Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 04-06-2011, 08:32 PM   #51
Maxwell Power
Member#: 190729
Originally Posted by 2slofouru View Post
cleaned,
46.6cc
Maxwell Power is offline   Reply With Quote
Old 04-06-2011, 08:42 PM   #52
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Wow, thanks for the quick response! I may have to use thicker than oem sti gaskets, the pics make it look like they shaved off more than they needed. May even need to cc both heads to check they are close. Man it sucks having only a couple of local machine shops, and they deal with 99% domestic. After dealing with them previously getting the heads and flywheel surfaced, I decided to take the 257 block to houston to find someone competent in subaru tech.
2slofouru is offline   Reply With Quote
Old 04-06-2011, 09:00 PM   #53
Maxwell Power
Member#: 190729
what pistons are you going to run?
Old 04-06-2011, 09:09 PM   #54
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Trying to decide on:
JE 291060 8.5
CP SC7421 8.2
Wiseco K598M100 8.5
I'd like to have 8.2 CR ideally, also want offset wrist pin for quietest possible but surely normal will do
Old 04-07-2011, 01:14 AM   #55
xandi911
Member#: 163991
after reading all the thread, so if i own a 08STi with stock pistons, and change the pistons... the only piston that should keep the same CR is the wiseco?? both CP and JE will drop my power due lower CR???
curious....
xandi911 is offline   Reply With Quote
Old 04-07-2011, 07:48 AM   #56
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
curious....
They make pistons for normal compression ratio, I just listed those because I'm looking for a lower compression piston to make up for my smaller volume heads so I don't end up with a substantially higher than stock compression level.
Old 04-07-2011, 10:15 AM   #57
Maxwell Power
Member#: 190729
JE 291060 8.2
CP SC7421 8.2
Wiseco K598M100 8.5
Je is 8.5
Old 04-07-2011, 10:16 AM   #58
Maxwell Power
Member#: 190729
curious....
Isn't the 08 sti 8.2
Old 04-07-2011, 03:51 PM   #59
xandi911
Member#: 163991
but JE and WISECO have pistons that keep my CR like STOCK?
Old 04-07-2011, 03:59 PM   #60
Maxwell Power
Member#: 190729
nope
the dish on the JE piston is 16.5cc.
Old 04-07-2011, 04:27 PM   #61
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
didn't the 08+ sti have a sligthly shorter rod as well?
Old 04-07-2011, 04:34 PM   #62
Maxwell Power
Member#: 190729
not that I know of....
guess I should look into that.
Old 04-07-2011, 05:05 PM   #63
Maxwell Power
Member#: 190729
the answer is no. Unless it's about 3 thou. I measured the compression height of the 08+piston and the 06STi piston. Both were the same within' 3 thou.
Old 04-07-2011, 05:24 PM   #64
Homemade WRX
Member#: 33782
96 in the garage
yeah, it was the rod spec that changed. I think Juan Medina had shown it to me...He quoted Quirt, so it's only so reliable
Edit: found it
http://forums.nasioc.com/forums/show...8&postcount=20
Old 04-07-2011, 07:03 PM   #65
xandi911
Member#: 163991
nope
and this means... my CF will increase OR DROP?
Old 04-07-2011, 07:11 PM   #66
Amuzzing
Member#: 161050
2007 STI
Increase
Amuzzing is offline   Reply With Quote
Old 04-07-2011, 08:02 PM   #67
Maxwell Power
Member#: 190729
Increase. Which isn't a bad thing.
Old 04-07-2011, 11:00 PM   #68
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Je is 8.5
My bad, I was thinking that because that JE piston is designed for use with the 257 block and ej205/207 heads to maintain 8.5. Its possible I could end up with just a tad higher with the proper gaskets. I'll have to remember to try and call JE tomorrow. Reading their site (which doesn't list weight of the pistons) there are some interesting facts. They also mention offset wrist pins but don't state any of their subaru pistons are. If I could confirm the JE model I listed had offset pins that would push me to get them as long as the CR wasn't excessively high.
Old 04-08-2011, 10:10 AM   #69
Homemade WRX
Member#: 33782
96 in the garage
JE has offset wrist pins...Nick, their import rep, is/was a subie guy.
Old 04-08-2011, 11:57 AM   #70
Maxwell Power
Member#: 190729
You're looking at a different piston. We are talking about pistons for the STi heads. JE offers a piston for the S20 heads. I don't recommend running it however due to the shrouding of the valves on the S20 head limiting power and creating hot spots. It's not the fault of the piston, it's the fault of going with a hybrid.
Old 04-08-2011, 07:16 PM   #71
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Which piston are you referring to? I posted the piston JE offers that is designed for the 2.0 head and the 2.5 (sti) block. Aren't we talking about the same one? JE 291060 ? I thought Dave was running this model. Which part number are you referring to, Maxwell?
This type, 100mm with older style square countersunk top:
http://www.jepistons.com/Catalogs/Sp..._ej20head.aspx
Old 04-14-2011, 07:27 AM   #72
Leonardo
Consigliere
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
Ok, good info!
Still a bit confused, I have a blown 05 LegGT which exept for the block saying it's a EJ255 in reality it's a EJ257.
My heads were scored with the cams so which heads should I go with? Was thinking on going with new aftermsrket pistons (bored to 100mm) and 257 heads. Cam profiles the same between the two?
Leonardo is offline   Reply With Quote
Old 04-14-2011, 10:46 AM   #73
Homemade WRX
Member#: 33782
96 in the garage
the block halves themselves are the same. You had B25 heads which are the smaller ports. You can go to the newer heads with the exhaust air ports but simply block those off and you're good to go.
I've never cross references the PN's nor measured for the cams though. I'd suspect that they're the same knowing subaru but I could be wrong.
Old 04-14-2011, 11:37 AM   #74
Maxwell Power
Member#: 190729
EJ255 and EJ257 cams are identical.
If your 05 came with the B25 heads, they are the exact same head as an STi as well.
If your 05 came with the D25 heads, they are the same as an 06+WRX.
Old 04-14-2011, 11:45 AM   #75
Homemade WRX
Member#: 33782
96 in the garage
^^^05 LGT heads were a split mid-model year?
EJ257 Block and Internals with EJ255 Heads jpirrung18 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-24-2010 05:42 PM
EJ257 vs EJ255 dyno results are in !!!! IA Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 69 03-10-2010 12:37 AM
EJ257 vs EJ255 Cam differences Maxwell Power Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-12-2009 11:39 AM
Newbie Q: EJ25E vs. EJ255 vs. EJ257 tekgnosis Built Motor Discussion 2 12-31-2006 02:26 PM
EJ257 vs EJ255 English2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-05-2006 08:52 AM
