Welcome to the North American Subaru Impreza Owners Club Monday April 15, 2024
Old 12-03-2007, 09:12 PM   #1
freshpl
Member#: 80057
06 STI
Default how to remove airbag on 06 sti
I tried to do a search for instructions but did not find any if anyone can help me out?
freshpl is offline   Reply With Quote
Old 12-03-2007, 09:25 PM   #2
twigg107
Member#: 119718
2008 STI
baseball bat to the front bumper.....
twigg107 is offline   Reply With Quote
Old 12-04-2007, 01:11 AM   #3
Schell
Member#: 127976
2006 WRX Wagon 6 spd
Schell is offline   Reply With Quote
Old 12-04-2007, 01:11 AM   #4
Schell
Member#: 127976
1) disconnect the battery
2) use a torx wrench and unscrew the two torx screws on the sides of the wheel. They wont come out so just loosen all the way.
3) grab the airbag assemby and remove from the wheel by pushing to one side and pull towards you on the opposite side. disconnect the horn wire and airbag connector from clockspring assemby while removing airbag.
4) to remove the wires you will have to pull the sides of the yellow clip out towards you using needlenose pliers - this will pop up as one piece. at that point the plugs should pull out.
5) your done.
DUMB question: how to remove headlights on 06? Must@ng Electrical & Lighting 2 01-03-2010 11:00 AM
How to remove grill on '08 STi? sonny2 Interior & Exterior Modification 1 11-22-2008 11:15 PM
How to remove fender on 04 sti. scutzi128 Interior & Exterior Modification 4 09-16-2008 07:49 AM
How to 300 whp on 06 STI? STIvsS2K Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 06-11-2007 08:54 PM
how to remove grill on 06 asherbo Interior & Exterior Modification 3 11-12-2006 03:43 PM
