Welcome to the North American Subaru Impreza Owners Club Monday April 15, 2024
Old 10-25-2008, 03:50 PM   #1
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
Default oil leak after turbo install
just finished up my wonder week with an 18g install. car is dripping oil and its not the oil feed line (either end) and does not seem to be coming from the oil return line. anyone have any ideas? its dripping pretty decent and you can watch the feed/drain lines and they appear to stay dry?
eb_rat_7 is offline   Reply With Quote
Old 10-25-2008, 04:27 PM   #2
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
going to pull the turbo again. looks to be coming off the oil return line gasket (not hose)...
Old 10-25-2008, 04:28 PM   #3
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
You may have cracked the AVCS line, which is the hard line that goes from the AVCS port in front of the intake manifold to the back of the block, and then up to connect to the turbo oil feed line. It's pretty common to crack them when installing a turbo, they are sensitive.
boost junkie is offline   Reply With Quote
Old 10-25-2008, 08:30 PM   #4
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
^thanks
ugg .. that was anoying..
it was the gasket from the turbo to the oil return line. with it installed you couldnt tell where the oil was coming from except it looked like it might have come from the center section. it was running along the center section and dripping from the housing.
note to people doing a turbo install. even if the turbo is NEW and comes with the return line attached- check and ensure its tight. once we tightened it it was fine. ugg... stupid fp..
Old 10-25-2008, 09:09 PM   #5
MattPersman
Member#: 139385
if someone else reads this in the future the WRX does not have that AVCS line that cracks. that is 04-06 STi only
MattPersman is offline   Reply With Quote
Coolant leak after turbo Install 855m0n0 South East Region Forum 5 03-27-2018 07:09 AM
coolant leak after turbo install Wookie768 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-02-2007 05:06 PM
Oil leak after Header install? dubya tee ef fokai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-26-2005 03:05 PM
Oil leak after uppipe install rmac12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-16-2005 02:50 PM
Help: bad oil leak after uppipe install abaxter34 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-27-2004 03:17 AM
