Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Old 06-22-2009, 07:55 PM   #1
nismo3183
Member#: 204986
2005 Sti
Default rear camber bolts or camber plates
Pretty much made up my mind to go with the BC coilovers, BR series, and was just wondering which camber adjustment method for the rear is better for me. I dont race the car and I dont have a really large rim/tire setup. What are the pros and cons for each setup? so far the only thing I can think of for the plates is removing the rear seat each time I want to adjust the camber. As far as the bolts go I think the only thing is the range of adjustment is a limitation. Do I have to run a specific brand of bolts with the BC BR series? Any help on which camber adjustment method I should get would be appreciated.
nismo3183 is offline   Reply With Quote
Old 12-03-2010, 10:22 AM   #2
Link2006
Member#: 249123
2004 PSM STi
bumb, have the same question, kinda.
Link2006 is offline   Reply With Quote
Old 12-03-2010, 10:57 AM   #3
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
if you can afford the rear camber plates do it, most alignment centers don't know how to use camber bolts and mess them up or install them in a fashion that they come loose and allow your alignment to change. i had eibachs not that brand of rear camber bolt matters, also if you run retarded wheel and tire setups a combo of camber plates and bolts allow for extra clearence from coilovers.
feint05 is offline   Reply With Quote
Old 01-02-2011, 03:23 AM   #4
y2ldude
Member#: 99400
2005 sti
asphen
im just trying to help my brother out
would these work on ohlins pcv? it says its for bc coilovers, just wanted to make sure?
thanks
http://www.subaruwrxparts.com/shop/p...IDCategory=136
y2ldude is offline   Reply With Quote
Old 01-02-2011, 03:49 AM   #5
LTBlackBird
Member#: 222367
2004 Impreza WRX STi
Platinum Siver Metallic
Which is pathetic considering how many mcpherson strut cars out there that get aligned all the time. 99% of the time they are "Toe n Go's"
LTBlackBird is offline   Reply With Quote
Old 01-02-2011, 03:50 AM   #6
LTBlackBird
Member#: 222367
Also. im running front plates, front bolts (in addition to the stock), AND rear bolts. I do my own alignments though with the assistance of whoever's rack it is. Havent had any of them loosen up on me, i check them every so often though.
Tokico D-Specs + Camber bolts = less camber than stock struts without camber bolts?! formula91 Brakes, Steering & Suspension 10 09-07-2009 12:59 AM
Rubbing Issues: Saggy Butt Shims vs Rear Camber Bolts or Both? HawkI56 Brakes, Steering & Suspension 9 03-15-2008 10:29 PM
Camber Bolt vs Camber Plate Questions ruggedman Brakes, Steering & Suspension 17 02-23-2008 12:35 AM
Eibach Springs - Need Camber Bolts or Alignment? Rich10 Brakes, Steering & Suspension 3 09-03-2003 04:14 PM
rear camber bolts = front camber bolts? Penguinking Brakes, Steering & Suspension 1 07-12-2003 10:01 PM
