Welcome to the North American Subaru Impreza Owners Club Monday May 17, 2021
Old 08-17-2008, 04:35 PM   #1
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Default Brake Pad Spreader/Remover - Where to buy
Like the title, where is the best (most reasonable) place to buy a brake pad spreader/remover online.
I'm running a Wilwood big brake kit with Cobalt GT Sport pads and would like a tool that would make it faster/simpler to change them out.
I've seen the pad spreader around but not sure where to purchase.
Thanks guys!
skimobile is offline   Reply With Quote
Old 08-17-2008, 09:00 PM   #2
MasterKwan
Member#: 98961
2003 WRX
Well, you can use a screwdriver between the pad and the rotor. I have a pair of vise grips with flat ends on the jaws (for holding welding materials). I use that on my calipers.
MasterKwan is offline   Reply With Quote
Old 08-18-2008, 09:43 PM   #3
ronemus
Member#: 124146
'17 Outback 2.5i
Premium Tungsten
A large C-clamp will do the job well for little money.
ronemus is offline   Reply With Quote
Old 08-19-2008, 05:59 AM   #4
Aegean93L
Member#: 103162
04 RS Sedan
Sears sells pad spreaders/removers.
Aegean93L is offline   Reply With Quote
Old 08-19-2008, 08:37 AM   #5
dunk
Member#: 15359
Most pad spreaders are designed for sliding calipers and won't work well on your Wilwood setup. I have the BSL6 front caliper. When I change pads I just open the bleeder and push the piston back in with my finger. I'm running a track car though, so I'll just leave the bleeder open for a little bit and let it gravity bleed any air bubbles that might have accumulated.
Duncan
dunk is offline   Reply With Quote
Old 08-19-2008, 09:34 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
wiggle one pad out. Turn 90* with friction surface against rotor. Use as a lever to push pistons back.
Insert new pad.
NOW remove the second pad, turn 90* and use as a lever. insert new pad.
Old 08-19-2008, 09:40 AM   #7
Mechie3
Member#: 120152
My friend has the rubber padded quick grips. They work quite nicely and don't marr up nice mono-block calipers.
Old 08-19-2008, 08:20 PM   #8
skimobile
Member#: 92114
03 WRX (NAVY Camo)
Cool, thanks for the input guys.
Old 08-19-2008, 11:07 PM   #9
Web Foot STi
Member#: 39086
2004 STi
Eastwood.com for your strange tools.
Web Foot STi is offline   Reply With Quote
SS brake line copper washers - where to buy mmiller2002 Brakes, Steering & Suspension 4 03-08-2010 02:07 PM
Brake pads for gc8, where to find? Mayrun Brakes, Steering & Suspension 0 08-03-2009 09:18 AM
Changing brake pads, where to buy? 98kPa Bay Area Impreza Club Forum -- BAIC 10 08-09-2002 05:22 PM
Need decent brake pads, what and where to get? RotarFreak Brakes, Steering & Suspension 8 05-03-2002 11:48 AM
Where To buy Endless Brake pads??? Tkacik General Forum Archive 4 05-20-2000 12:36 AM
