Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 10-22-2009, 08:14 PM   #1
SoloImpreza
Member#: 42520
99 P1 twin, EJ207
Default HELP!!! 98 impreza 2.2 to 98 ej25 DOHC HELP!!!!
hey guys.
does anyone know if i can throw a ej25 98 DOHC Rs motor into a 98 2.2L impreza, plug and play.
basically i just need to know if wiring will match up. i have the ecu too if need be. thanks.
SoloImpreza is offline   Reply With Quote
Old 10-22-2009, 11:45 PM   #2
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
I don't think it's plug and play... Because the crank sensors are different between the DOHC and SOHC. I'm pretty sure if you take a SOHC Phase 2 EJ25 and remove all the sensors and replace them with the EJ22 sensors, it should work. If you had a Phase 1 DOHC EJ25 you can run your intake and 2.2 heads and make it work, but I'm unsure how it would work retaining the DOHC cylinder heads.
jedz123 is offline   Reply With Quote
Old 10-23-2009, 01:50 AM   #3
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
I'm planning on doing this too. I have a 98' DOHC 2.5 and plan to drop it in a 96' Impreza 2.2
From my research, it looks like it will work plug and play. The trick is to use all the 2.2 wiring and plug it onto the 2.5 motor. The cam and crank sensors are the same plug style, and the IAC valve should be the same as well. You do need the whole 2.5 motor including the manifold, because the 2.2 manifold will not bolt on the 2.5 heads...it's a different bolt pattern.
So basically the 2.2 ecu and wiring is running the 2.5 mechanics. The fuel trims should be close too since the 2.5 will have the injectors for that size motor.
I will soon find out when I complete the swap.
morrocco88 is offline   Reply With Quote
Old 10-23-2009, 01:47 PM   #4
vipergtrdj
Member#: 131770
2001 Subaru Impreza
I am in the process of this - just with a '01 L to a ej22t/ ej25dohc and everything bolts up. I am using the 2.2 wiring and sensors, on the 2.5 intake manifold. But ran into a problem with the crank sensor - believe it got damaged when swapping as its throwing a CEL for P0336 CKT range/perf. I will swap that out and let you know how it goes.
I know its a little different from your swap, but electrical wise should be the same - ej25 running on ej22 ECU.
vipergtrdj is offline   Reply With Quote
Old 10-24-2009, 04:45 PM   #5
SoloImpreza
Member#: 42520
99 P1 twin, EJ207
well i have the EJ25 RS ECU
basically i bought a second RS for a wrx swap. my friend in his 1998 impreza needs a new engine. his 2.2 spun a bearing. so just wondering if i can throw my RS DOHC engine in his car!
Old 11-07-2009, 08:21 PM   #6
silverWRX_02
Member#: 123564
2001 Impreza L
I'm not sure about the DOHC but I'm swapping a phase II 2.5L SOHC into my 2001 impreza L 2.2L and everything is plug and play. Only thing I have to change is the exhaust manifold to a dual port. I'd do that if I were you. I've heard the SOHC are better than the DOHC anyway.
silverWRX_02 is offline   Reply With Quote
Old 11-10-2009, 10:10 AM   #7
SoloImpreza
Member#: 42520
99 P1 twin, EJ207
ok guys, i have been trying to do some research that is narrowed to more of my exact swap issue and i cannot narrow it down. so far i got conflicting stories....
theories
1) swap the 98 DOHC RS motor in the My 98 Impreza 2.2L but swap sensors over
2)take ej22 engine harness and put it on ej25 98 engine
3) is theory 2 done because most people dont bother to get the ej25 ecu? basically is the engine harnesses swapped because of ej22 ecu running ej25?
basically i want to go into this project and be done with it. i dont want to mess around. i have a second impreza RS i am swapping, and this NA swap is for a friend. i dont have time to trouble shoot.
i have exhaust dual port headers, MY 98 Ej25 DOHC ECU, and complete MY 98 Engine.
Old 11-10-2009, 05:47 PM   #8
SoloImpreza
Member#: 42520
99 P1 twin, EJ207
badabump
Old 11-13-2009, 08:49 AM   #9
j.Mack
Member#: 192347
1997 RS2.5 I-Wagon
well I have a 98 RS motor in my 97 wagon, The PCM and harness was all plug and play, you will need the coil pack for the DOHC motor though as the 2.2 one does not work (or fit iirc). Pretty easy swap, imo, but if you want a full RS conversion, you will have to swap the PCM in, I wouldnt even bother with the harness. My 2.2 PCM handles its duties without one problem so its really up to you to put in what you want.
j.Mack is offline   Reply With Quote
Old 11-15-2009, 07:58 PM   #10
turbo01gc8
Member#: 217973
2001 turbo impreza L
acadia green
was thinking about this swap b/c i turboed my 01 impreza L w/ the 2.2L sohc. got 164K on it. will a complete 2.5 dohc swap work with my ecu? i am aware of the dual port header i have to get
turbo01gc8 is offline   Reply With Quote
Old 11-15-2009, 10:27 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Your answer is #2. Except just transfer the engine harness. You won't have a plug for the EGR, so leave it unhooked. The IACV may be a little different location wise, but otherwise plug and play.
Jay
theories
Old 05-23-2014, 01:56 AM   #12
double0sport
Member#: 375644
2000 impreza outback
black with blue ridge pea
Is it possible to swap the 2.5 rs top end onto a 00 ej22??
double0sport is offline   Reply With Quote
Old 10-04-2014, 05:47 PM   #13
erkkrose
Member#: 402490
Know if you can put a ej25t from an 07 impreza into a 98 with all the harnesses and ecu included with the 07 engine?
erkkrose is offline   Reply With Quote
Old 03-10-2015, 12:27 PM   #14
AWDacious
Member#: 409099
1997 Impreza EJ25
Red,blk and stupid purple
Ok, so what's the story with the headers? I have a 97 gf4 ej22 but I'm putting in a 98 ej25d from a legacy GT. Will the headers from the GT bolt to the rest of the exhaust in my car without modification?
AWDacious is offline   Reply With Quote
Old 05-24-2016, 02:53 AM   #15
JacquesMWest
Member#: 447534
Sorry to post on an older thread, but what engines would be a direct plug and play? It's for an 1998 Subaru Outback with an EJ25.
JacquesMWest is offline   Reply With Quote
Old 06-03-2019, 07:58 AM   #16
Krw.8886
Member#: 502828
I'm also wanting to swap the 2.2 out of my 95 Legacy for the 2.5 out of a 97 Legacy GT. Is there anything I need to know so that when the swap is done it will run right?
Krw.8886 is offline   Reply With Quote
2006 WRX fuel pump fitting onto a 98 Impreza L 2.2?? silver06wrx Pre-2002 Factory Turbo Powertrain 1 04-08-2007 10:35 PM
I need a MT for a 98 impreza L 2.2 rufracer Private 'Wanted' Classifieds 0 03-17-2007 02:48 PM
98 Impreza L 2.2 White Sedan - CO - $3000 Jish Private Vehicle 'For Sale' Classifieds 1 08-02-2006 01:56 PM
98 Impreza L 2.2 kinda. kilahkam Private Vehicle 'For Sale' Classifieds 15 08-02-2006 10:55 AM
Selling 98 Impreza rs 2.5 automatic transmission blueimprezars2.5 Private 'For Sale' Classifieds 0 09-26-2005 12:24 AM
