Welcome to the North American Subaru Impreza Owners Club Tuesday April 16, 2024
Old 02-10-2009, 02:19 AM   #1
coolestguy20
Member#: 200246
Default introducing myself and need some answers :D
hello everyone, just want to introduce myself; im a new subaru wrx driver and just curious about something.
ive been told from my friend that usually when you tune a subaru, you go by stages. i just want to know what what does that mean. well from what ive been told so far, i know that by adding more performance part, you go up the stage. but how do i know which stage im at, and where to begin or end.
--also im really interested about getting a open wastegate. dont know where to start of getting that, bc i want to be a txs stealthback, will that fit with the whole open wastegate project that im doing.
ps. its a wrb wrx wingless. with a cool CARBON FIBER EXHAUST SHIELD. lol doesnt really do anything but looks cool to me. thanks guys,
duke
coolestguy20 is offline   Reply With Quote
Old 02-10-2009, 03:03 AM   #2
howweirdo
Member#: 186257
2015 WRX Premium
CBS
its always a good idea to fill out your profile so that people know what they're dealing with. as far as stages go, this is more of a marketing scheme for aftermarket performance stores. but for starters, stage I is an ecu tune on a stock car and stage II is basically a turboback exhaust with a tune. a good way to get started in your research is here
http://forums.nasioc.com/forums/showthread.php?t=533787
good luck.
howweirdo is offline   Reply With Quote
Old 02-10-2009, 10:58 AM   #3
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
All you need is a special up-pipe for an EWG setup... oh, and a tune afterwards.
T Wrex--OH is offline   Reply With Quote
Old 02-10-2009, 11:27 AM   #4
noobsauce
Member#: 197563
08 Impreza
duke
Before you do anything to the car read the forums. I'm a subaru noob as well and the one thing I've learned is imprezas are sensitive to mods. If you install some random mod, the fuel/air ratio can change, then you car start to run lean, and your engine eventually gives out.
noobsauce is offline   Reply With Quote
Old 02-10-2009, 11:40 AM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It's not random, it's actually very straight forward. It's just that a lot of people here that claim to know what they're talking about actually have no idea and tell noobs they will blow their motor if they breathe on it the wrong way.
The only mods that will change your air/fuel ratio are those that affect the air or fuel. Changing to a larger MAF housing without telling the ECU means you will have more air coming in than it thinks and you will run lean. Switching to larger injectors or crushing your fuel pressure regulator without telling the ECU means you will have more fuel coming in than it thinks and you will run rich. That's as complicated as it gets...
These cars are no more sensitive to mods than any other turbo car, but turbo cars in general are a bit more sensitive than NA cars.
Old 02-10-2009, 12:12 PM   #6
ekw
Member#: 92141
2014 GT-NC-PRHT
Zeal Red.
on the "stages" front, you need to read this:
What is a Stage 2 or Stage whatever package?
welcome to nasioc.
ekw is offline   Reply With Quote
Old 02-10-2009, 12:57 PM   #7
noobsauce
Member#: 197563
08 Impreza
When I spoke of sensitivity to mods I was thinking of naturally aspirated (NA) cars compared to turbocharged ones. I should have clarified that.
Old 02-10-2009, 01:06 PM   #8
noobsauce
Member#: 197563
08 Impreza
I'll have to say one of the most affordable mods that comes to mind is replacing the stock air-box with intake. Before you think about even doing that read this intake FAQ...
http://forums.nasioc.com/forums/showthread.php?t=477393
After reading this, I decided to keep my stock air box, but changed the oem air filter for the HKS hybrid drop-in filter instead. I've noticed a better throttle response and my MPGs have gone up a few points
Old 02-10-2009, 06:31 PM   #9
coolestguy20
Member#: 200246
thanks everyone, im learning alot. i know what i should do first, is engine management, but that comes with another question...which one are for me...and how many are out there
Old 02-10-2009, 06:49 PM   #10
RingU
Member#: 137243
2004 2.5L WRX JPB
1999 Civic EX White
Check out the Cobb Accessports.
RingU is offline   Reply With Quote
Old 02-10-2009, 07:01 PM   #11
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Which are in some cases nothing more than expensive, fancy paper weights.
My suggestion to the OP, don't make any decisions on anything yet. Start with the Stickies at the top of the forum, specifically the Unabomber's Manifesto, wherein is contained an Engine Management FAQ that will give you a GREAT starting point. It will also help get you in the habit of searching before asking questions, as just about anything you can think of has been asked before, and answered in great detail. Why wait a day for random answers when FAR more results can be found in a few minutes?
You should also look around your regional forums and see what tuners are local to you and what software they use. If you can get professional custom tunes, an AccessPort can be one of the biggest wastes of money out there, and a blanket statement as a suggestion to buy one is not very good advice.
Good luck and enjoy!
Audiosavvy is offline   Reply With Quote
Old 02-10-2009, 07:46 PM   #12
Oedipus_WRX
Member#: 201327
08 Impreza WRX
duke
You dont need to go by stages. It just makes things easier to tune for and market (and brag). Welcome from another new member!
Oedipus_WRX is offline   Reply With Quote
Introducing myself....and BOV question... afrothang Newbies & FAQs 11 09-09-2008 01:29 AM
Introducing myself and maybe big project- Soob camper dajabr Newbies & FAQs 26 09-09-2005 12:19 PM
Whats up? thought I would intro myself. And need some info. spinwax Southern California Impreza Club Forum -- SCIC 23 05-16-2002 05:29 PM
Hello all! Just wanted to introduce myself and my '93 legacy. Kichigai South East Region Forum 9 10-02-2001 10:03 PM
please help me out, car hurt and need some q's answered on aftermarket parts 98mpreziveRS Technical Forum Archive 4 08-03-2000 05:50 PM
