Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 04-19-2015, 12:46 PM   #26
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Originally Posted by jmec67 View Post
i realize this is an old post but i have done this swap and it works fine i went about it differently if anyone is interested i would be more than glad to share the info
Post it for posterity....although these cars are getting old, Phase 1 vs. Phase 2 differences are still a major issue w/swaps.
Thanks
wtdash is offline   Reply With Quote
Old 04-23-2015, 10:42 PM   #27
Storm
Member#: 5218
96L Most Over-
Developed Beater
The kids buying these old cars and doing these swaps can use all the cheap help they can get. Post it up!
Jay
Old 05-11-2015, 11:29 AM   #28
reggler
Member#: 400429
1996 Legacy Wagon
Mostly green
A ph2 short block bolts in just fine to a ph1, and vise versa. The issue is with the wiring harness/intake. It's easier to keep the same heads in the car to keep the same manifold which will retain the same harness. If you're swapping things around like this you'll either raise or lower compression in doing so and may need a custom headgasket, which cometic probably already has a file on to make.
reggler is offline   Reply With Quote
Old 06-10-2019, 12:29 PM   #29
SPENCETHEKID
Member#: 503073
1997 Impreza
black
10 years later.... Glad i found this post but im in the process of doing this but reverse, im taking a 97 impreza with phase 1 EJ22(that jumped time) and putting in a Phase 2 EJ253 (that i already had), but after reading this im coming to the conclusion that i could just take the I.Manifold from the 2.2 block off the EGR and put in on the 2.5. If im wrong tell me (or ill find out soon enough.)
SPENCETHEKID is offline   Reply With Quote
Old 06-10-2019, 01:34 PM   #30
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
You'll want to keep reading and any Google search would answer this in 5 minutes...and please don't double-post the same request on the forum.
These are incompatible. Sell that EJ253 - should be worth $$ if any good - and buy another much cheaper '90-'98 EJ22 to swap back in...Read up.
And remember to change the timing belt, pulleys, and WP on the replacement.
anyone running phase 1 ej25 heads on phase 2 ej25 block ??? IllNastyImpreza Built Motor Discussion 7 05-04-2008 11:48 PM
Phase I DOHC to Phase II SOHC swap jnorth85 Subaru Conversions 4 04-23-2008 07:16 PM
1998 phase 1 EJ25 into 2000 phase 2 EJ22 OBS. s'ko Subaru Conversions 0 04-14-2008 12:20 PM
Headgasket VS. Phase II EJ25 to Phase II EJ22 swap- "Simple"? 99legacyL Newbies & FAQs 0 03-01-2008 04:09 PM
Phase I EJ25 vs. Phase II jetfan8178 Normally Aspirated Powertrain 6 03-21-2002 03:11 PM
