Welcome to the North American Subaru Impreza Owners Club Saturday April 20, 2024
Old 08-27-2008, 02:13 PM   #26
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by obs2008 View Post
iv been lookin for struts as all 4 of mine are blown out already, all were leaking at 9k.
how did you manage to do that? did you have them replaced under warranty until you find something better?
Old 08-27-2008, 06:53 PM   #27
obs2008
Member#: 163068
08 outback sport
ah think they blew out partially cause they are lame and partially cause i beat the crap out of it. i was going to have them replaced at subaru but. . .1) i have cobb springs on there and whole bunch other suspension mods so subaru will just laugh at me 2) i dont want people touching my car cause god knows what kinda moron subaru will have do my struts and 3) they are only going to put the same crappy struts back on so why even bother
obs2008 is offline   Reply With Quote
Old 08-27-2008, 06:59 PM   #28
nhat
Member#: 140163
03 STi
hellaflunctional
all you had to say was cobb springs
Old 08-27-2008, 07:05 PM   #29
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
cause god knows what kinda moron would blow his struts on a new car
aross is offline   Reply With Quote
Old 08-27-2008, 07:31 PM   #30
jmun671
Member#: 178919
2008 WRX 5-door
^^ am I missing something here? installing Cobb springs in a week....obviously lower so propensity to bottom is there but BLOWN ?
searching . . . . . . .
jmun671 is offline   Reply With Quote
Old 08-27-2008, 08:35 PM   #31
obs2008
Member#: 163068
08 outback sport
Originally Posted by aross View Post
uh i never said that, wtf is that all about?
Old 08-31-2008, 07:13 AM   #32
jamal
Member#: 71875
Still pretty confident front is the same between new legacy and impreza. Tops, mounting, control arms, spindle, are all identical. I've been under a few of each lately. As for the rears, they're really, really, similar. The lower mount is a bit different, but the lenght and motion ratio look very close. I'm thinking all it takes is to loosen the top nut to rotate the shaft 90* and swap out the lower bushing (or make a sleeve). The legacy uses a bigger bolt because it hangs off the side of the link where on the impreza it's held in a stamped steel u-section.
jamal is offline   Reply With Quote
Old 08-31-2008, 11:00 AM   #33
BIGSKYWRX
Member#: 7958
09 GH B+
would be nice if the front strut housings were identical- more sources for donors- also the 09 WRX w/ the firmer damping might make for a nice upgrade for the Leggy's.
I'm still a little fuzzy on the upper rear, swapping the lower shock bushing part makes sense (different size bolts)- I'm not visualizing the upper rear- is there a bearing in the upper spring perch/top? A threaded shaft at the top of the strut? Is that what the one poster drilled out?
thanks
Old 08-31-2008, 05:44 PM   #34
jamal
Member#: 71875
it's just a smaller top hat with two mounting bolts instead of three. So yeah there's a threaded shaft and top nut.
Old 08-31-2008, 06:03 PM   #35
BIGSKYWRX
Member#: 7958
09 GH B+
thanks- I found this schematic which clear things up a bit
Old 08-31-2008, 07:14 PM   #36
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
thanks
As posted above, just a two bolt top hat, the bolt pattern and center bore is different between the 05+ Legacy and 08+ Impreza.
The front strut housing is similar, however the spring perch and hub bolt pattern is not.
I tried 06 wrx strut housings, they sat too high, and lots of +ve camber
Old 08-31-2008, 08:39 PM   #37
BIGSKYWRX
Member#: 7958
09 GH B+
^ does the rear top have a bearing center section like the front (and "old" rear)? Is that what you drilled out?
thanks
Old 08-31-2008, 08:43 PM   #38
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
thanks
Its not really a bearing like the front top mount.
Imagine a smaller pre 08 Impreza top hat, smaller, two bolts only, with similar components, rubber insulator with a fixed center. The center bore was too small for the Legacy's larger bore strut, so I had to enlarge it a little.
Old 08-31-2008, 08:52 PM   #39
BIGSKYWRX
Member#: 7958
09 GH B+
OK- that's makes sense then, I was thinking it would be a little risky drilling out a bearing center
thanks
Old 12-16-2008, 07:32 PM   #40
BIGSKYWRX
Member#: 7958
09 GH B+
update on the Koni's
Koni Holland evidently has delayed the release of the 08/09 Koni damper, time frame is unknown- it could be quite some time .
