Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 06-21-2019, 12:16 PM   #2876
1qukSti07
Member#: 326585
2007 STi
Originally Posted by Waddlz View Post
Yeah dude, I literally measured nothing. not even the piston rings.
New case halves, Eagle rods, reused 55k mile crank, standard bearings and Manley graded B drop ins.
slapped it together. just crossed 25k miles last weekend.
I was like overboard with measurements building this block. Darton sleeved cases with a fresh line bore, new crank, replaced the rod which spun the bearing (Manley H-Tuff Rods), King bearings, Manley pistons, L19 head studs, built heads etc. etc.
1qukSti07 is offline   Reply With Quote
Old 06-21-2019, 12:19 PM   #2877
1qukSti07
Member#: 326585
2007 STi
Originally Posted by yamahaSHO View Post
I thought I launched hard to get my 1.80 60', which net me a 12.4 on an 8,700 DA day and I wasn't hitting boost. I'll be more than happy if I can knock out an 11-second time up here with my little turbo.
Because oil is getting pushed through our turbo's. There are other references where, I believe BW, states that you can use a restrictor with higher oil pressures.
I went to Orlando speed world which is almost at sea level, launched at 5k
No restrictor here, even with the 12mm pump, and no smoke issues
Old 06-21-2019, 12:25 PM   #2878
Waddlz
Member#: 395275
2012 STi
yeah im building another block because im suprised this one has lasted this long. Going to go closed deck, but unsure on what pistons to go with.
Waddlz is offline   Reply With Quote
Old 06-21-2019, 02:07 PM   #2879
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I never had smoke issues, but I could see some oil leaking out of the bottom of the cartridge, over time. Additionally, I would get a faint burnt oil smell.
I may have had some smoke on cruise after a hard drive, but I couldn't never really make certain while driving up the dirt road to my house at a slow speed.
Running an external oil cooler, probably undersized by my standards, will help keep that pressure at bay.
yamahaSHO is offline   Reply With Quote
Old 06-29-2019, 09:20 PM   #2880
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Waddlz and I went to the dyno yesterday. He wanted to finally bump the power and I wanted to check my tune, which I did in a dyno in Omaha, up at high altitude. I tried some things, but the map I made on the last dyno is what I went back to. My 6758 falls off up top, way up here. It did not help that it was a 90+ degree day. From what I've read, this DYNOmite reads 11-14% lower than a DynoJet, so I am happy with the numbers. Altitude was around 5,5xx ft and about 90F.
Kevin should be faster than me now. He made a good bit more power than me with his 7163. I ran out of WGDC on his car trying to hold 29 PSI. I believe hell be doing a 4-port now. Here is his graph, 19 PSI tapering to 25.
Old 06-29-2019, 09:30 PM   #2881
PDXREALTOR
Member#: 468393
2017 STI
How much psi are you trying to hold at redline?
I couldn't get past 26 pounds @7k with a 24 sprung single port TS WG and hybrid boost.
PDXREALTOR is offline   Reply With Quote
Old 06-29-2019, 09:34 PM   #2882
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
On a 7163?
I'll give it what it takes, but WGDC was maxed out. Hybrid results to an MBC, so it won't have any help keeping the wastegate shut.
Kevin has an EWG, so he won't just blow it open. If it won't hold 29 PSI, we'll take what we can get... But I have a street log holding 27 PSI flat, last year.
Old 06-29-2019, 09:48 PM   #2883
PDXREALTOR
Member#: 468393
2017 STI
Yes - on a 7163. At sea level.
Old 06-29-2019, 09:51 PM   #2884
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
We'll see what it does, but I think it will hold 28-29 up top.
Old 06-29-2019, 10:06 PM   #2885
PDXREALTOR
Member#: 468393
2017 STI
I've been digging through logs since I posted last. You had me curious.
I was wrong with my numbers above - I held 28-28.5 to 7k after the WG spring upgrade. Target was 34. Before the spring upgrade I was at 26 psi / 7k.
Old 07-11-2019, 12:01 AM   #2886
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
On the street, the turbo is holding much better. Also, Kevin does not use both ports on the EWG, so we'll change that after Street Car Takeover this weekend. He should smoke me now.
Old 07-18-2019, 11:52 AM   #2887
Swift2
Member#: 135432
2006 WRX STI Limited
Urban Grey
I’ve been reading this thread with interest as I’m on the hunt for the best performing stock location setup on the market and keep getting drawn back to the EFR7163. I have to stay stock location, TMIC, UEL Headers to meet regulations and annual inspections in Switzerland, where I am. I would like to maximize this setup considering those constraints and have basically been looking at;
Turbokit
Full Race EFR Stock Location kit V band (up/down pipe, headers etc) or BNM Fabrications
EFR7163 0.85a/r (indy style vband in/out housing)
Turbosmart IWG Dual Port or EWG recirculated (efr’s too many problems holding boost)
Block:
IAG Closed Deck Stage 2.5 or Stage 3
Intake:
Spec C intake Manifold
Grimmspeed or Spearco TMIC (paint to look stock STI)
3in Inlet AMR or Perrin 3in inlet
KStech 73mm Intake or APS 70mm
IAG Street Series AOS
Fueling:
ID 1300’s
IAG v2 Fuel Rail
Radium Surge Tank
Walbro 450 E85 pump hardwired
Radium Fuel Pressure Regulator or Aeromotive A1000 Fuel Pressure Regulator
Cobb Flex Fuel Kit
Fuel Filter + -6an fuel lines
Other:
Omni 4 bar map sensor
IAG IAT Speed density kit
12mm Cosworth oil pump
Fuel:
European 98RON and E85
Can anyone provide some criticisms or improvements on this setup? What can I learn from your EFR7163 setups?
Should I aim for any headwork or not? IAG Stage Heads?
Other option would be a Spoolinator with a GTX3067-R or GTX3071 Gen2...
Swift2 is offline   Reply With Quote
Old 07-19-2019, 09:41 AM   #2888
rocklizzard91
Member#: 226287
I am looking at building a setup with the EFR7163 as well for my version 9 EJ207. I think the G25-660 or G25-550 are a bit more comparable to the EFR lineup. Unfortunately there isnt a whole lot of data on them just yet :/
Good call on BNM as well! I just placed an order with him too!
rocklizzard91 is offline   Reply With Quote
Old 07-19-2019, 11:52 AM   #2889
Snow_Shovel
Member#: 344498
The BNM is nice, just hope you anticipate quite a wait. Took me 20 months for my fogturbo kit using the IRL 7163... Itís basically art though so Iím okay about it.
Snow_Shovel is offline   Reply With Quote
Old 07-19-2019, 12:25 PM   #2890
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Check out the Speed Academy channel on YouTube. They put a stroker EJ207 in an 08 STI with a G25-660. They are going to dyno it with both hotside options after break in...so we should have a little bit of data to help our decision making sometime soon.
T-37 is offline   Reply With Quote
Old 07-19-2019, 12:52 PM   #2891
Waddlz
Member#: 395275
2012 STi
A local to me had a G25-660 and he put down 505 whp 480ish wtq at 28 psi of boost on E85. I know its just 1 car, but its something
