Welcome to the North American Subaru Impreza Owners Club Wednesday August 21, 2019
Old 10-02-2008, 03:17 PM   #26
strong_auto_concepts
Member#: 83716
'04 Burn-Up WRX
IGES is an obvious choice. It will be nice if there are more formats as well. necessary space can grow in a hurry, but it's not a huge ordeal.
You brought up a good point of a naming convention. Maybe we can go for something along these lines:
MY-Model-Part-creator
So your Alternator would be 03-WRX-Alternator-bishop333.iges
More comments could be added in the notes sections of the properties for a part.
Obviously general shapes are acceptable. When someone comes up with a more detailed part, we'll replace it.
I'll have to come up with some webspace. I have an ENOVIA server, but I have a feeling that's a little much for most people.
I think .01" for tolerance is more than enough. I'm also not interested in trying to model accurate internals.
I'm out of town for the next few days, but I'll try to get something a bit more formal going at the end of the weekend.
Also remember, once you submit this, it will be public domain. Don't submit something that you've designed and then be disappointed when someone else decides to make it and make money on it.
For now, if you want me to host a file, send it to [email protected]
Parts List:
Heads LH/RH - S.A.C.
Block Halves LH/RH
TGV - S.A.C.
Intake Manifold
Oil Pan
Alternator and brackets
A/C Compressor
Power Steering Pump
Oil Pump
Water Crossover
Throttle Body
Valve Covers
Electrical Sensors - S.A.C.
Intercooler (Stock/Aftermarket)
Fuel Rails
strong_auto_concepts is offline   Reply With Quote
Old 10-02-2008, 06:17 PM   #27
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
this will be cool if this gets working.
I'm currently at school for engineering so i hope i can possibly contribute. i do have access to mastercam 9.1 and X3 along with vericut 6.2 so if anybody needs some G-code created or checked then let me know.
catia is awesome. i've only seen boeing use it though... ($$$!!!!!!!)
solid works is what i use.
Zefy is offline   Reply With Quote
Old 10-02-2008, 07:28 PM   #28
STIGuy115
Member#: 145503
06' Impreza WRX
SGM
Just found this thread.
It would definately be awesome to have a 3D model of the EJ. I work for a design and engineering ccompany here in Michigan. I have access to Catia V5, UG NX 3-5, Solidworks, and other programs. I've been trying to compile a bunch of dimensions in order to start a basic model in my spare time, but I've been way to busy lately. I've got 4 projects going on and haven't been able to put much time into this. I may be abble to contribute, but I don't know how much.
Mike
STIGuy115 is offline   Reply With Quote
Old 10-02-2008, 07:29 PM   #29
SKC
Member#: 15250
A collegue of mine is a transport industry designer using UG NX5. He has a model which he has used to develop his Mini Project (complete subbie running gear into an original Mini.). I'll see if he has anything to contribute.
SK
SKC is offline   Reply With Quote
Old 10-02-2008, 09:04 PM   #30
Member#: 83716
'04 Burn-Up WRX
if skc finds something that would be killer. Otherwise when I get back on Sunday I'll put together a list of parts and people can take a couple and then submit them when they're done.
Old 10-03-2008, 03:20 PM   #31
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Well this sounds great!!
as for the tolerance of 0.01", that should be plenty as many of the parts being taken are cast parts and any of this machining is done with "slop holes" for misalignment (notice play with intake manifold bolt holes, alternator/ac bracket, etc...
Old 10-06-2008, 03:38 PM   #32
Member#: 83716
'04 Burn-Up WRX
Okay, I'm back. I started a Google Group. This would allow people to upload files. Unfortunately it has a 100MB limit. I'm not sure if there's an option for more space, or if more people joining means more space.
I'm still exploring more options for housing models.
And now for a list. I wish this forum had a WIKI post option. I'm going to edit the first post and put user names next to the parts that people are committed to modeling. If you have more to add, just post and I'll add it to the list.
Old 02-13-2009, 10:15 PM   #33
Member#: 83716
'04 Burn-Up WRX
Wouldn't it be awesome if I had an engine in there somewhere. Maybe I'll get some time soon
Old 02-13-2009, 11:34 PM   #34
colingilchrist
Member#: 138516
2011 Honda CRV
I've got access to a lazer scanner as well as a Romer CMM arm (similar to Faro). If you can supply parts I can scan them and give you the point cloud data. I can also use the Romer arm to capture planes and bores acurately...
