Welcome to the North American Subaru Impreza Owners Club Friday August 23, 2019
View Poll Results: Which repair option
Replace gaskets 0 0%
Replace gaskets and use timeserts and/or o-ring 2 20.00%
Outfront closed deck 1/2 inch studs case halves 8 80.00%
Voters: 10. You may not vote on this poll
Old 06-28-2019, 08:06 AM   #1
Atheba
Member#: 352783
Default Advice needed - another pushing coolant at 700+ whp thread
Heya,
So I need some expert advice on what to do.
Car details:
2007 Subaru STi
BW 9180
Golden Eagle sleeved block & no o-ring
720 whp @ 7000rpm on e85 29psi boost 5750 ft above sea level
ARP 625+ studs
History:
From day one the car was pushing coolant into the overflow. There were a few areas that I have fixed that were leaking. Replaced the wg return line that had a slight tear in it. Replaced the radiator cap + drain plug.
The car also had some fueling issues that I sorted out. The oem fuel controller was initially used on the lift pump and after a short while fuses started to blow. I bypassed the controller so that the pump is hard wired. The two main pumps are running in a radium engineering surge tank with the second pump triggered to run above 0.8 bar boost. The second pump was hard wired but I decided to move this onto the secondary controller that is used by the first main pump. Fuel issues seem to be sorted at this point but I have ordered a fuel pressure sensor that will be monitored by the ecu going forward.
I also had some misfire issues and replaced the coil packs with the okada units. Misfires have been sorted.
Problem:
The car was initially pushing a slight amount of coolant and this has become a bit worse at this point. I suspect the head gasket has gone after the fuel related issues. Car still runs great and pulls strong but I havent had a chance to check power output on the dyno. Car doesn't overheat and stays below the half mark on the gauge. I am running without a thermostat so this might be keeping temps in check. Coolant doesnt bubble at idle or when car is revved but I can smell fuel in the radiator and the overflow has what looks like fuel residue.
I am most likely going to need to get the motor pulled and gaskets replaced at a minimum. I'm unsure if the initial pushing coolant was caused by water leaks or heads lifting. What is my best option? Id hate to replace a gasket and have the same issue a couple of months later.
Option 1:
Replace gaskets
Option 2:
Replace gaskets and use timeserts and/or o-ring for additional sealing strength
Option 3:
Order outfront closed deck 1/2 inch stud case halves and transfer my rotating assembly
I'm stuck between options 2 & 3 and would appreciate help from folks that have dealt with these issues.
Thanks.
P.s. I initially planned to turn the boost up another 5 psi but am probably going to leave the car at this level as I want to start with another build next year.
Atheba is offline   Reply With Quote
Old 06-28-2019, 07:26 PM   #2
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
IAG closed deck with 1/2" Head studs and Firelock Headgasket. I love to see you push coolant after that
user1029 is offline   Reply With Quote
Old 06-29-2019, 03:10 AM   #3
Atheba
Member#: 352783
The Outfront block is the same? I have 99.5 pistons currently. The IAG only comes in a 99.75 bore?
EDIT: My mistake - I see they have their own firelock HG.
Whats your experience with this? Also, pinned mains? Are they worth the extra spend?
Old 06-29-2019, 09:12 PM   #4
kp05sti
Member#: 80973
You don't need to replace the case halves to do half inch studs. Last I checked outfront has a kit to install the studs yourself OR you can send them your case to be machined for the studs. If you do a new case you will need to reset your main bearing clearances. You will also need to machine your heads for the studs either way. If it were me Id go outfront CD and half inch studs since thats what I am running right now at 700+whp with no issues.
kp05sti is offline   Reply With Quote
Old 06-30-2019, 10:56 AM   #5
user1029
Member#: 57064
2008 STi IAG built
I have pinned mains, 1/2 studies, oring gasket. I haven’t pushed a drop of coolant at 38psi for the past 40k miles
Old 06-30-2019, 02:48 PM   #6
Atheba
Member#: 352783
Logistics is a bit of a problem - Im in South Africa and getting new case halves might be more economical than sending mines for machining. I'm going to find out from the tuner about getting these installed locally. I want to be certain that the machine work will be up to scratch.
Would I be able to get away with o-rings only? How critical is pinning the mains at this power level? Do you have pinned mains & o-ringed block?
With heads lifting will there be a noticeable power loss? At the moment the car runs great and feels strong. Also there is no overheating - I need to get the coolant system pressure tested as a start.
Old 06-30-2019, 02:53 PM   #7
Atheba
Member#: 352783
That is impressive! Speaks volumes for IAG's work.
What has me worried is that the oem cylinder liner is still used with the CD inserts and you can run into a problem like this.
Also not forgetting the 1/2 inch studs pulling threads issues that people have experienced.
As much fun as the car is at the moment - I'm considering replacing gaskets and torque limiting the motor to 500 ft/lbs. I want to start a build with a 6 cylinder and would like to move on to my next project.
Old 06-30-2019, 02:56 PM   #8
Atheba
Member#: 352783
I see IAG recomends 99.75 bore on their case? Is this the same with the Outfront case? Or could I use my 99.5 with new rings and a hone + set main bearing clearances?
