Welcome to the North American Subaru Impreza Owners Club Sunday August 25, 2019
Old 06-16-2012, 04:17 PM   #26
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
Does anyone happen to know the size of these 2 fittings? Are they 1/8" NPT?
8thWonder is offline   Reply With Quote
Old 06-16-2012, 09:11 PM   #27
8thWonder
Member#: 230366
2005 STi
^^update, they're not 1/8" NPT
I'm thinking they're M10-1.0 bolt size... not 100% sure though, since the only parts store within walking distance didn't carry that size.
Any feedback would be greatly appreciated. I'm either going to plug those holes or use different size vacuum fittings in them.
Old 06-17-2012, 10:32 AM   #28
Storm
Member#: 5218
96L Most Over-
Developed Beater
Good info in here. I will add that I used the OBX rails that came with my ITB kit....mostly because I had them onhand and knew I would be fabricating adapters anyway.
You can see the small adapters I made for the rails, as well as the 1" spacer welded to the .500" plate I had previously welded to the plenum. My throttle cable bracket is anchored to the lower boss on the plenum and the cable runs under the coolant crossover, up to the TB. It's a 70mm Ford unit with no IACV. This setup has no idle function aside from a programmed fuel/spark cut on the ECU side (aka GpN type).
Also note that most aftermarket rails will interfere with the oil fill tube. This will need addressed.
Jay
Old 06-17-2012, 05:35 PM   #29
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
They are 1/8 BSP from the factory, but I chased those threads with a 1/8 NPT tap and used 1/8" NPT fittings (Thats my manifold pic).
lukeskywrx is offline   Reply With Quote
Old 06-17-2012, 06:37 PM   #30
8thWonder
Member#: 230366
2005 STi
Thank you so much for the info! I think I'll be ordering a 1/8 NPT tap as well.
Old 01-14-2014, 10:19 PM   #31
25rsti
Member#: 166324
I just want to bump this up for people. We should keep this thread alive for issues, solutions and ideas.
Seems to me that the biggest hurdles are DBC throttle body issues, and clearing issues when used with AVCS heads.
Old 01-15-2014, 02:59 AM   #32
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
^^^ Zero drift sports makes a rail, contact ASF to get them. They have been installed on AVCS and DBW cars.
project_skyline is offline   Reply With Quote
Old 01-15-2014, 09:08 PM   #33
nashelton
Member#: 253882
2011 STI Sedan
Dark Grey Metallic
I have a 2011 STI and a 2.5 NA longrunner intake manifold. I used outfront motorsports fuel rails and 16mm phonolic spacers. (can go bigger if you want)
mine is NOT reversed, its a DD so I can keep A/C
nashelton is offline   Reply With Quote
Old 01-16-2014, 12:09 PM   #34
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Where is asf machine. Any update on that kit?
timeXlost is offline   Reply With Quote
Old 02-06-2014, 05:00 PM   #35
AJRX
Member#: 84991
2011 STI
you don't need to lose the A/C if you go rotated manifold, you'll need 8mm-12mm phenolic spacer and notch the alternator bracket to allow for it to sit lower, then you'll clear it with your cool charge piping.
AJRX is offline   Reply With Quote
Old 02-06-2014, 06:34 PM   #36
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
With 8 to 12mm spacers the rails wont clear the head vent tubes. At least they didnt with the 2.0 head vent tubes. I needed 19mm.
fastblueufo is offline   Reply With Quote
Old 02-06-2014, 07:20 PM   #37
outfrontmotorsports
Member#: 220204
We have the rails that are direct bolt-on. The price is $160 and they come anodized black. They are in stock and ready to ship.
outfrontmotorsports is offline   Reply With Quote
Old 05-11-2014, 02:05 AM   #38
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
Just sent you guys an email
Looking forward to your response.
RustyHinge is offline   Reply With Quote
Old 10-02-2015, 01:13 AM   #39
ScoobieSnaks
Member#: 385514
02 WRX
rally blue
Good info
ScoobieSnaks is offline   Reply With Quote
Old 10-04-2015, 08:39 PM   #40
WhatTurboLag?
Member#: 243992
2006 WRX TR
Does anyone have that picture of all the holes and fittings and stuff we can shave off the manifold? Trying to save some money and do it myself.
WhatTurboLag? is offline   Reply With Quote
Old 10-05-2015, 08:15 AM   #41
nitsuj
Member#: 87081
05 PSM STi
05 AW XTi
I spent the time doing it and grinding it down to make it ready for powder coat, it was a lot of time with a carbide burr doing the EGR tube alone, if I could go back and do it all over again, I would send it to someone to do it
nitsuj is offline   Reply With Quote
Old 10-05-2015, 09:25 AM   #42
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
My good friend owns a metal polishing business. He shaved and polised my long runner NA manifold.
cnstman is offline   Reply With Quote
Old 10-07-2015, 12:51 AM   #43
WhatTurboLag?
Member#: 243992
2006 WRX TR
Been working on mine myself, regret it greatly lmao.
Deciding to have someone finish it, and have it ported/honed before powdercoat. Or just have it powdercoated once I am done doing it myself. Stock heads/motor I won't see gains so I'm not sure
Old 10-12-2015, 08:25 PM   #44
outfrontmotorsports
Member#: 220204
We have the rails in stock and ready to ship.
Old 04-01-2016, 02:56 AM   #45
ScoobieSnaks
Member#: 385514
02 WRX
rally blue
Do you still have any of these in stock?
Old 04-11-2016, 01:56 PM   #46
evilfirbolg
Member#: 184796
2001 Impreza RS 2.5
^^^^ what he said. Looking as well. Have emailed Outfront, in fact have several times about various things, never got a response. Sorry, Outfront, I work silly hours in the deep backcountry and don't get the opportunity to call you guys so email how I hafta do things.
evilfirbolg is offline   Reply With Quote
Old 04-12-2016, 07:54 AM   #47
WhatTurboLag?
Member#: 243992
2006 WRX TR
Moore performance has adapters to use regular rails in stock that's the route I went.
Old 04-12-2016, 08:16 AM   #48
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
I contacted Outfront a few days ago. As of then, they have the rails. $160.00 is what I was told. Does not include anything except for the rails.
svynx is offline   Reply With Quote
Old 04-15-2016, 01:50 PM   #49
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
For those of you who are running this mani in the non-reversed mounting position, how much room do you have between the throttle body and the firewall?
Old 08-08-2016, 10:49 AM   #50
DarthFXT
Member#: 448492
2004 FXT
JBP
Did you ever get a response on this one?
DarthFXT is offline   Reply With Quote
What fuel rails do you run on the big plenum NA intake manifold? DSM_Outback Built Motor Discussion 6 11-28-2011 12:48 AM
FS : CA: Brand new JDM STI V7 intake manifold, used Spec C intake manifold orwrx Engine/Power/Exhaust 18 04-05-2011 01:28 AM
What FPR to use with Perrin fuel rails? awd4ever Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-17-2009 12:01 PM
this might be dumb: but would an STi intake manifold fit on an NA 2.5RS? Impreza2003 Normally Aspirated Powertrain 15 06-22-2005 11:58 AM
rallispec intake owners: what do you use to clean your pipercross filter? M a t t General Forum Archive 3 03-07-2001 09:07 PM
