Welcome to the North American Subaru Impreza Owners Club Monday April 15, 2024
Old 08-14-2002, 08:02 AM   #1
redoktober_99
Member#: 17430
Sedona Red Pearl
Default Not knowing much about engine design, I have this question.
Ok, I know NOTHING about engine design. However, I was wondering if it was possible to raise the redline on the WRX to 9K.
Does it require rebuilding the entire engine or just parts of it?
I have no idea, does anyone know/have an idea?
redoktober_99 is offline   Reply With Quote
Old 08-14-2002, 08:31 AM   #2
PLAYER
Member#: 19340
94 Impreza WRX
Red
Mine spins to 9K but it dont make power up there, most decent motors (rods are required) will spin there but you need a huge turbo to move enough air to get em to make grunt, my 2.4 L with the old setup made 220KW ATW @5700rpm and it fell over there, to get em making power any higher (than say 7000rpm) you have a problem with 6000rpm of lag.,
PLAYER
PLAYER is offline   Reply With Quote
Old 08-14-2002, 08:34 AM   #3
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
Raising the redline is one thing, however, the problem is making sure there is sufficient airflow at the newly found higher rpms. Usually, this requires some valve, spring, and head work to ensure that the flow is enough to make more power. It doesn't make much sense to increase the redline unless you can get more power higher up. If you can't, your just working the engine harder.
jb
jimb is offline   Reply With Quote
Old 08-14-2002, 08:43 AM   #4
PLAYER
Member#: 19340
94 Impreza WRX
Red
Airflow is directly proportional to boost, you have to remember that up there the valves are only open for a VERY short period of time.
I run cams (still mild though), 21-4n stainless single piece valves and shimless buckets to keep them alive, bearings is an issue too.
PLAYER
dont know much about engine management, but i'm looking to do some tubo'ing josh...just josh Engine Management & Tuning 3 10-13-2005 12:12 PM
Anyone know stuff about hovercraft design? 8Complex Off-Topic 27 02-26-2004 07:18 PM
Don't know much about borring an engine and need help! AWJunkies Subaru Conversions 0 08-16-2003 01:09 AM
Anyone know much about Bowie, MD? MidnightScooby Mid Atlantic Impreza Club -- MAIC 7 06-13-2002 07:07 AM
Anyone know much about the jdm AVCS? iceweazel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-02-2001 02:02 PM
