01-02-2013, 03:15 AM | #2626 |
Member#: 260501
AKIC
Vehicle:2003 miata SE Blurple |
I'm running naked myself, but I'm going to get a ptp blanket blanket and a coated grimmspeed shield when I put my new AVO tmic on.
01-02-2013, 09:12 AM | #2627 |
Member#: 284420
SWIC
Vehicle:2011 WRX Sedan SWP |
The stock is better than the aftermarket ones from what I've heard due to the thickness of the metal and the way it is shaped. Probably not much of a difference though. The stock is very very easy to modify. Benefit to going aftermarket is that you can return to stock without it looking like you were stage 2 as much. Be careful running nothing at all, my friends paint is coming off right by his hood scoop directly above the turbo from doing this.
01-02-2013, 09:37 AM | #2628 |
Member#: 309636
Vehicle:2015 STI LE WRB on Gold! |
Stock+aftermarket is even better!
01-02-2013, 10:19 AM | #2629 | |
Member#: 303531
BAIC
Vehicle:12 Subaru WRX White |
01-02-2013, 11:41 AM | #2630 |
Member#: 260501
AKIC
Well I live in Alaska so the ambient temperatures are so low it's not really an issue. Besides it's winter right now and I'm not usually on it very hard anyway.
01-02-2013, 01:36 PM | #2631 |
Member#: 284420
SWIC
01-02-2013, 02:28 PM | #2632 |
Member#: 303531
BAIC
01-02-2013, 04:06 PM | #2633 |
Member#: 166490
Vehicle:2011 WRX WRB |
On my last car I cut the stock heat shield with a dremel. Worked like a charm.
01-06-2013, 10:23 AM | #2634 |
Member#: 309636
So I went and got the coolant ECU recall done and gave COBB the rom here: https://forums.cobbtuning.com/forums...Program-WQC-39. A '12 STI owner posted a stock rom with the recall update there too. Hopefully they can use the data to update their maps.
Sidenote, since this issue only affects 2011+ cars, I'm really glad we have a 2011+ discussion thread. |
01-06-2013, 12:45 PM | #2635 |
Member#: 303531
BAIC
Ok so I just bought a used cobb downpipe. The guy only had it on the car for 1000 miles. My question I have a spt exhaust on my 12 wrx with 8000 miles, do I need new gaskets for it? When you buy a downpipe new does it come with gaskets?
01-06-2013, 12:47 PM | #2636 |
Member#: 98210
Vehicle:2016 Forester XT CWP 2002 WRX SRP 2016 Sienna |
you can probably get away with using the stock gasket for the bottom, its a good idea to get a new gasket where it mates to the turbo since that one is much harder to change if its leaking
01-06-2013, 12:53 PM | #2637 |
Member#: 260501
AKIC
Yeah, get a new one for the turbo and you should be able to reuse the doughnut gasket.
01-06-2013, 01:05 PM | #2638 |
Member#: 297588
Vehicle:2011 wrx white |
2011 wrx 5spd to 6 spd swap
hi guys new to nosiac looking to get some advice. im looking to swap out my 5 spd for a 6 spd. does anybody know which tranny would fit my 2011 wrx. i have major upgrades and need a 6 spd. any advice would be helpful.
01-06-2013, 01:07 PM | #2639 |
Member#: 98210
you pretty much need to do the full 5x114.3 conversion with all the axles and such to make it work from what I've heard
01-06-2013, 01:21 PM | #2640 |
Member#: 303531
BAIC
01-06-2013, 01:26 PM | #2641 |
Member#: 260501
AKIC
01-06-2013, 01:33 PM | #2642 |
Member#: 303531
BAIC
01-06-2013, 02:40 PM | #2643 | |
Member#: 284420
SWIC
01-06-2013, 03:24 PM | #2644 |
Member#: 309636
No problem man, it's all about helping the community! I figured it was safer for me to collect the update for COBB since my car is otherwise stock rather than having a Stage 2 risk it.
01-06-2013, 09:15 PM | #2645 |
Member#: 302389
TXIC
Vehicle:2011 WRX I'm a stormtrooper pewpew |
I'm also curious about solid info on this. Its something I'll be looking into in the future
01-08-2013, 12:21 AM | #2646 |
Member#: 298002
BAIC
Vehicle:2011 WRX Base Obsidian Black Pearl |
Anyone else feel like the gear ratio for 4th and 5th gear in the 2011 WRX is odd? I feel like the 4th gear pulls much harder and longer than 5th? I feel like a fool for asking this and don't know if I'm describing it correctly but maybe someone will understand what I'm talking about.
01-08-2013, 12:30 AM | #2647 |
Member#: 260501
AKIC
5th is the final gear, you shouldn't be pulling in it unless you're already going like 120.
01-08-2013, 12:32 AM | #2648 |
Member#: 98210
generally the lower gears will pull harder than higher ones...otherwise it would be hard to do things like, for example, moving
01-08-2013, 06:34 AM | #2649 | ||
Member#: 43393
Vehicle:2014 Audi a6 Daytona Gray |
I don't know if its applicable for the gr's, the legacy 6 speed is usually much cheaper than the Sti 6 speed and the gears are more usable... We all know the Sti is geared for towing boats out of the water. |
01-08-2013, 11:18 AM | #2650 |
Member#: 98210
I think newer wrx gears are already about the same as legacy gears
Similar Threads | ||||
Differences of 2011 wrx motor and 2011 sti motor | stpkenton | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 03-06-2012 11:03 AM |
Differences of 2011 wrx motor and 2011 sti motor | stpkenton | Newbies & FAQs | 3 | 05-12-2011 09:27 PM |
2011 Subaru shifter fitment! All TWM Shifters still fit! | TWM Performance | Vendor Announcements | 14 | 02-28-2011 03:27 PM |
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb | agentmaxwell | Private 'For Sale' Classifieds | 1 | 05-24-2006 07:41 PM |
Attn: Clayton, Ben and all others involved in the 6MT discussion. | sherifx | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 07-31-2002 03:00 AM |
