Welcome to the North American Subaru Impreza Owners Club Tuesday January 15, 2019
Old 08-04-2018, 05:45 PM   #2551
PDXREALTOR
Member#: 468393
2017 STI
Here is a link to a long post about my issue. The problem is identified. It's a long read, but the short version is at the bottom.
If anyone would like me to wipe my posts from this thread let me know. It got way off topic. Thanks all for your advice and patience with the matter.
Fuel pressure differential injector scale compensation
PDXREALTOR is offline   Reply With Quote
Old 08-04-2018, 05:49 PM   #2552
PDXREALTOR
Member#: 468393
2017 STI
Originally Posted by NSFW View Post
I suspect that both of those rich dips might be the same thing.
Yes it is driven by rapid load changes, I'm just saying you can get those load changes, and thus AFR dips, at any RPM (it just depends on what the RPM is when you stomp on the gas pedal) so you have to be careful about tuning around them.
It might be illuminating to plot fuel pressure and boost pressure together, along with commanded AFR and actual AFR, and see if the curves diverge in harmony. If so, that would suggest that you're right about the fuel pump being maxed out (or not switching to higher duty soon enough).
Head over to my thread above - I have something for you there.
Old 08-06-2018, 11:02 PM   #2553
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I was going to start asking if the fuel pump controller was acting up, but I guess you have it figured out now.
Homemade WRX is online now   Reply With Quote
Old 08-06-2018, 11:16 PM   #2554
PDXREALTOR
Member#: 468393
2017 STI
Thanks. I did actually log the FP duty cycle and is kicking on to 100% DC before I get my lean spike.
Even with the differential table de-activated I still have a bit of a lean spike there. I'm going to bet on the fuel pump not being able to keep up with the fuel demand at that psi. I got the 1300s in last night, and am dropping the base back down to 43.5. Will know more soon.
A side from that.... I really, really, like this turbo. I got it out and about the other night on some quiet freeways and side streets. The thing just rips compared to my Green. It's funny too.... my Green, at least as of now, spooled 150 rpms sooner. But, the response is so 'right there' it's just silly. I giggle every time I hit the gas.
Old 08-09-2018, 05:34 AM   #2555
JakeGri
Member#: 489905
Goals lol
JakeGri is offline   Reply With Quote
Old 08-16-2018, 01:42 AM   #2556
PDXREALTOR
Member#: 468393
2017 STI
Does anyone have a 7163 turbo available to measure the compressor inlet snout from cover to end?
Old 08-16-2018, 07:53 AM   #2557
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I do. You want how long the inlet is, where a 3" coupler mounts to?
Old 08-16-2018, 08:13 AM   #2558
Robert Derby
Member#: 490228
2010 ford
black
Great engine!!!
Robert Derby is offline   Reply With Quote
Old 08-16-2018, 11:41 AM   #2559
PDXREALTOR
Member#: 468393
2017 STI
Yes, I think. My 7163 is a 2.5" inlet
To help you help me.... What I am doing is making a 2.5 to 3" adapter sleeve. I would like to push the sleeve as far back over the entire 2.5" portion of the Compressor inlet. I think this portion would be polished.
I'm tapering ~1/4" to a sharp point out past the inlet to get a smooth airflow (think velocity stack).
Old 08-16-2018, 12:14 PM   #2560
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I get 1.03" in length. Also to note, the inlet already is tapered almost to a point already.
Careful with the 'horn'. It's easy to induce more turbulence than remove it. I've found short horns, even reduced in size (some Garrett turbos) will improve surge and flow properties best.
Example, 4" to 3" conversion:
Old 08-16-2018, 12:49 PM   #2561
PDXREALTOR
Member#: 468393
2017 STI
Thank you!
Nice adapter plate. On your horn - did you specifically make it have a flat 'face' before the taper?
This is what I'm doing with the 'horn'. Just enough to direct the airflow into the inlet. Thoughts?
This isn't the actual material I'm using this time around. I found this to be too soft. This just illustrates the point the horn comes to. The actual piece I'm using is below. It isn't finished. It's an 80a Urethane.
Old 08-16-2018, 01:41 PM   #2562
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Space constraints prevented the radius from being all the way out to the OD. I couldn't get the geometry of the horn and size and fitment all to jive so I just made the radius and taper to taste. Worked exceptionally well.
