Brakes & Suspension Forum sponsored by The Tire Rack |
02-12-2001, 09:41 PM | #1 |
Member#: 1305
AKIC
Vehicle:2000 Impreza |
Tire size/rim width recomendations....
Hey I found this Yokohama site that recomends what tire size will fit on what rim width. Does anyone know if these same recomendations hold true for other tire companies besides Yokohama?
http://www.yokohamatire.com/04a4e.html
02-12-2001, 11:54 PM | #2 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
It's pretty true for about every tire size. Although tires do vry a little bit, the numbers are pretty close. I'd use the chart if I were you...
Eric |
02-13-2001, 06:19 AM | #3 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
The chart looks like standard min-max with some exceptions that I'm sure Yokohama could explain if you emailed. (like a 205/45-16 only being recommended for 7" rim.)
For high performance tarmac use, you should use a rim at least 80% the width of the tire. At least 90% will be better. On lower profile tires narrower % rims become less tolerable. |
Question about offset, tire size, wheel width... | wgr73 | Tire & Wheel | 7 | 01-27-2010 03:15 PM |
tire vs. rim width | hpracingwrx | Tire & Wheel | 9 | 08-19-2005 12:21 PM |
Rim width vs. tire size question | dedgley | Tire & Wheel | 2 | 04-27-2005 01:19 PM |
Matching rim width and tire size (8.5" with 225/45ZR17) | wrbWRX | Brakes, Steering & Suspension | 8 | 04-18-2005 11:45 AM |
tire and rim width? | rawrFERNY | Tire & Wheel | 5 | 03-09-2005 09:01 PM |
