Welcome to the North American Subaru Impreza Owners Club Tuesday April 16, 2024
Old 05-29-2004, 02:48 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Will coil packs off the v7 sti work on a 2002 WRX?
The part number for the STI is FK0186 and the part number from the WRX is FK0140.
LiquidForce is offline   Reply With Quote
Old 05-29-2004, 02:54 PM   #2
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
yes, pm mr2guru... he had spec C coil packs for a bit.
-Mike
MJU1983 is offline   Reply With Quote
Old 05-29-2004, 03:05 PM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
thanks
I'll send him a pm.
I noticed you said he used them for a "bit". Do you know if he had any issues?
I am running a reflashed ecu if this makes any difference.
Old 05-29-2004, 03:11 PM   #4
MJU1983
Member#: 14364
He liked them better than stock. He is currently parting out his set up tho, that's why I said used for a bit.
He has had 3 different motor setups and countless turbos. Just likes to change it up a bit.
-Mike
Is it possible ton run a V7 jdm sti ecu on a 2002 wrx engine? julien Engine Management & Tuning 5 05-09-2007 06:34 PM
Is it possible ton run a V7 jdm sti ecu on a 2002 wrx engine? julien Subaru Conversions 7 05-04-2007 11:43 PM
Will the 2005 AP work on a 2002 WRX? thejean AccessPort 2 03-31-2006 07:18 PM
Will this uppipe work on my 2002 WRX? TRUDAWG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2005 12:00 PM
Will the v7 motor work with an 02 WRX ECU? TrizzyDizzy Engine Management & Tuning 4 10-20-2004 02:01 PM