Old 06-30-2019, 03:55 PM   #9
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I believe the 99.75 bore is because they have to account for boring and/or honing after the close deck process, with torque plates applied. You can't just close deck the block and leave the original 99.5 bore and expect it to be spot on. There will be dimensional changes to the inner bore, up top where the close deck inserts have been pressed in.
My guess at your power level is that stainless o-rings and new gaskets would do the trick. Not sure why all the expense of a completely new case would be needed...you already have a sleeved case. Just get the o-ring work done, and have your block honed with torque plates. Then you will have a proper seal and boost will never be an issue.
If you 1: lived in the USA, 2: didn't have a block at all, 3: yours was destroyed by a pissed off piston rod, or 4:just felt like throwing the money you've spent on your current case away...then buying an Outfront or IAG close deck converted block would be a great option.
2slofouru is offline   Reply With Quote
Old 06-30-2019, 04:02 PM   #10
Atheba
Member#: 352783
I agree with this - Any need for the 1/2 inch headstuds? The block will have to come apart and go for o-ring machine work.
Old 06-30-2019, 04:13 PM   #11
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I would get 13 or 14 done, if you're already doing the o ring work. The larger OD of the studs will spread the threads load out and be less likely to pull. Pinned mains would be a good idea as well, since it will all be bored and honed in one trip. Keeps you from wishing you'd done it later on if/when you decide to go bigger on the turbo and injector end. Just opinion based on what I've seen here over the years, but there are always blocks and turbos for sale...because people decide to go bigger. Already running sleeves, your block doesn't need much more to be at the top end.
Old 06-30-2019, 04:29 PM   #12
Atheba
Member#: 352783
Thanks. This is some good advice. I'm going to speak to engine builder and tuner and see what options I have.
Old 07-01-2019, 11:25 PM   #13
user1029
Member#: 57064
2008 STi IAG built
I had the same concerns going big studs and closed deck but then I remembered that IAG defies physics with their engineering
Old 07-02-2019, 05:34 AM   #14
Atheba
Member#: 352783
I'd swear that you are a sales rep for IAG. lol.
Old 07-02-2019, 05:36 AM   #15
Atheba
Member#: 352783
On a side note - HG or heads lifting would always have a loss of power when on boost resulting in overheating thereafter?
I have none of this but coolant is missing?
Old 07-02-2019, 11:23 AM   #16
TDagen
Member#: 163648
V9 6mt R180 Brembos
My engine never overheated with the heads lifting, but it would blow the coolant overflow cap right off and spray coolant out. Like you, I also never noticed any type of power loss.
TDagen is offline   Reply With Quote
Old 07-02-2019, 04:23 PM   #17
Atheba
Member#: 352783
Ok thanks. I'm going to trawl through my logs and check if I can spot anything. Boost/manifold pressure would probably go flat at a certain point in this scenario?
I think I need to also re-check my entire cooling system setup:
1. Overflow is deleted.
2. My turbo tank is deleted - hence no water is being drawn back into the system from the overflow.
3. My heater core is bypassed but it looks like the return line for this has been deleted i.e. the one that supposed to run to the water pump. It looks like the feed line is used to fill a vw coolant bottle.
Is there an online resource where I can check every coolant port on the block /head and where they supposed to route to? And the coolant manifold?
Old 07-03-2019, 10:58 AM   #18
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
I doubt you'll see anything boost wise in the logs that will show the HG issue. Coolant temp is probably the only sensor that might help. Might be worth looking into a coolant pressure sensor in the future which will show the HG failing.
coolant diagram
https://forums.nasioc.com/forums/sho....php?t=2794899
Old 07-03-2019, 02:11 PM   #19
Atheba
Member#: 352783
coolant diagram
This is a useful idea - I've got a pressure sensor and an arduino laying around. Will put something together to view this on the laptop to confirm.
How much of a spike in pressure should I be looking at to indicate hg failure/heads lifting?
Old 07-04-2019, 09:55 AM   #20
Paul
Member#: 56203
00 RSTI Coupe
You’ll have to do your own testing most likely since I assume everyone’s readings are different. I’d hook the sensor up, do some logging to see what’s “normal” then set a safety a little bit higher
Old 07-04-2019, 03:04 PM   #21
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I'm guessing an abnormal fluctuation would be rapid spikes in the realm of milliseconds, whereas normal would be a slow rise/fall in spans of seconds.
Why are you not using a radiator cap and reservoir that would allow excessive pressure to vent and be reclaimed during cooling? This would also ensure air is eventually thoroughly purged (assuming no headgasket or external system leaks).
Old 07-04-2019, 04:37 PM   #22
Atheba
Member#: 352783
Makes sense - I would expect a sharp rise above the radiator cap rating on boost.
This is unintentional. Im going to switch this to the oem setup. And I am going to run the 1.3 bar radiator cap as I have the aluminium radiator.
Old 07-04-2019, 04:39 PM   #23
Atheba
Member#: 352783
I'm going to run this on the ecu after my testing.
Old 07-05-2019, 10:45 AM   #24
1qukSti07
Member#: 326585
2007 STi
What head studs are you currently running?
1qukSti07 is offline   Reply With Quote
Old 07-05-2019, 12:51 PM   #25
Atheba
Member#: 352783
The ARP 625+ stock sized studs.
