Welcome to the North American Subaru Impreza Owners Club Saturday August 17, 2019
Old 01-21-2017, 09:01 PM   #26
Juice66
Member#: 340526
2004 WRX STi
HTA86
Originally Posted by WhatTurboLag? View Post
What is the advantages of doing a 1/2" stud over a 625 on a non closed deck block?
Currently doing a "budget" build to get the car up, and a closed deck is unfortunately an extra 1500 I cannot spend. But o ringing the stock block and 625 or 1/2" studs I would do if it made sense.
75 lb/min turbo.
Clamping force. A 625 stud should hold everything a 75lb/min can offer if your tuner is worth a $h|t
Juice66 is offline   Reply With Quote
Old 01-21-2017, 11:05 PM   #27
WhatTurboLag?
Member#: 243992
2006 WRX TR
Yep he is a good one for sure.
Would o rings help on a non closed deck block? Or the increased clamping force "stiffen" the cylinder bores?
Seems 625's as planned is my best bet and might o ring it for redundancy.
WhatTurboLag? is offline   Reply With Quote
Old 01-22-2017, 12:36 AM   #28
Juice66
Member#: 340526
2004 WRX STi
HTA86
Sounds more like a budget build than anything, although a good one. My H11 studs held 32psi on my HTA86 just fine with E. You should be good to go with what you have. Skip the o ringing, imo.
Old 01-22-2017, 01:16 AM   #29
WhatTurboLag?
Member#: 243992
2006 WRX TR
Right now, the block is the fuse it seems.
2011+ crank
H tuff rods
Orbit pump
King bearings
Stock 06 WRX heads
Turbo tuff Pistons.
Stock 200k mile 701 casting block (bores look good still, I believe in well seasoned blocks) no current block mods planned
625 head studs
Haven't decided on head gasket.
Old 01-22-2017, 10:31 AM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
IMO o-rings are pointless unless you sleeve. Squeezing an o-ring between two soft materials just does not apply enough squish to the o-ring. High power builds have even tried multiple o-rings on closed deck blocks, and they still fail (although they are also pushing high cylinder pressures).
I think Juice is on track with the no o-ring recommendation.
Pay close attention to the head gaskets surface requirements specs, torque procedures, and if you want to go an extra step (which almost no one does), re-torque after break-in.
KillerBMotorsport is offline   Reply With Quote
Old 06-28-2019, 05:05 PM   #31
grangepack2
Member#: 428757
1994 Impreza v9 207
Originally Posted by primetime2123 View Post
if the 625+ pulled at 18 psi your builder put the block together wrong. i have had the regular arp at 30 psi with no issues
at what HP?
grangepack2 is online now   Reply With Quote
