Welcome to the North American Subaru Impreza Owners Club Monday August 26, 2019
Old 01-05-2015, 10:27 PM   #1
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Default Barigas 07 STI LIMITED EFR7670 E85 Gas
Making a new post the old one is cluster ****.
Simple and functional setup:
Outfront closed deck block
1/2 ARP2000 studs torque to 100
+2 mm Saenze "Doms tuff" rods with JE OTS pistons
Ported heads with +1 mm Ferra valves/dual-springs and Kelford 264/260 10.70mm/10.20mm Lift
King bearings
JE Head gaskets
Fullrace 7670 Twin Scroll IWG turbo kit with Turbo Smart WG actuator
Thanks to Geoff @ Fullrace for support on boost issues, turbo smart actuator makes me hold flat boost to red line from 20 - 28 psi
APS FMIC using EFR internal BOV
ID 1300cc Injectors on WB 465 Intank pump Teflon -8 feed and -6 return FuelPRO pump controller
Vipec V10 ECU with Flex fuel sensor
This thing is scary to drive on E85
On 92 Oct i get around 420 whp @ 20 psi
This pulls are done on road that a bit uphill,
E80 @ 23psi
E80 @ 26psi
Bariga is offline   Reply With Quote
Old 01-05-2015, 11:35 PM   #2
VladiWrX
Member#: 145658
On my 10th scoob
and lovin it
wow, that power band is nuts. congrats
VladiWrX is offline   Reply With Quote
Old 01-06-2015, 12:43 AM   #3
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
i don't know if the numbers are real but it pulls hard to redline, i will do more pulls later @ 28 psi that will be max for this fuel system.
Old 01-06-2015, 12:48 AM   #4
VladiWrX
Member#: 145658
On my 10th scoob
and lovin it
any chance the road wasn't straight/level? it's odd how the power/torque jumps up toward the end.
either way, that's a ton of power and torque
Old 01-06-2015, 12:56 AM   #5
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
If only they'd made that Limited in a wagon. Beautiful machine.
Dave D. is offline   Reply With Quote
Old 01-06-2015, 06:17 AM   #6
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
holy ****
user1029 is offline   Reply With Quote
Old 01-06-2015, 07:18 AM   #7
Kiahatsiu
Member#: 406927
AFR goes leaner at the same point, so that is probably linked to the power increase.
Kiahatsiu is offline   Reply With Quote
Old 01-06-2015, 07:40 AM   #8
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Not really...goes lean then richer where theres the HP/TQ increase.
Im guessing its the road also
OP: Does it spool like you expected?
Old 01-06-2015, 10:54 AM   #9
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Old 01-06-2015, 02:46 PM   #10
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Wow, great results!!
I've seen a dyno sheet like that when there is a dip in the (straight) road. Regardless, that's a heck of a graph! Needs more rpm
wgr73 is offline   Reply With Quote
Old 01-06-2015, 10:13 PM   #11
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Updated the road dyno sheets,
At 26 psi my injector duty is almost hitting 100% and WG duty cycle is at 100% as well, also i don't think this turbo has any more juice in it.
I really like the quick turbo response and that it hits 500whp, i will never trade that for more lag.
Old 01-06-2015, 10:17 PM   #12
Wolfie_OBXT
Member#: 364484
2006 OBXT
That's pretty damn solid man... Good job!
Wolfie_OBXT is offline   Reply With Quote
Old 01-07-2015, 09:56 AM   #13
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Cant beat the spool vs whp, awesome!
Old 01-07-2015, 11:27 AM   #14
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Thanks guys, spent tons of time tuning this thing still cant beat stock ecu wish COBB would get off their asses and develop flex fuel system.
Old 01-07-2015, 11:57 AM   #15
JoshFiricano
Member#: 317193
2013 WRX Premium
VERY nice!
JoshFiricano is offline   Reply With Quote
Old 01-07-2015, 02:40 PM   #16
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Nice #'s man.
I probably won't be back on the road for 3-4 months.
Old 01-07-2015, 03:33 PM   #17
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Today on wet road I span all wheels in 2nd gear, that's crazy.
What's going on Kelly?
Old 01-08-2015, 12:51 AM   #18
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Well since I determined my car was pushing coolant in October my mother passed away, my father had his left lower leg amputated, I moved and I recently quit my job. The Subaru was the last thing on my mind but I'm back working on getting it back on the road now. No hurries though.
Old 01-08-2015, 09:41 AM   #19
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Very nice. Maybe you should look into the Syvecs ECU.
west_minist is offline   Reply With Quote
Old 01-08-2015, 10:21 AM   #20
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Sorry to hear that Kelly, that's tough. Hang in there man, things will get better.
Old 01-08-2015, 04:44 PM   #21
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
After Vipec everything is a downgrade except motec lol
Old 01-08-2015, 04:50 PM   #22
west_minist
Member#: 53451
w/ AVCS Silver
It is not a downgrade and thr vipec is not even in it class. In some quarters, one could argue even better than motec. Read roger clarke motors reference to his moving away from motec.
The syvecs is a life racing device.
Old 01-08-2015, 06:01 PM   #23
yazel
Member#: 215344
tasty
yazel is offline   Reply With Quote
Old 01-09-2015, 12:11 AM   #24
ree666
Member#: 410494
2011 Sti
World Rally Blue
beautiful
ree666 is offline   Reply With Quote
Old 01-09-2015, 01:07 AM   #25
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
i came from AP v1, AP v2, Hydra 2.5, Hydra 2.6, AEM V1, Vipec lol
Vipec is best so far! easy interface and great support documentations with examples for noobs.
