Welcome to the North American Subaru Impreza Owners Club Thursday November 26, 2020
Old 11-19-2020, 12:58 AM   #1
Sekelsky
Member#: 518903
Default New to subi little help please
So I bought a subi. 02 wrx wagon that was put together not very well..after my third piston blew the top of the block I decided to put a little money in it..no engine work just bolt ons if I like ill do head and block work anyway....so hear it what I bought what else would help and also whats up with this pvc reroute and a vacuum diagram most aimt clear about what goes where and what to tee and cap off....but silicone turbo inlet tgv deletes 1050cc injectors 8an fuel rails parrellel set up new to me jdm 205 I swapped cam crank and coolant hoses all new cam crank knock sensors new timing and water pump.. 20g ebay turbo (for now) headers uppipe 4inch widemouth catless downpipe full exhaust killer b oil pan and pickup and matching baffle fuel pressure regulator front mount intercooler 3 port ebc....any recommendations for a bov and other stuff...wastegate tips.....oh and as far as tuning goes what is my better option cobb or open-source
Sekelsky is offline   Reply With Quote
Old 11-19-2020, 08:16 AM   #2
Zak6182
Member#: 481754
2017 STi Base
Welcome to NASIOC.
Just a little advice from what I've seen on here. If you clean up you post so that its easier to read you will probably get more help. I struggled to understand what you are asking.
Zak6182 is offline   Reply With Quote
Old 11-21-2020, 10:19 PM   #3
Thunderpaw
Member#: 242205
2009 I don't know
Dirt
Go to a reputable tuner and have them tune it. Dont do an off the shelf access port tune as it wouldnt work with your mods
Thunderpaw is online now   Reply With Quote
Old 11-21-2020, 11:35 PM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
I can't follow what you're asking. Use sentences and punctuation so we can follow your thoughts. The questions I think you're asking should be taken to your tuner. That's where you will get the best advice and knowledge.
snow_bound26 is online now   Reply With Quote
Old 11-23-2020, 10:49 AM   #5
knesek
Member#: 508145
2007 WRX Wagon
Satin White Pearl
I'm in the same boat as the others. This is a separate thing but just make sure to check under the carpet on the rear strut towers as the wagons can rust there pretty bad.
knesek is offline   Reply With Quote
