Welcome to the North American Subaru Impreza Owners Club Friday April 12, 2024
Old 04-03-2008, 05:54 PM   #1
rsmith2786
Member#: 176412
Default 04-05 STi Engine into an 05 WRX?
I have been searching and searching but still cant find all of the info i need. It have a good grip on the transmission/drivetrain options and issues. When it comes to the motor i understand it will pretty much bolt right in but what i am still not so sure on is the wiring.
I see a lot of people use the WRX wiring, intake manifold, throttle body, and ecu. There are a few things i dont like about doing that but it seems maybe its the best way.
What i was wondering is if you could use all of the STi parts including the ECU and wiring harness to essentially have a complete stock STi powertrain but in a WRX chassis. Then you could take advantage of the STi valve control system too. I am sure there is a reason people aren't doing it this way but i cant seem to find it. I bet the info is already here but i am having one hell of a time finding it.
If anyone could explain, or better yet, post up a link that would be great.
Thanks!
rsmith2786 is offline   Reply With Quote
Old 04-04-2008, 11:21 AM   #2
Prorex
Member#: 176541
2002 Impreza WRX
blue
Are you wanting to do just the motor? No trans.. etc..
Prorex is offline   Reply With Quote
Old 04-04-2008, 11:24 AM   #3
rsmith2786
Member#: 176412
I plan to do the whole powertrain but the tranny swap i have figured out.
I am basically wondering if i can use an STi ecu so that i am basically running a stock STi setup but in a wrx. Can i run the full STi harness, engine, and ecu or what needs to be done?
Is it possible to swap an 04 STi console into an 02 WRX? adrive43 Interior & Exterior Modification 21 07-17-2009 04:36 PM
Swapping an EJ257 STI engine into an RS or possibly WRX Audioexcels Subaru Conversions 0 04-27-2009 12:31 AM
HELP! 05 STi engine into an 03 WRX KillerBumbleBee Subaru Conversions 5 01-24-2007 11:10 AM
04 STi motor into an 02 wrx Smoby Service & Maintenance 1 08-28-2006 10:35 PM
04 sti engine in an 02 wrx lovemyrex Subaru Conversions 6 12-19-2005 10:40 PM
