Welcome to the North American Subaru Impreza Owners Club Friday August 23, 2019
Old 04-29-2017, 09:55 AM   #101
Tickled Rage
Member#: 403930
Man I'm envious! Outstanding commitment my friend! I am picking up an 04 2.5 TS today. I bashed my front end in on my 05 wrx wagon similar to the 07 donor you have. Not gonna be able to do the amount you have, but my motor is ending up in the TS for sure. Hope to see spring bring you to a great conclusion!
Tickled Rage is offline   Reply With Quote
Old 05-06-2017, 10:30 AM   #102
sebwrx
Member#: 467171
Which ecu did you use when swapped?
sebwrx is offline   Reply With Quote
Old 06-23-2017, 10:06 AM   #103
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Hey thanks man, i have been doing some projects around the house. It has been super hard to get back to finishing it up, and i am so close. Hopefully this summer i can squeeze it in. Sorry for not noticing your post sooner
slowgenius is offline   Reply With Quote
Old 06-23-2017, 10:09 AM   #104
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I also apologize for such a late reply, I currently have the 07 wrx ecu and wiring harness in the car. At a later date i may try to run the vipec and built davcs engine. At this point i just want to get the thing running and enjoy it a bit first.
Old 06-16-2019, 12:46 AM   #105
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Back from the dead. I had some help to install the ej255 engine and my old act clutch and flywheel from the ej205. We got the radiator in and plumbed, a vf turbo from an sti, i forget which turbo it is. I still have a ways to go. I will update with pics and more details to come.
Old 06-16-2019, 12:52 AM   #106
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I'm on a search for a driveshaft for this six speed swap. I believe the one i need is the sti one, the two sets of wrx driveshafts are to long, and the bit about i must have tossed them out some time ago. How do you loose two whole driveshafts anyway? The distance between the output of the transmission and the input of the differential flange is 55 inches. Since the shaft goes into the transmission a few inches its total length is longer, and the service manual only gives the joint to joint length.
Old 06-17-2019, 09:08 AM   #107
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
So i talked with an ebay parts shop an they recommended based on my transmission and differential, to use the sti v7 (MY02-03) driveshaft. Go figure. I should have it in about a week and a half.
Old 06-25-2019, 10:37 AM   #108
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Driveshaft is in, i need the bushings for the carrier bearing, they weren't supplied.
Old 06-26-2019, 03:13 PM   #109
Paincakes
Member#: 468610
Dang, this is turning out great! Can't wait to see the finished product.
Paincakes is offline   Reply With Quote
Old 06-26-2019, 05:04 PM   #110
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Thank you! I have to thank my wife for putting up with me all these years with this car.
Old 07-02-2019, 05:35 PM   #111
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Small update, i ordered some coilovers to replace the tired original struts. The front top hats had cracked as well from sitting.
ISC Suspension N1 Street Sport
Old 07-07-2019, 08:30 PM   #112
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Today i was able to get the driveshaft installed mostly. It did not come with the bushings for the carrier bearing in the middle. They are not serviceable says the stealership, so i found some billet aluminum ones that are way overkill.
I also had help to separate the turbo exhaust housing and replace it with a new one. The old one had a huge crack in it, not the hairline one usually on the wastegate.
Then i wrapped my header, uppipe and downpipe with heat wrap. The header and up pipe were already ceramic coated but i am worried about melting my undertray and all the wires and hoses near the downpipe now.
Old 07-07-2019, 08:35 PM   #113
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
My ISC suspension is in, i hooked up all the oil and waterlines on the turbo, the upper coolant tank and radiator. I still have the vaccum and breather hoses to do along with hooking up the pipes for the front mount interfooler.
The air intake also needs put on. Then i can flush the fuel system and hook it up to the engine fuel rails.
I think I am getting close to being able to try and start the car.
Old 07-07-2019, 08:40 PM   #114
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Old 07-07-2019, 08:41 PM   #115
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Old 07-07-2019, 08:41 PM   #116
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Old 07-07-2019, 08:44 PM   #117
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Old 07-07-2019, 08:46 PM   #118
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Will leave more updates soon.
Old 07-08-2019, 04:36 PM   #119
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Old 07-08-2019, 04:47 PM   #120
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
These are so nice, too bad I wont ever really see them again hopefully.
Carrier Bearing support bushings.
Old 07-15-2019, 07:25 AM   #121
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Nice. I see you opted for the camber plates
no694terry is offline   Reply With Quote
Old 08-08-2019, 01:00 PM   #122
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Yes I did!
