#1 |
Member#: 11232
Vehicle:2002 WRX 2010 Outback 3.6 |
![]() As per title, what's is wheel offset,
If I buying wheels, how does offset affect my choices, and finally what is the off set for a 2002 WRX Sedan |
#2 |
Member#: 4864
Vehicle:2004 WRX Silver |
![]() Wheel offset is a measure of how far the hub (where it ataches to the car) is from the horizontal center of the wheel. So if you're looking at your car's wheel head on, zero offset would put the hub right in the center. Positive offset puts it further away from the car. Negative offset puts it closer to the car. I hope that makes sense, because without a diagram, I can't think of a better way to explain it. Subarus have an unusually high amount of positive offset on their stock wheels. I think it's somewhere in the low to mid 50s (+54?). I think the official minimum is +48.
[edit] actually, go <a href="http://www.tirerack.com/wheels/tech/offset.htm">here</a> for a better explanation and a diagram. Jordan |
#3 |
Member#: 3056
Vehicle:2001 Impreza 2.5RS Blue Ridge Pearl |
![]() +53mm offset for Subaru wheels. Try searching in the susp, brakes, rim and tire section. This has been covered many times before in there.
#4 |
Member#: 11232
![]() Thanks,
the website and info are all being written down and bookmarked. |
#5 |
Member#: 1501
Vehicle:2009 WRX wagon Dark grey |
![]() You will be able to get away using wheels with +48 offset.
What is it with wheel bearings? | rick-l | Service & Maintenance | 4 | 03-20-2007 07:24 AM |
What is it about the "Subaru" which made you buy one ? What makes it a great car ? | alfriedesq | General Community | 58 | 09-11-2006 06:24 PM |
machined cut inside wheel, what is it? | homer09 | Tire & Wheel | 7 | 04-11-2006 10:02 AM |
Brake/Wheel Creeking... What is it? | AVATAR-X | Service & Maintenance | 10 | 03-16-2003 05:45 PM |
JIL symbol found on many alloy wheels, what is it? | Snappy | Brakes, Steering & Suspension | 1 | 12-16-2001 03:40 PM |
