Welcome to the North American Subaru Impreza Owners Club Sunday August 18, 2019
Old 02-16-2017, 09:35 PM   #26
bmxhotsauce
Member Sales Rating: (10)
Member#: 127099
02 IMPERZA WRX
BLACK
Originally Posted by [email protected] View Post
Just like anything urethane, rubber or the like. it has a service life. We highly recommend NOT using anything petroleum based to help slide them on as it will shorten the life span. It's also not uncommon for the trans bushings to fail if you are running the car without the factory heat shields.
Normal life is around 5 years +-.
If they do fail and you nicely contact. I'll more than likely take care of you no problem. If you are a dick about it. Then not so much.
Tom
Love the honest truth .. still good **** kartboy!! I hate when people are dicks about small issues .
bmxhotsauce is offline   Reply With Quote
Old 02-17-2017, 12:14 AM   #27
Fierysun
Member Sales Rating: (109)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by Crawlerado View Post
You use Kartboy exhaust hangers on your truck as bushings? Do you have a build thread? In for results.
I have a baggy of the crumbled Kartboy bushings. I replaced all the bushings on my truck about 20 years ago with Energy Suspension polyurethane replacements. This includes shocks, endlinks, swaybar, control arms, spring eye, etc. Not one of them crumbled into little pieces. Not one. All of them are fine and I still have the truck. So I don't buy the 5 year life excuse.
Gotta love people that don't understand when a product is poorly made.
Fierysun is offline   Reply With Quote
Old 02-17-2017, 10:58 AM   #28
Crawlerado
Member Sales Rating: (5)
Member#: 305948
2015 818R
Black and Yellow
So none of those are attached an exhaust that's at several hundred degrees then.
Comparing exhaust hangers to suspension bushings
Crawlerado is offline   Reply With Quote
Old 02-17-2017, 11:14 AM   #29
Fierysun
Member#: 82745
2005 Subaru STI
Sorry you can't read, but his x-member bushing also crumbled to little pieces. Especially when other manufacturers like Cobb and TIC (the non KB ones they sell) as well as OEM doesn't. Yeah, Kartboys bushings are poorly made/designed.
Old 02-17-2017, 11:29 AM   #30
PARANOID56
Member Sales Rating: (44)
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
i have replaced a bunch of energy suspension poly parts, they have all crumbled. mainly where there is a lot of movement, say sway bar endlinks.
+1 for a vendor not afraid to speak the truth
PARANOID56 is offline   Reply With Quote
Old 02-17-2017, 12:27 PM   #31
Fierysun
Member#: 82745
2005 Subaru STI
Funny, Tom said his bushings are petroleum sensitive. Meaning if they come into contact with gas, oil, grease, etc, they break down. Which isn't a problem with other manufacturers.
My energy bushings are still fine after 20 years. Maybe they were properly installed.
Also, it helps no one (including the manufacturer) to cover up and/or stick up for a poorly made/designed product.
Old 02-21-2017, 08:47 AM   #32
cmiovino
Member Sales Rating: (22)
Member#: 134005
2004 WRX Premium
For what it's worth, I've had the Cobb hangers installed over 6-7 years, up to 110 degrees, down to -10 degrees, and about 50k miles including autocross and they're holding up just fine.
I didn't install them, previous owner did, so no idea if any lube was used installing them.
Old 04-28-2019, 08:57 PM   #33
goodolmrwilson
Member Sales Rating: (1)
Member#: 490063
2004 WRX
JBP
Originally Posted by dLo R6 View Post
thought i'd bump this thread to PSA that hangers snapping after a few years is not uncommon - happened to me last night while it was parked (luckily not while I was driving). about 7 years old. don't remember how I installed them but it was a new exhaust.
My kartboys snapped as well after about 6-7 years also in the parking lot of my job. i did call kart boy submitted photos and they send new ones out to me. for the price after a few years i would care to be honest but good to know they stuck behind such a cheap part. it was crazy to see all 4 hangers and my exhaust on the ground
__________________
Sorry for digging up a year+ old thread, but this was all i could really find. I just had all 4 of mine snap in the driveway overnight, luckily the 3 day old Invidia exhaust was saved! Did I install wrong? I used white lithium grease, so I can't imagine that was a cause for failure. There is a good amount of tension in the middle hangar, so I guess it may have needed a longer one there, but the other 3? I have just replaced all 4 with factory stock ones, and they don't' seem too tensioned. I'm afraid if i use all long hangars, it will hang too low.
goodolmrwilson is offline   Reply With Quote
Old 04-29-2019, 11:56 AM   #34
Fierysun
Member#: 82745
2005 Subaru STI
__________________
Unfortunately, KB bushing formulation is very poor and disintegrate after a short period of time (compared with other bushing manufacturers) .
Old 05-16-2019, 10:54 PM   #35
Atate489
Member#: 501699
Iíve had no issues with the Cobb hangars. Put them on 2 years ago when installing Cobb turbo back. Works like a charm
Atate489 is offline   Reply With Quote