I work up at the Everett Boeing plant.
Send me a PM if you are still interested in working on this project...
I do most of my CAD/CAM work in Mastercam, but I can also use Catia and Solidworks...
colingilchrist is offline   Reply With Quote
Old 02-13-2009, 11:42 PM   #35
Member#: 83716
'04 Burn-Up WRX
Well ****.... Can't ask for much more than that.
PM on it's way.
Cheers
-Steve
Old 02-17-2009, 12:49 AM   #36
KevlarSTi
Member#: 134036
2007 STi Limited
Satin White Pearl
This thread makes me happy in the pants. There's a CNC Mill I have access to via my school's FSAE team, and I've had a few small things in mind that I'd like to try making, so a CAD engine model would help me immensely. Here's hoping something comes of this.
KevlarSTi is offline   Reply With Quote
Old 02-17-2009, 02:46 AM   #37
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
Definitely interested in this. I have messed around with solidworks and such a bit, but I'm definitely not good enough to model parts like that. This will be awesome when it's all put together
Thug Nasty is offline   Reply With Quote
Old 02-17-2009, 03:06 AM   #38
sorrowfulkiller
Member#: 170439
I <3 Lamp
I beleive someone on deviantart did an ej engine awhile back... I'll see if I can find it...
it was done in illustrator... so not really the same... but heres a link if anyone is interested
http://donefour.deviantart.com/art/I...ngine-16210822
sorrowfulkiller is offline   Reply With Quote
Old 02-17-2009, 02:18 PM   #39
Member#: 83716
'04 Burn-Up WRX
I'll let people know what happens. I haven't heard back from the guy here at Boeing yet. The illustrator picture is nice, but useless unfortunately...
Old 02-17-2009, 11:11 PM   #40
Legba
Member#: 88589
2005 STI
the best one
lots of stuff in here...
http://www.3dcadbrowser.com/preview.aspx?ModelCode=7332
Don't see any Subaru engines though
Legba is offline   Reply With Quote
Old 02-17-2009, 11:32 PM   #41
colingilchrist
Member#: 138516
2011 Honda CRV
Pm'ed ya back Steve... Looking forward to meeting you.
-Colin
Old 03-13-2009, 06:59 PM   #42
Member#: 83716
'04 Burn-Up WRX
Engine is ready to get laser scanned. I'll post progress as soon as there is some.
Old 04-22-2009, 10:40 PM   #43
Homemade WRX
Member#: 33782
96 in the garage
bumpity
any updates? did it get scanned?
Old 04-23-2009, 02:23 AM   #44
Member#: 83716
'04 Burn-Up WRX
having trouble finding time we can both get down to the laser scanner.
I did get a decent scan of the head lights and tail lights at home. I'll get some new renders up tomorrow. Maybe this friday we'll get down there.
Old 09-01-2009, 07:42 PM   #45
Member#: 83716
'04 Burn-Up WRX
Had to start from scratch. Didn't like some of the measurements. Still not happy with CATIA's internal renderer. Might have to try something else.
Old 09-01-2009, 07:46 PM   #46
Member#: 83716
'04 Burn-Up WRX
Old 09-01-2009, 07:56 PM   #47
Member#: 83716
'04 Burn-Up WRX
That's it for now. I'll throw some other materials on it and see what happens.
Old 09-01-2009, 09:52 PM   #48
colingilchrist
Member#: 138516
2011 Honda CRV
Looking good holmes.
What width are the tires modeled at? Looks like it could use another inch maybe for the pics to balance it out...
We need to go scan some more engine parts...
Old 05-25-2019, 03:31 PM   #49
Tinho
Member#: 483929
Hi everyone's!
About this ej cad model, somebody have it?
I want to diy new oil pan here in Brazil.
Tinho is offline   Reply With Quote
Old 05-25-2019, 04:16 PM   #50
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
EJ engine scan?...
KillerBMotorsport is offline   Reply With Quote
WRX CAD Model ? AeroWRX Off-Topic 1 04-08-2009 01:34 AM
anyone do solidworks or 3d Cad modeling software??? WRXINTX Off-Topic 17 10-25-2006 08:56 PM
Subaru Engine CAD Models? bryan_johnson Subaru Conversions 2 01-19-2005 10:33 PM
3D CAD model of Impreza? f4phantomii General Community 23 10-12-2004 01:12 PM
What's the combustion sequence of the ej series engines? The Enemy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 03-13-2003 07:07 PM
