Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 05-16-2018, 12:50 PM   #51
kcinsparks
Member#: 154608
Chapter/Region: HIIC
2004 Sti
Damn! Hey I bet it was worth it! And yeah if my wife knew what I spent on my car she’d probably spaz a lil bit too haha
kcinsparks is offline   Reply With Quote
Old 05-16-2018, 06:02 PM   #52
Nib
Member#: 472886
2013 WRX Spoolinator
Heading to Houston Wednesday to drop the machine off..
Whiteline rear controll arms and a tune and I will be complete.
Just need to install my Cryo2 sprayer and I think I will be done.
Nib is offline   Reply With Quote
Old 05-27-2018, 01:59 AM   #53
Nib
Member#: 472886
375hp/[email protected] psi on 93
488hp/[email protected] psi on e85
Mustang Dyno
This is just what Kosmic Motorsports posted on Facebook.
Old 05-27-2018, 06:19 AM   #54
kcinsparks
Member#: 154608
2004 Sti
Damn nice! I’m at home listening to the cars racing around on the freeway every so often. I bet this thing rips on the street!
Old 05-27-2018, 09:27 PM   #55
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Mustang Dyno
What were the limiting factors? These numbers are really low, so I'm assuming there was an issue, or this dyno reads super super low.
KillerBMotorsport is offline   Reply With Quote
Old 05-27-2018, 09:37 PM   #56
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
IIRC, Kozmic's dyno is a "normal reading" Mustang dyno, so those numbers are way low. He should be doing 440-450 whp with 22 psi on 93 octane.
How was the EWG plumbed back? If it was really sharp, that would hold things back. I can see the car losing 30-40 whp with a poor plumb back design.
ShinjiML is offline   Reply With Quote
Old 05-28-2018, 08:45 AM   #57
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'd say 20-30 getting away from UEL and another ~20-ish dumping the WG to atmosphere on 93. Close to double those figures on E85 as those power levels are really going to start becoming a major bottleneck on a 3" (which is less than 3" I.D.) closed exhaust.
Fun to speculate, and we'll likely never know... or bring it over to my place, we've got a brand new Mustang, we can compare
Old 05-28-2018, 03:55 PM   #58
Nib
Member#: 472886
Default I
I may take a road trip
Old 05-28-2018, 03:56 PM   #59
Nib
Member#: 472886
Pm me Killer Bee
I’ll send some pics of the plumbing.
Old 05-28-2018, 07:43 PM   #60
Nib
Member#: 472886
Don’t forget,I went with 1300s.
This is what I thought you used to achieve nearly 600 whp.
I do not know the details of the dyno pulls. I bet I ran out of fuel.
I’ll know details tomorrow.
Old 05-28-2018, 09:07 PM   #61
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Thanks for contributing to the thread, curious to see more details of your tuning session and maybe even some video if you recorded.
I'm using 2000cc injectors, the tuner was confident they would tune well, just have to make sure the exhaust and intake paths are as free as possible. If/when she's up and running and I have a primary tune, I may be headed to DD to get a legit catback fabbed.
2slofouru is offline   Reply With Quote
Old 05-29-2018, 03:31 PM   #62
blurred
Member#: 47143
You can do the math with how much fuel you used and afr to determine roughly how much power you should be making, regardless of dyno.
I haven't seen any consistent mustang dynos around, but as a comparison with an old school gt3076 on a stock savcs motor (headers/big dp/exhaust/fmic) we made 480whp/380wtq on 94oct at 25psi and 420whp/320wtq at 22psi on both dynapack and dynojet so that is why your numbers seem low. But if you are using the fuel required to make ~550whp on e85 and ~440 on 93 then you're fine.
1300cc will be plenty.
And... ALWAYS be present during dyno tuning of your vehicle!
edit:
Now that I think about it I think your tuner capped your revs at around 6500 for some reason. He should have been revving to 7000-7500 as he decided to limit torque in the midrange. Doing this requires maintaining that torque into a higher rev range to make the proper amount of power. By keeping your revs low and your powerband in the midrange, but with lower torque left a lot of power on the table. If he was scared of revs you should have your midrange torque bumped up to compensate which will increase hp as well, but in a smaller powerband.
blurred is offline   Reply With Quote
Old 05-29-2018, 04:51 PM   #63
Nib
Member#: 472886
I was unable to witness the dyno run due to me living 400 miles away
When I get a call back from David, I will ask for the graph to be sent and ask some questions.
Any suggestions?
Thanks.
Old 05-29-2018, 05:33 PM   #64
blurred
Member#: 47143
Any suggestions?
Thanks.
A guy just drove 1300miles to have my friend tune his car. He made the same trip a couple of years ago with a different setup. Its important to be there
Old 05-29-2018, 05:38 PM   #65
zugu
Member#: 77863
2013 WRX
Unfortunately I don't have a 3576 log, only 3067 (which spooled better than stock). Here's the pump 93 with the 3576 Gen I
[IMG]...[/IMG]
Here's the E85
[IMG]...[/IMG]
What turbine housing was this on? (.63 or .82)
zugu is offline   Reply With Quote
Old 05-29-2018, 06:13 PM   #66
Nib
Member#: 472886
Couldn’t be there.
Old 05-30-2018, 08:17 PM   #67
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
0.82
The 0.63 was used previously, but left a ton of power on the table. In hindsight the 0.63 should not ever be considered for the EJ25 unless your running a restrictor class (which you'd never do with this turbo), or at altitude. If I were to do it again, I may consider using the 1.06 A/R.
Old 06-06-2018, 03:37 PM   #68
Jered
Member#: 50957
2010 WRX STI
Spoolinator 3076 with a .60 housing
396/347 on 93, limited by mass air.
Jered is offline   Reply With Quote
Old 06-06-2018, 04:32 PM   #69
zugu
Member#: 77863
2013 WRX
^^^ Graph? Turbine size? Mods?
Thanks
Old 06-06-2018, 11:09 PM   #70
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Thanks
+1 and maybe some under hood pics.
I tinkered with the coolant and oil lines today, purchased a coolant straight nipple for the rh turbo outlet and keeping the supplied upward banjo on lh inlet. The oil drain is spot on, easy hose connection. I'm going to use a rh facing banjo oil inlet fitting on top, and run it to the right. May use a shorter oil feed hose to the subaru banjo to head fitting.
Old 06-07-2018, 02:29 PM   #71
Jered
Member#: 50957
2010 WRX STI
IAG Stage 2 Tuff
Stock heads, cams
Grimmspeed top mount
Killer B Spoolinator w/GTX3076R
Killer B 3 inch downpipe
Custom fabbed up pipe
Invidia R400
AEM Intake
Old 06-07-2018, 02:35 PM   #72
Jered
Member#: 50957
2010 WRX STI
Thanks
Old 06-07-2018, 08:08 PM   #73
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Nice, so are you running VTA no pcv?
Old 06-07-2018, 09:20 PM   #74
Jered
Member#: 50957
2010 WRX STI
Yes, full flavor Rotella air freshener.
Old 06-07-2018, 09:56 PM   #75
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I'm thinking of using my perrin aos in a combination vta setup, since it will be map based. May go back to using a venturi vacuum source on the exhaust, instead of going in front of the turbo. Won't burn the fumes but will substantially decrease oily vapor coating the intake side. Hopefully the catback setup extends far enough past the bumper to prevent a lot of buildup on the bumper cover.
