Welcome to the North American Subaru Impreza Owners Club Monday October 15, 2018
Old 04-09-2006, 03:19 PM   #1
homer09
Member#: 97100
2002 2.5RS
Midnight Black Pearl
Default machined cut inside wheel, what is it?
I bought some used STI v7 wheels. I am presently sanding them down and filling in the dings and scratches with bondo so i could eventually paint em.
now i noticed something weird. on the inside of one wheel, where the the tire sits, (not visible with tire on) there is a cut. kinda looks like it was grinded out. now im not sure if this was done by some dumbass who was careless, or if it comes like that from the factory to balance the wheel.
i filled up the cut with bondo, but now im not so sure i should have?
edit: added picture
homer09 is offline   Reply With Quote
Old 04-10-2006, 12:48 AM   #2
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
Need picture.
May have been someone screwed up with the mounting machine (heh, that sounds dirty).
Chi_San is offline   Reply With Quote
Old 04-10-2006, 05:35 PM   #3
homer09
Member#: 97100
2002 2.5RS
added picture
Old 04-10-2006, 10:05 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
so why are you worried about an area which is covered by the tire when it's mounted?
DrD is online now   Reply With Quote
Old 04-10-2006, 10:13 PM   #5
homer09
Member#: 97100
2002 2.5RS
because of balancing issues. if the cut was put at the factory, its because it belongs there for a reason. i shouldnt cover it with bondo in that case.
Old 04-11-2006, 03:23 AM   #6
Mojambo
Member#: 102581
2006 STI-USDM
SGM
the weight of bondo is quite minimal. I've never seen a wheel "balanced" this way....don't you need to have the tire on to balance?
not trying to be a smart A$$ but I think someone took a chunk out. I just finished painting my BBS RK's and they had none of this.
Mojambo is offline   Reply With Quote
Old 04-11-2006, 07:21 AM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
it looks like a minimal amount of material has been removed - that, plus the fact that you will probably have more positional variation in the weight of the tires would say to me "don't worry about it"
My question was more of a why even bondo it in the first place if you are never going to see it? Unless it's really deep, it's not really going to impact tire balance, anyway.
Old 04-11-2006, 10:02 AM   #8
homer09
Member#: 97100
2002 2.5RS
ok thanks guys. i wont worry about it. probably was some jackass that took a chunk out of the wheel.
i bondoed it cuz i was doing the front face (curb rash, pitting) and figured mind as well do that too. im painting all around once this stage is done.
What is it with wheel bearings? rick-l Service & Maintenance 4 03-20-2007 07:24 AM
who sells this thing and what is it called? picture inside STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-03-2003 12:17 PM
Brake/Wheel Creeking... What is it? AVATAR-X Service & Maintenance 10 03-16-2003 05:45 PM
JIL symbol found on many alloy wheels, what is it? Snappy Brakes, Steering & Suspension 1 12-16-2001 03:40 PM
Wheel offset, what is it? MarkZ Newbies & FAQs 4 10-31-2001 11:07 AM