I would smoothen and round where the chamfer meets the ID. Maybe shorted it up a but to put that feature closer to the inlet. IIRC the sweet spot for where the horn should start to open is about the distance = compressor wheel diameter. All that stuff I did goes back to 2010, so I may be off on that one. I remember doing lots of reading and CAD simulations to try and find the sweet spot. Having an in with some Garrett engineers was nice for note comparisons too. I don't see why it wouldn't translate to BW. A compressor wheel is a compressor wheel.
Old 08-16-2018, 02:01 PM   #2563
PDXREALTOR
Member#: 468393
2017 STI
My plan was to match the chamfer exactly with the beginning of the turbo inlet. Like pictured below. This is a sloppy example but gives you the idea.
This is the reason I wanted the length of the inlet snout. I wanted to avoid having to 'line up' the chamfer with the inlet. I want to accomplish the alignment by simply pushing the sleeve on against the compressor housing.
By just doing this I gained .5 PSI on spool up with the FP Green. However, I think that's all kind of relative unless you are at the turbos limit and the only way to get more PSI is to increase the inlet size.
The main reason I am doing this on the BW 7163 is the soft inlets, and hard inlet couplers, are all 2.4". On my 2.4" coupler you can see it almost turns into a restriction after being stretched on the larger compressor inlet.
Old 08-16-2018, 02:20 PM   #2564
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
OK, I got you now. Offset transition isn't helping any I'm sure. You can't get that same thing in a 2.5" coupler?
Old 08-16-2018, 02:28 PM   #2565
PDXREALTOR
Member#: 468393
2017 STI
I'm not sure. You have me wondering now. I am going to call AP and ask them. However, you can see when the 3" coupler is installed correctly it's not that bad.
I'm thinking the 3" with 2.5 > 3" adapter sleeve would still be better than a 2.5 > 3" offset coupler. What do you think?
Old 08-17-2018, 07:12 AM   #2566
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You're probably right.
Old 08-17-2018, 10:53 PM   #2567
PDXREALTOR
Member#: 468393
2017 STI
The FP Green must sit differently in one way or another. I can't get a pinch free connection for the life of me.
I am quite pleased with compressor inlet adapter though. I rolled the edges as KB suggested and it took a bit of the precision out of the final cut.
It's slip fit on the snout very tight. I'm going to keep working on this and see if I can get it to pop into place somehow.....
Old 09-07-2018, 11:18 AM   #2568
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
I picked up a new 7163 that has never been run. The ID badge doesnt seem to match anything in production currently and was wondering if anyone here has any info on what Ive got or knows where I can go to get the specs. I know these turbos when through various revisions and I would like to know where mine falls in that range. I am suspecting this was a very early model as the description (Desc. EFR-7163 TURBO 6) and serial number (06) are like nothing out there. Ive never hear of a 2 digit serial number haha
pearson222 is offline   Reply With Quote
Old 09-07-2018, 12:02 PM   #2569
Homemade WRX
Member#: 33782
96 in the garage
Well it has an aluminum CHRA, which I thought they only sold as a supercore, without housing.
Looks pretty straight up to me.
Old 09-07-2018, 01:05 PM   #2570
Xtea
Member#: 395734
Could be one of the early versions with the smaller AR and slightly smaller wheel, aka, first page dyno plot.
Xtea is offline   Reply With Quote
Old 09-17-2018, 12:25 PM   #2571
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
What method or order of operations did you guys use for installing the uppipe, turbo, and downpipe. I found that I had to install the turbo on the uppipe first and then attach that assembly to the headers. That left the downpipe pretty difficult to get aligned with the midpipe and turbo v-band. I have a pretty major leak at the dp-midpipe and wanted to see what others have found to be successful.
Old 09-17-2018, 01:55 PM   #2572
PDXREALTOR
Member#: 468393
2017 STI
Headers, uppipe, turbo. Only thing that gave me any problem was that back bolt. It ended up going on as it should, but I forget how I did it.
Old 09-21-2018, 01:49 AM   #2573
PDXREALTOR
Member#: 468393
2017 STI
Does anyone know if the SINGLE port turbosmart wastegate with a stiff base pressure spring works any better than the high boost EFR canister?
I was thinking like a 22 psi base pressure.
Old 09-21-2018, 11:47 AM   #2574
LanceKA-T
Member#: 491735
I'm sure that you'd be better off with a dual port wastegate or a 4-port MAC valve to control it.
LanceKA-T is offline   Reply With Quote
Old 09-21-2018, 12:23 PM   #2575
PDXREALTOR
Member#: 468393
2017 STI
Thx. I'm well aware of it. But, I wanted to know specifically about the single port.
