08-29-2007, 12:23 PM | #1 |
Member#: 57589
Vehicle:2011 WRX A Blu Hue |
Timing Belt
is the 3.0 the only one with the timming chain?
08-29-2007, 01:59 PM | #2 |
Member#: 10471
TXIC
Vehicle:2000 BMW Z3 sold Outback & ForesterXT |
I do believe the timing belt is found on just about all the subaru models. The 3.0 probably has a chain becuase of the bigger engine (though they could've used a bigger, stronger belt I suppose).
08-29-2007, 04:21 PM | #3 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
From cars101.com: http://www.cars101.com/subaru/outback/outback2003.html
* 3.0L DOHC H-6 cylinder engine. This engine has an aluminum crankcase, double-overhead camshafts (dohc) chain-driven with four valves per cylinder. The timing chain does NOT have a replacement schedule - suggested replacement of the rubber belt on the 2.5L 4 cyl is 105,000 miles. The 6 cylinder uses Direct Ignition with an individual ignition coil for each cylinder so there is no distributor or sparkplug wires. The H6-3.0 produces nearly 30 percent more horsepower and torque than the 165-horsepower 2.5-liter H-4 and is only 0.8 inches longer. Premium fuel, 91 octane, is recommended. o 212 horsepower @ 6,000 rpm o 210 lb.-ft. of peak torque @ 4,400 rpm 174 lb.-ft of torque @ 2,200 rpm |
08-29-2007, 06:37 PM | #4 |
Member#: 152710
Yes the posts are correct, the 3.0 H6 in the Legacy is chain driven. It was done that way because there wasn't enough room in the current Legacy body at the time to fit a 6 cylinder and a timing belt. The chain cover is skinny compared to the tbelt cover.
Now the SVX on the other hand is a belt driven H6. But that is a story for a different time and thread! |
Similar Threads | ||||
Timing belt cover and checking the timing belt | Pinned | Service & Maintenance | 14 | 12-28-2015 12:09 AM |
Question on how to inspect timing belt. | Blitzkrieg | Service & Maintenance | 5 | 06-04-2010 08:11 PM |
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley | Kansai Subaru | Service & Maintenance | 14 | 10-23-2008 04:05 AM |
FS: Gates Racing Timing Belt NEW/ PE timing belt | Keo | Engine/Power/Exhaust | 6 | 07-04-2008 03:15 AM |
Instructions for taking timing belt cover off to inpect the timing belt? | scoobbee | Service & Maintenance | 3 | 05-09-2005 06:33 PM |
