Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 07-13-2019, 01:15 PM   #1
stibias
Member#: 502092
Default 2019 STi DIY oil change?
So I'm about to do my first oil change for my 2019 STi. I've been researching around and have been looking in the owner's manual but couldn't find answers to my questions so I decided to post them here:
1. I know that there is an undercarriage panel that needs to be removed in order to get to the oil filter. And the panel itself has screws and (pins?) that need to be removed. Does anyone have a layout of the undercarriage panel along with its screws and pins that need to be removed? I'm also interested in the amount of screws and pins there are incase I miss one.
2. What size tools should I be using in order to remove the screws and pins?
3. What torque should I be setting the screws and pins to when I put the panel back on?
4. What torque should I be setting the oil filter back onto?
stibias is offline   Reply With Quote
Old 07-13-2019, 02:23 PM   #2
littledrummerboy
Member#: 94408
‘17 STI Sport-Tech
‘17 Impreza Hatch Touring
Lots of YouTube videos on changing oil on the 15+ so I suggest looking those to see.
It’s pretty intuitive if you just go under and look. 3 pop clips in each wheel well, 3 bolts (12mm iirc), 2 clip tab things at the back near the steering rack area and pull off the panel.
Torque for panel bolts is hand tighten. Seriously the service manual doesn’t list torque. Oil filter is a tight hand-tighten, but if you somehow really want to be technical I think it’s 8.9 for subaru blue filters and 10.3 ft-lb for the black ones. Oil plug is a hard hand-tighten (aka. 34.3 ft-lb)
littledrummerboy is offline   Reply With Quote
Old 07-13-2019, 04:59 PM   #3
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
IIRC there are six plastic push pins and three bolts which are either 12 or 13mm. There are also two U clips that attach the under panel in the rear. It's pretty self explanatory once you get under your vehicle.
A flat head screw driver is all I use to remove the plastic push pins. Pop up the center section then remove the entire unit.
OEM blue Subaru oil filter is 7/8ths of a turn AFTER the gasket makes contact with the block.
Scorpius is offline   Reply With Quote
Old 07-13-2019, 06:13 PM   #4
stibias
Member#: 502092
Cool, thanks for replies guys. Where do you suggest putting the jackstands?
Old 07-13-2019, 06:43 PM   #5
littledrummerboy
Member#: 94408
‘17 STI Sport-Tech
At the jacking points shown in the owner’s manual. You can lift the front of the car with a floor jack at the front centre plate (just by the rear panel bolt you’re taking off when it is up), then place the jack stands by the jacking points and lower the car on them. On a related note, you can lift the rear up using the rear diff for stuff requiring the rear to be up (again place jack stands where appropriate).
Old 07-13-2019, 06:56 PM   #6
Fahrezz
Member#: 501383
+1
Fahrezz is offline   Reply With Quote
Old 07-14-2019, 12:13 AM   #7
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
ramps are so much easier to use.
jasonwrx86 is offline   Reply With Quote
Old 07-14-2019, 10:40 AM   #8
stibias
Member#: 502092
I was actually considering this as well. Which ramps do you use?
Old 07-14-2019, 01:09 PM   #9
08redWRX
Member#: 186068
2019 STi
I bought the advance auto parts one and they work great on the stock height. Once I lower i'll have to make extensions to get on them but for stock height car you can't beat them for the price
08redWRX is offline   Reply With Quote
Old 07-14-2019, 04:14 PM   #10
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
There are three bolts, two at the front and one at the rear center, and require a 12mm socket to remove. These bolts are "shoulder bolts" and when reinstalling, do so by hand as not to damage the opening in the under-panel. Tighten to snug.
There are six push-lock clips, two at each side center lower, and one at each side center upper. You will need a panel removal tool or similar. The center pins are to be popped out a few millimeters, and then the base of the clip pulled out with the center pins still in place.
There are two plastic square shaped "c" clips, rear, that hold the panel to the cross-member. Pull down slightly and slide rearward, keeping parallel to the car/ground.
The oil-pan drain-plug utilizes a crush-washer. If this is the first time changing the oil, the crush-washer will either be stuck to the pan or to the drain-plug. It is recommended to use a new crush-washer. Or as an option, install a Fumoto oil drain-valve.
I use heavy-duty Rhino Ramps for light-duty trucks and two to four pieces of 2" x 12" boards to elevate the front to get onto the ramps (I have a lip).
Old 07-14-2019, 06:58 PM   #11
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
I run RaceRamps.
RR-56
RR EX-12 (extensions)
For winter under cars I hibernate RR-FS (Flatstoppers)
oichan is offline   Reply With Quote
Old 07-14-2019, 09:53 PM   #12
littledrummerboy
Member#: 94408
‘17 STI Sport-Tech
I didn’t want to spend that much on Race Ramps, so I ended up making my own out of spare 2x4s. No scraping on my lip with a really low approach angle (ramp length is 6.5 ft long), raised up nice and high with 6 stepped levels, and each side is 14” wide to fit fat tires while still having some safety wiggle room on either side of the tire. I also made them 2-piece interlocking so I can slide out the rear 3.5 ft for side access. Basically DIY 2-piece Race Ramps+extenders at a fraction of the cost.
Oil changes are definitely faster to do on ramps and I feel safer being under there with my setup than using my jack stands... they’ve done their job safely too, but still... now I only use jack stands for things requiring the wheels to be off.
Old 07-14-2019, 10:50 PM   #13
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I think you need to visit your local regional forum here and/or find locals on facebook and ask for help personally.
Old 07-15-2019, 04:23 PM   #14
xtremsiege2
Member#: 232721
2015 wrx premium
ICM
I think you should bring it to your local dealer and have them do it and watch the tech. I'm sure they won't mind letting you watch them work on it as long as you stay out of way.
Honestly, it sounds like you picked the wrong car to learn on. Its very easy, but its very expensive considering what can do wrong and not always for everyone.
xtremsiege2 is offline   Reply With Quote
Old 07-16-2019, 04:22 PM   #15
crick0234
Member#: 319696
2012 Subaru WRX STI
youtube vids of underskirt tray. typically 3 screws, two tabs in the back, and a plastic rivet behind each front wheel well area. It's not too hard if u have the car up and just study the undertray a bit.
the new filter, i typically hand tighten. usually goes about 7/8 a turn when the gasket makes contact. dont really need to tighten to specific torque (like it says 10 or 11Nm, i'd just hand tighten cuz finding the right size oil filter wrench was a PITA, it slips a lot too - hand tighten is fine, don't overthink it).
the screw torque for the undercarriage, meh, i hand tighten again with a 3/8 ratchet... probably around 4-5 ft lbs i'm guessing? maybe 8? i dunno; just tight with a 3/8 ratchet. the rivets themselves dont need torque, they just pop on and off.
crick0234 is offline   Reply With Quote
Old 07-18-2019, 10:52 AM   #16
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
Rhyno ramps are very cheap and durable.. I have been using them for over a year now...
Here's a random youtube video of someone using them..
ericsson is offline   Reply With Quote
