Welcome to the North American Subaru Impreza Owners Club Sunday August 9, 2020
Old 07-16-2019, 06:29 PM   #1
Skadoodle27
Member#: 504322
Default Ac Compressor Wont Turn On.
So I have 01 2.5rs subaru Impreza. The AC compressor attempts to spin but wont actually turn on!! I checked the relays and the fuses they're all good. I bypassed the relay with a paperclip it turns on blows cold air for about 2 minutes before pressure builds up and blows freon out of somewhere. I replaced the AC relay with the horn relay and it worked again for about 2 minutes before shutting off. Now It will not work at all. Any ideas? Someone mentioned that my high pressure switch may have gone bad and someone else mentioned it just may be the clutch in the compressor.
Skadoodle27 is offline   Reply With Quote
Old 07-16-2019, 08:39 PM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Low freon stops the compressor from spinning. Check/fill and if this fixes it, you likely have leak. #1 leak spot is short hose going into compressor.
Old 07-17-2019, 06:35 PM   #3
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Get it filled, and when they do, have them put the dye in it so you can see the leak if it has one.
bdubblu is offline   Reply With Quote
