Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 01-24-2019, 01:00 PM   #26
Stija
Member#: 492861
18 WRX Stg 2 tuned
Is this as simple as take old one off and this on (on MY18) or are there things to watch for during install?
Stija is offline   Reply With Quote
Old 01-24-2019, 01:08 PM   #27
anarekist
Member#: 468117
2017 WRX
DMG
anarekist is offline   Reply With Quote
Old 01-24-2019, 01:09 PM   #28
anarekist
Member#: 468117
2017 WRX
DMG
Old 01-24-2019, 01:11 PM   #29
Stija
Member#: 492861
18 WRX Stg 2 tuned
I enjoy watching lasthumansgarage more as a show than how to do things properly because it usually takes him two to three tries and he doesn’t cut out the fails, which is what makes it watchable as a show.
Thank you. Are you running one too?
Old 03-08-2019, 02:07 AM   #30
Arodsti
Member Sales Rating: (1)
Member#: 498769
2011 WRX STi
Great write up, I want one now!
Arodsti is offline   Reply With Quote
Old 03-31-2019, 08:03 PM   #31
SpeedHoles
Member#: 339900
So, does this still require cutting timing cover for clearance on a 2015+ STi/EJ257?
Or was that only in older models?
SpeedHoles is offline   Reply With Quote
Old 03-31-2019, 08:21 PM   #32
PDXREALTOR
Member#: 468393
2017 STI
yes it sure does. Really easy to do though....
PDXREALTOR is offline   Reply With Quote
Old 04-06-2019, 01:03 PM   #33
Fierysun
Member Sales Rating: (109)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I have both ATI and Fluidampr and you don't have trimming issues with the ATI as well as needing a puller to remove it. My assessment of both products is, ATI is race and Fluidampr is for consumers.
Fierysun is offline   Reply With Quote
Old 04-07-2019, 11:22 AM   #34
Bariga
Member Sales Rating: (33)
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
installed mine in when i did the engine build, noticed 0 difference from stock
Bariga is offline   Reply With Quote
Old 04-07-2019, 01:38 PM   #35
Fierysun
Member#: 82745
2005 Subaru STI
Then you should've taken a closer look.
Old 04-09-2019, 11:19 AM   #36
kenliu84
Member Sales Rating: (49)
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
I purchased this pulley almost a year ago and finally got around to installing it. I did my belts while I was at it. My car is an 06 WRX wagon with STi trans.
Installation
It should’ve been a lot smoother but as all things go with modding the car, it became slightly of a pain. For all EJ engines, at least 2002-2007, the center timing cover needs to be trimmed. At first, I wanted to remove it but I had so much trouble just trying to remove one of the rusted bolts that I decided to trim it without removing it. I had to remove the passenger side fan in order to get my dremel tool in there with a rectangle cutoff blade. I put some painters tape on the inside of the “ring” and went at it carefully with the dremel keeping the blade flat against the cover and using all sorts of blade angles to get around the ring. It was a plus that my dremel had a variable trigger.
I don’t know about you guys but the pulley was an extremely tight fit. Even just to get it initially pressed on was a pain. And because of this tight fit, it was not easy for me to align the “tooth” with the opening in the pulley. I had to make marks on the pulley to better eyeball it, then tighten the bolt slowly to see if it went in properly. It took me about three tries before it aligned properly.
No special tool was needed, I just kept the car in 6th gear when I was tightening to spec.
Smooth is the best way to describe my initial impressions. The engine idles a lot better cold or warm. The car seems to rev a lot faster or smoother when you really get on it. I noticed this when I was at an highway on ramp that had a stop sign. I went through gears 1-4 at full throttle and I was amazed at how much faster the car seemed to rev and how the car jerked around a lot less when shifting. The car always seemed to sound and feel like it was falling apart when I did this kind of driving previously and I thought it was just the nature of the beast but this fluidampr pulley is making a huge difference in how smoothly the engine runs. It just feels so much calmer all around. Cruising on the highway is also quieter but not by much. I had a friend in the car and I didn’t tell him I did anything. He told me how the car felt a lot smoother all around during the drive.
I definitely recommend this pulley for those who are currently running either stock or a lightweight pulley. I’ve known of a few stock pulleys that have failed when the cars were running a decent amount of power. My friend’s forester was just running stage 1 at 80K miles. The outer metal sheared off from the inner part of the pulley mounted to the crankshaft. Then the outer metal started eating into the timing cover and we caught it just in time before it did any serious damage. A new stock pulley is just roughly half the price of a fluidampr. Factoring in the cost, I think it would be well worth it to upgrade from a stock pulley. As with everyone else’s reviews going from LW to this pulley, you can recoop some of the cost by selling the LW one. Nothing wrong with just running your LW one if you’re not convinced. But if you are, you can wait like I did and do it when you do your belts.
kenliu84 is offline   Reply With Quote
Old 04-09-2019, 09:30 PM   #37
Fierysun
Member#: 82745
2005 Subaru STI
Yeah, the fit of the Fluidampr sucks, but the ATI fits like OEM. The performance is the same on both. I couldn't tell the difference. I would recommend ATI over the Fluidampr.
Old 04-13-2019, 06:52 PM   #38
Rexy18
Member#: 500337
Seems like an interesting upgrade and also easy to install, am i missing something or is it just damper off dampr on?
Rexy18 is offline   Reply With Quote
Old 04-14-2019, 01:42 AM   #39
Fierysun
Member#: 82745
2005 Subaru STI
Yes for the ATI, not the case with the Fluidampr.
Old 04-14-2019, 09:36 AM   #40
violentleaf
Member#: 432126
2015 WRX
Galaxy Blue
It is for the fa20
violentleaf is offline   Reply With Quote
