Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 07-27-2003, 10:58 PM   #1
gooter80
Member#: 25519
Steel Grey
Default twin BOV question for the masters
ok so i was at a show this weekend and there was a WRX there with a front mount, turbo upgrade etc etc. i noticed he had 2 bov's connected. one just after the turbo and one right before the intake manifold. what would this actually do? benifits? downfalls? louder? just curious is all.
gooter80 is offline   Reply With Quote
Old 07-27-2003, 11:05 PM   #2
mlambert
Member#: 13831
Most likely it was just for bling.
mlambert is offline   Reply With Quote
Old 07-27-2003, 11:23 PM   #3
gooter80
Member#: 25519
Steel Grey
that is quite possible but what actual effect would it have on performance either negative or positive?
Old 07-28-2003, 01:03 AM   #4
Snowphun
Member#: 1800
After the turbo? How could that be a BOV? Are you sure it wasn't a fancy waste gate or something?
Paul
Snowphun is offline   Reply With Quote
Old 07-28-2003, 01:14 AM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I would assume it was after the compressor discharge and one before the throttle body.
Maybe HE thought that all the piping of the FMIC would take too long to depressurize after throttle lift with only one BOV???
Mabye they open at different speeds and give some kind of cool pshhh.. pshhh sound?
Hell I don't know...sounds like a waste of money to me
mr2guru is offline   Reply With Quote
Old 07-28-2003, 01:17 AM   #6
Stoychkoff
Member#: 30453
2002 Saturn Sl2
Charcoal Grey
two bov prevent boost creep. if you don't know what boost creep is then here it is:
Normal boost rise when set to 13 psi = shoots up to 14, then 13, 13, 13...
Boost creep = shoots up to 14, then 13, 13, 14, 15, 16, 17...
if you want your engine to blow up then you stick with one bov or none... but if you want your engine to survive the boost world then you have to regulate your psi... and one way is with two bov's... it just lets out more psi so you can stay steedy at what ever you have it set at
Stoychkoff is offline   Reply With Quote
Old 07-28-2003, 01:24 AM   #7
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Lay off the crack bro...BOVs have nothing to do with boost creep.....
Wastgates regulate boost. Only one is required...either internal or external. Usually external ones provide better boost control and curb the dreaded "boost creep"
Old 07-28-2003, 01:26 AM   #8
wickedwrx
Member#: 23826
2002 impreza
No color it is invisible.
A BOV does not controll boost. It helps prevent the turbo from slowing down when you lift off the throttle under boost. You are thinking of a waste gate. I have seen 2 BOV on cars, but they were running insane amounts off boost and had to vent large volumes of air to prevent compressor surge.
wickedwrx is offline   Reply With Quote
Old 07-28-2003, 12:36 PM   #9
bunot
Member#: 21641
4EAT [email protected]
Now a 6MT! beyatch!
are you even sure the second one is a BOV? if it was after the turbo, maybe it was made to bypass the cats and muffler. they make dump gates now for our exhausts.
jason
bunot is offline   Reply With Quote
Old 07-28-2003, 01:34 PM   #10
Snowphun
Member#: 1800
Ahhh....
Old 07-28-2003, 05:35 PM   #11
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
The more you can vent the less backpressure on the turbo when the throttle body closes.
Not all BOV's are equal, HKS has to be one of the more restrictive ones I have seen & can cause compressor surge on larger turbo/FMIC systems.
Dual BOV's wouldn't hurt if placed properly...
Perfect BOV would probibly be the size of the piping it is venting...
my 0.02
GLwagon is offline   Reply With Quote
Old 07-28-2003, 10:01 PM   #12
Dick Fitzwell
Member#: 25684
i second that, probably just for looks.
who's car was it...do you know? from here?
Dick Fitzwell is offline   Reply With Quote
Old 07-28-2003, 10:25 PM   #13
gooter80
Member#: 25519
Steel Grey
not too sure whos it was. it just got me thinking because i have an HKS on my car now but i also have a GFB sitting in my room. thought perhaps it would be cool to have both sounds and if it would help with venting. just a thought that crossed my mind. although im sure you all will think its a ghey idea
Old 07-29-2003, 12:50 AM   #14
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Ohhh Boy Maybe we should go over what a BOV is.
Scoobie Steve is offline   Reply With Quote
Old 07-29-2003, 05:06 AM   #15
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Like GLWagon said.. dual BOVs can help for quicker response.. venting the air out faster than a single.. I've heard the HKS SSQV wasn't the quickest venting bov out there and have seen many people use dual HKS SSQVs to fix that problem.. Other than that, it's purely aesthetic..
Jay
Diversion is offline   Reply With Quote
Does anybody have any experience with the forced air tech twin gt30r kit for the sti? GT42r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 12-06-2007 09:22 AM
What company's offer twin scroll twin turbo kits for the sti? GT42r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 09-12-2007 10:27 AM
Who is pumped for The Masters?? rickeyj23 Off-Topic 27 04-07-2004 09:26 PM
suspension question for the master techs: bushing differences between FWD/AWD? RaceCarRiot Brakes, Steering & Suspension 2 05-14-2002 09:08 AM
Newbie questions for the Subaru masters...:D RSarte Newbies & FAQs 10 04-02-2001 08:25 AM
