Welcome to the North American Subaru Impreza Owners Club Friday April 12, 2024
Old 12-03-2005, 07:17 AM   #1
lovemyrex
Member#: 98321
2002 wrx
midnight black pearl
Default 04 sti engine in an 02 wrx
How hard is it to install an 04 sti engine in an 02 wrx, what is involved, can I keep my 5 speed trans, can u keep the stock ecu, Or do have to swap them out to how difficult would that be, The reason im asking shese questons are because I can get this 04 sti engine for 3k and I was thinking about doing the swap, Or would it just be easy to just swap the sti shortblock out, And yes I have searched but I just can't find the answer's im looking for, Please no smart ass remarks as im still new to this!
lovemyrex is offline   Reply With Quote
Old 12-03-2005, 01:03 PM   #2
Ghost Rider
Member#: 70346
2017 Golf R
Deep Black Pearl
the big problem is the drive by wire throttle. You need to get the pedal assembly and so forth, which i think means your are going to need the STi ecu too, but i could be wrong on that last part. i think swapping the heads off the shortblock might technically be more work. the ej257 should just drop right in and bolt up to your 5 speed. at least i hope, because i am planning the same thing for february
Ghost Rider is offline   Reply With Quote
Old 12-04-2005, 04:21 PM   #3
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
just get an sti block and all your problems are solved
turbocolin is offline   Reply With Quote
Old 12-04-2005, 04:22 PM   #4
cronic
Member#: 9749
Just change the intake manifold, for your wrx one with cable throttle. Drill and tap for cam sensor, and be done with it.
cronic is offline   Reply With Quote
Old 12-05-2005, 07:14 AM   #5
lovemyrex
Member#: 98321
2002 wrx
If I were to just do a sti short block can i use my stock 02 ecu
Old 12-05-2005, 05:12 PM   #6
pux888
Member#: 8356
02 STi swap
12 WRX limited
Cronic is right on....Im running the exact same swap your considering. you can use your 02 ecu w/ a utec. Ive actually got an extra w/ maps ready to go.
pux888 is offline   Reply With Quote
Old 12-19-2005, 10:40 PM   #7
turbocolin
Member#: 43539
95L 97L 03hedgehog
also the drive by wire gas pedal does not bolt up i had to weld it in with a bracket
Will an 04 STi spolier fit an 02 wrx stonecutter29 Interior & Exterior Modification 7 04-14-2012 09:34 PM
Can UTEC run an 06 sti engine in my 02 wrx w/ AVCS? breathinez UTEC 2 02-13-2010 10:15 AM
Is it possible to swap an 04 STi console into an 02 WRX? adrive43 Interior & Exterior Modification 21 07-17-2009 04:36 PM
??04 sti cluster in an 02 wrx??? SIBzzz Interior & Exterior Modification 6 02-02-2008 05:41 AM
04 sti cluster in an 02 wrx realove Interior & Exterior Modification 4 06-22-2004 11:34 PM
