt be a problem, with the SPT heatshield and intercooler you cant see down at the pipes, and with the skidplate you cant see up, and I doubt they would pull it off.
Thanks!
Eric
Old 08-05-2008, 09:52 PM   #8
Superorb
Member#: 135252
2002 WRX Wagon
Hmm, I'm in the same boat too. I rushed another FL renew to put it off another year, btu I have catless and a skid plate, no codes from XPT map. I hope it's that easy.
Superorb is offline   Reply With Quote
Old 08-05-2008, 11:02 PM   #9
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Go to capital blvd.. Jiffy lube.. they are just toooo lazy to lift your car!
AWDBoost is offline   Reply With Quote
Old 08-06-2008, 12:48 AM   #10
SPECTRE2099
Member#: 128019
2013 BRZ Limited
Crystal Black Silica
Do what I do and take it to a Jiffy Lube 10 minutes before closing time on a Saturday. I'm totally catless and have had no problems.
SPECTRE2099 is offline   Reply With Quote
Old 08-06-2008, 06:48 AM   #11
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
I too have had no problems.
However, if you are looking for a downpipe, Im thinking of selling mine soon.
cucamelsmd15 is offline   Reply With Quote
Old 08-06-2008, 09:27 AM   #12
smakdown61
Member#: 93797
2008 Mazdaspeed 3
Thanks!
Eric
They can still fail you if they can't see it.
smakdown61 is offline   Reply With Quote
Old 08-06-2008, 09:33 AM   #13
NCStateSTi
Member#: 177735
2015 WRX
Dark Gray Metallic
Great f'n idea! I'm gonna try that this time, instead of takin down to the hood where I know they couldn't care less.
As for the visual inspection, you may be able to tell the guy your resonator is a cat, but if they have any sense, as far as O2 sensor goes, thatll blow up in ur face.
NCStateSTi is offline   Reply With Quote
Old 08-06-2008, 10:46 AM   #14
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Lol this is what i have been doing for 5 yrs .. I take it to roxboro rd in Durham!! No lift at the shop..But like 5 Pitbulls!!!
Old 08-06-2008, 11:01 AM   #15
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
Hi guys!
I passed catless up/down pipes. I also run a vf34
legacy1907 is offline   Reply With Quote
Old 08-06-2008, 12:16 PM   #16
GreenMarine
Member#: 36080
2005 Volvo V70R
I passed inspection 2 years ago with completly shot CATs... And when I say "completly shot" I mean the ceramic material came out in chunks when they were cut out of the exhaust... ... No problems passing anymore with my Metallic substrate CATs
~ Chris
GreenMarine is offline   Reply With Quote
Old 08-06-2008, 12:18 PM   #17
Superorb
Member#: 135252
2002 WRX Wagon
I was waiting for someone to find a shop w/o a lift
There's still the issue of me passing an eye exam for my NC license...
Old 08-06-2008, 03:10 PM   #18
smakdown61
Member#: 93797
2008 Mazdaspeed 3
~ Chris
With an obd1 car you can shoot dog **** out the exhaust and they still have to pass you as long as you have no CEL and there is something resembling a cat underneath (assuming they check).
Old 08-07-2008, 11:25 AM   #19
DustinTarditi
Member#: 139798
2005 WRX Wagon
I run a Stage2 Cobb 93 Oct map with Cobb CBE and Injen Catted DP
The low-restriction cat keeps you legallay running w/ a cat.
The design of the stock DP itself is as much of an issue as the cat - lots of restrictive bends and a blocking plate where it comes off the turbo - Injen and Cobb designs are both bellmouth.
DustinTarditi is offline   Reply With Quote
Old 08-07-2008, 09:09 PM   #20
nuggetWRX
Member#: 177174
2007 Impreza 2.5i
Sport Wagon
i dont know about all the technical OBD emissions here in NC (i mean i'm running an STi factory cat-back on my 2.5i Wagon, shouldnt be a problem) but maybe you could gut the cat and weld it back up so it looks like it has a cat but actually is hollow. my only concern then would be noise ordinance violations :-D
nuggetWRX is offline   Reply With Quote
Old 08-07-2008, 10:39 PM   #21
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
WIn!!
That's the funniest ish i've heard all day. Sad, in a pitiful sort of way, but funny!
4wdrift is offline   Reply With Quote
Old 08-07-2008, 11:43 PM   #22
GreenMarine
Member#: 36080
2005 Volvo V70R
Oh yeah, that's right... I forgot the last time I was tested for emmissions was in 2005... Haha, now it's just a safety inspection for me... Speaking of which, I've gotta go get that done
~ Chris
Old 08-08-2008, 09:30 AM   #23
Braz
Member#: 64273
2005 STi
CGM
i'm fully catless, and had a bit of difficulty when i had my cel-fix wired in. Even if my CEL was not on, the voltage reading off the rear o2 sensor was too low. After removing the wired fix and installing a mechanical fix there was no problems. I imagine if you tune it out there wont be any problems.
Also if you've reset your ECU within the past 120miles or so it can throw an unready code.
I've yet to fail for there visually being no converter in NC.
Braz is offline   Reply With Quote
Old 02-07-2017, 02:01 PM   #24
JohnFXT05
Member#: 462381
Say, how often are the inspections.. (once a year)?
JohnFXT05 is offline   Reply With Quote
Old 02-07-2017, 03:03 PM   #25
subezero
Member#: 207614
2008 WRX Hatch VF52d
SSM
8.5 year thread bump, nice. Yes once a year.
subezero is offline   Reply With Quote
Will I pass NC inspection with ABS on? Zackbo South East Region Forum 16 07-30-2009 08:36 AM
Will I fail inspection with a catless uppipe? elhockey3 New England Impreza Club Forum -- NESIC 14 12-30-2008 12:03 PM
Will my car pass State Inspection with rear seats removed? WRXVII Interior & Exterior Modification 2 04-23-2005 10:06 PM
Will I pass PA inspection with Airbag light on? il96 Tri-State Area Forum 5 09-08-2004 05:46 PM
Will it pass NYS inspection with with a turbo back exhaust? stihopeful Newbies & FAQs 4 06-08-2004 04:01 PM