Good news is Lee Grimes from Koni NA is very excited about developing a good damper for us I mailed off a front strut and rear shock for test fitting today. He's pretty confident they will be able to come up w/ suitable dampers.
Should be hear something back after the 1st of the year.
Old 12-16-2008, 08:15 PM   #41
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2018 Focus RS
2006 Evo #17 STU
Are they focusing on the WRX or STi specifically?
Old 12-16-2008, 09:15 PM   #42
BIGSKYWRX
Member#: 7958
09 GH B+
WRX- AFAIK the STi still utilizes a inverted strut up front so an insert is a lot tougher (if this isn't the case someone please post up )
Old 01-09-2009, 10:17 PM   #43
BIGSKYWRX
Member#: 7958
09 GH B+
they got to look at the rear shocks today- as expected the Koni LGT shock utilizes a different lower bushing, as expected the threaded pin is a different diameter on the Koni LGT vs oe WRX- the shock body is shorter on the Koni LGT shock by ~ 1" and the LGT shock has ~ 1.5" less of overall stroke
they're going to look at the front strut next week
Old 01-09-2009, 10:24 PM   #44
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
Figured that, it does sit lower in the rear. No major handling issues though, and it is a night and day improvement over stock.
Old 02-27-2009, 08:32 PM   #45
BIGSKYWRX
Member#: 7958
09 GH B+
update from Koni today- they successfully installed the front insert into my donor strut- fitment was very good - the only suggestion they had would be to cut a little less on the WRX strut vs the LGT one
sooooooooo here's where we sit. at the moment we have a viable option w/ the LGT insert/shock- as aross mentioned it is NOT going to be plug and play so this won't be marketed by Koni as a WRX setup for now
if you want to use this setup you will have to swap in your WRX shock bushings, you will also have to slightly drill out the rear top- the fronts are a plug/play (well except that part about cutting up your strut )
now that Koni knows they have an off the shelf front insert that works, they only need to work on the rears- they believe that it will be relatively easy to get the rears into spec- they will develop the correct lower bushing and then probably taper down the shock pin so it fits w/o drilling
that's probably going to be awhile before that gets done, sorry I don't have an estimate
there is even some chance that Holland comes up w/ a full strut front replacement, that would be down the road (if it happens at all)
so we do have an option that will work, with some work
Old 02-27-2009, 08:36 PM   #46
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
Still loving mine
Old 02-27-2009, 08:42 PM   #47
BIGSKYWRX
Member#: 7958
09 GH B+
Still loving mine
you were way ahead of the curve
Old 02-27-2009, 08:53 PM   #48
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
What is everyone doing for springs now?
Old 02-27-2009, 09:04 PM   #49
BIGSKYWRX
Member#: 7958
09 GH B+
I'm going to be running Stock class so nothing here , but if I weren't I'd be riding these:
https://www.subarugenuineparts.com/p...oducts_id=1483
modest lowering (~ 10mm) w/ spring rates of 285/228 (vs 223/196)
Old 02-17-2010, 06:16 PM   #50
09wrxracer
Member#: 238630
2009 WRX
Pearl White
Default 09 WRX Koni inserts
I'm looking for folks with 09 WRX's that have installed the Koni inserts and would like to hear what they think of the setup ride wise and installation.
09wrxracer is offline   Reply With Quote
08 wrx owners, want to be as fast as an 09? Its easy. Franko Impreza Forum 12 06-16-2009 10:29 PM
very soon to be 09 sti owner tgraci Newbies & FAQs 2 05-14-2009 11:42 AM
Does anyone make projectors for the 2005 STi's sti.2005.blk Interior & Exterior Modification 10 12-23-2007 11:18 AM
Does anyone make cams for the 2.2L cybin Normally Aspirated Powertrain 31 12-03-2003 03:46 AM
Does anyone make rims like the Advan Model 7s in gold and lightweight? Andrew Brakes, Steering & Suspension 14 11-07-2001 02:58 AM
