Welcome to the North American Subaru Impreza Owners Club Monday April 15, 2024
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 10-25-2004, 12:18 PM   #1
855m0n0
Member#: 33571
1993 LS1 FD3S RX7
Red
Default Coolant leak after turbo Install
I installed the VF-22 on the WRX over the weekend. Everything seemed to be OK. When i started the car it seemed to run. I let it idle for a while and watched for leaks. Didnt see any. Double checked that coolant was full in the resivoir over the injectors. Things looked good there. Took car for drive. At no boost (well under 5 psi) and under 3500 rpm with limited throttle everthing seemed OK. Decided to go to 1/2 throttle and 10 psi. Seemed OK, then got to stop sign in neghborhood. Steam coming from engine. Go back to house and open hood. There seemed to be a plethoria of steam coming from up pipe area. I could see coolant stains on up pipe. Took out flash light and started searching for leak. No luck. Re-filled coolant in resivoir. Made sure clamps were really tight on coolant hoses on turbo (top and bottom) and started car. No leak. Reved engine and held at 3500 RPM in neutral. No leak. Took car boosted to 10psi again. More steam!!!
Is there some other coolant line I am missing (not looking at that could be disconnected? When the turbo boosts does either one of the lines get pressurised? There are only 2 on the turbo that I can find.
I purchased some more coolant line today and when I get home I am going to replace the lower turbo coolant line just in case there is something lame going on. Anyone have any other ideas??
Thanks!
855m0n0 is offline   Reply With Quote
Old 10-25-2004, 12:30 PM   #2
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
If your VF-22 came with it's own coolant lines then you'll need to change the upper hose to the radiator fill tank. This hose will be too short. Also, remove the stock clamp on the lower hose(pass. side) and put a screw clamp on it. This should fix your problem right up.
Paco
Pacobeagle is offline   Reply With Quote
Old 10-26-2004, 09:28 AM   #3
855m0n0
Member#: 33571
1993 LS1 FD3S RX7
Red
After getting a new hose and attaching 2 pipe clamps to the end of it on the lower turbo it finally stopped leaking. I think I will have the shop look at it when I take it in to be tuned. Anyway. Thanks!
Old 03-26-2018, 10:35 PM   #4
02_B_Bug415
Member#: 471124
Unhappy Me too! Please help.
So basically the verdict in your cases was to use wo gear clas not the old lady
Ps bec they canít handle the new pressure? I installed a Tomei I turbo
And it leaks coolant on the uppipe but I CANNOT find it.
02_B_Bug415 is offline   Reply With Quote
Old 03-27-2018, 07:06 AM   #5
Andrew2166
Member#: 479808
02 Impreza wrx 2.0
Grey
Had the same problem...its the coolant feed hose, the lower rubber hose you connect to the coolant line...guarantee you didn't replace the clamp...took me 2 months to find it, and was about to rip my turbo out...but i can almost guarantee you its the coolant line connecrung the the lower turbo hardcoolant line...its leaking from there, running down the hardline to the lowest point,then dripping on your up pipe, and oil drain tube.
Andrew2166 is offline   Reply With Quote
Old 03-27-2018, 07:09 AM   #6
Andrew2166
Member#: 479808
02 Impreza wrx 2.0
Grey
Thanks!
Look at ny bottom post, but more then half the time you need to have your car underload to spot a leak, because at that point pressure is being asserted on the lines. If u reused old hoses, chances are theyre no good. Or you tightened the clamp to hard and ripped the hose that way
Coolant leak after motor mount install. stikboy9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-03-2009 05:29 PM
oil leak after turbo install eb_rat_7 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2008 09:09 PM
coolant leak after turbo install preacher#1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-12-2007 01:36 AM
coolant leak after turbo install Wookie768 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-02-2007 05:06 PM
Coolant Leak After Uppipe Install... timman_24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2004 03:56 PM
