Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 02-13-2006, 03:41 AM   #1
wfofromthegetgo
Member#: 102985
2000 Outback Sport
Default Why do so many people run Accesports?
I just read the FAQ section in this forum and it made me wonder...this is probably a stupid question but I was thinking of upgrading soon to a WRX and I wanted to know if it was as easy to make power with as my other factory turbo cars. I used to have an '89 Supra Turbo and after that a Talon. With minor mods such as MBC and full exhaust, i was making fairly good power without having to do any real tuning as far as fuel and ignition went. I was pretty much relying on the stock ECUs to supply the extra fuel needed. Obviously, I got to a point where I was going to need an AFC or something like that to go any further but I was at roughly 300 crank hp on the Supra with stock everything.
I guess my question is, if I don't have much money left over after buying the WRX (which is going to be the case) can I still have a little fun at first just raising the boost and getting exhaust.
wfofromthegetgo is offline   Reply With Quote
Old 02-13-2006, 04:03 AM   #2
23b_Rex
Member#: 79394
02 gda
wrb
bottom line:
without em.... these cars dont make reliable power
23b_Rex is offline   Reply With Quote
Old 02-13-2006, 09:59 PM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Originally Posted by 23b_Rex
bottom line:
Please explain to me how a custom dyno tuned reflash from ECUTek or a Hydra/UTEC map with temperature compensations isn't reliable? What about the homebrew reflashes of the stock ECU? Not reliable?
cdvma is offline   Reply With Quote
Old 02-13-2006, 04:05 AM   #4
Davenow
Member#: 23676
Its the cheapest EM out there.
Old 02-13-2006, 04:13 AM   #5
Gethin
Member#: 2998
And simplest. Plug it in, reflash, drive.
Gethin is offline   Reply With Quote
Old 02-13-2006, 05:46 AM   #6
AlucardR
Member#: 54213
Personally I use Ecutek, after flashed maps or custom tune..it does all the timing adjustments needed..if it knocks at any point..it remembers and retards timing accordingly, then permanently remembers it. The advantage accessport people have is they can more easily change maps and settings, where I run 1 or 2 standard flashed maps, a 2nd one which would need to be triggered by defrost button + full throttle. Say one would be a daily driver, the other a race map. I can adjust some settings manually, take any logs/see realtime engine processes and run a road dyno with Ecutek, but not without the assistance of Deltadash..which I also have and use through a laptop. I don't know if accessport users have features to this extent, but overall it seems convenient and affordable.
AlucardR is offline   Reply With Quote
Old 02-13-2006, 06:07 AM   #7
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
personally I use UTEC... I would prefer Hydra but its soooo expensive.. IMO, If you are planning on doing more mods, then go with a UTEC...
vipernj is offline   Reply With Quote
Old 02-13-2006, 07:16 AM   #8
Kha0S
Member#: 8808
DGM 5D
The main issue with just slapping on boost control with these cars is that the stock fueling runs rather lean in the low load/low RPM sites where a stock car isn't making boost, but a mildly modified car is. As a result, even at pre-wastegate pressures, the car can become knock prone from simple exhaust modifications. Similarly, the MY04+ cars have some well known issues in the switchover from closed loop to open loop fueling, and lean conditions are a symptom of aftermarket exhaust and boost control on cars without supporting engine management.
The current feelings with tuning the WRX seem to fall into the piggyback vs. reflash communities, usually evangelized by the UTEC vs. AccessPort customers. The pros/cons of both are hashed out regularly in the history of this forum.
If you're looking for the absolute cheapest way to tune a 2002-2005 WRX, get the OpenPort cable (around $80 from tactrix.com) and reflashing your ECU with the free tools from OpenECU.org. While the process is nowhere near as simple or as well documented as the products from Cobb or ECUtek, you can modify your fuel, timing, and boost maps to make the car run safely.
Kha0S is offline   Reply With Quote
Old 02-13-2006, 09:33 AM   #9
ScoobySnacker
Member#: 105303
So you are saying that there will be knock with simple exhaust mods and no EM? I just put a turboback on and dont have the money at the moment for an accessport. Am i safe?
ScoobySnacker is offline   Reply With Quote
Old 02-13-2006, 09:49 AM   #10
Kha0S
Member#: 8808
DGM 5D
There can be knock with simple exhaust mods and no EM. I can say that my car, with an uppipe and turboback, and silicone turbo inlet and intercooler hoses, was suffering a little bit of light throttle, low RPM timing retard, presumably from ECU-detected knock. The car was targeting 13.2:1 or so at 7psig (wastegate pressure). The real scare was that the high detonation fuel map was also too lean at the same load sites.
Any time you modify the intake or exhaust characteristics of your motor, the fuel and ignition mappings could potentially cause damage or poor performance.
/Andrew
Old 02-13-2006, 09:51 AM   #11
Zumble
Member#: 34860
2005 Forester CGM
Catted or uncatted?
Zumble is offline   Reply With Quote
Old 02-13-2006, 09:53 AM   #12
ScoobySnacker
Member#: 105303
Originally Posted by Zumble
Catted or uncatted?
uncatted
Old 02-13-2006, 12:22 PM   #13
Davenow
Member#: 23676
2002-2003 run just fine with a exh and no EM. Its not ideal, but at that low level, you will be fine.
Its 04 and later that cant safely run like that
Old 02-13-2006, 12:44 PM   #14
Kha0S
Member#: 8808
DGM 5D
I beg to differ. I found that with nothing more than exhaust modifications, my 02 was susceptible to boost spikes and was running an IAM of 12 due to low-RPM, low-load lean conditions.
The car was able to pull back timing to account for it, but it shows that it's not "safe" to be running that kind of hardware change without updating the engine management.
Old 02-13-2006, 01:52 PM   #15
ScoobySnacker
Member#: 105303
What exactly is boost spike? If i am right in my thinking i may be getting a little right now??
Old 02-13-2006, 11:58 AM   #16
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
WR Blue Mica w/ Gold BBS
To answer the original question, for the price of a manual boost controller and exhaust, you can get an AP and have more power safely. Also, you can add mods later and you're ready for the upgrade because you have engine management. That's why my first mod was an AP.
yakkosmurf is offline   Reply With Quote
Old 02-13-2006, 01:06 PM   #17
bgod
Member#: 100274
pretty much all newer turbo factory cars need em's to make reliable/safe power.
the mk3/mk4 supras bpu'd with an mbc can compensate. so can the 1g/2g dsm's.
ap isn't the best. but in terms of reliability and ease of use it can't be beat especially when shops like tdctuning/pdxtuning are tweaking their own maps.
bgod is offline   Reply With Quote
Old 02-13-2006, 08:29 PM   #18
wfofromthegetgo
Member#: 102985
2000 Outback Sport
ok, thanks guys...I'll factor in the price of an AP with the purchase price
Old 02-13-2006, 09:16 PM   #19
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
1st mod, boost gauge, before anything.
personally, i wouldnt run any kind of basemap. thats why i waited to just get a custom tune by the best. phil at element tuning. im also running a utec.
David Medina is offline   Reply With Quote
Why do so many people love VW and Audi? plunk10 Off-Topic 114 09-19-2006 10:50 AM
Why do so many people hate the AP? richde Engine Management & Tuning 133 11-25-2005 11:01 PM
Why do so many people on NASIOC like to start arguments JoshP Off-Topic 70 11-04-2005 12:30 AM
Why do so many people blank out their license # on car pics Trizzle Off-Topic 17 11-26-2003 03:26 PM
why do so many people who drive hondas hate impreza bluesubie General Forum Archive 26 08-29-2000 09:29 AM
