Welcome to the North American Subaru Impreza Owners Club Wednesday December 2, 2020
Old 11-21-2020, 11:18 PM   #1
subarufanjdm
Member#: 520438
Default do these look normal?
KNOCK DETECTED at 2020-11-21 11:55:38 AM
AFR: 14.7
Boost (psi): 3.80
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 7
Injector PW (ms): 8.4
Load (g/rev): 1.37
MAF (g/s): 105.19
RPM: 4598
Speed (kmh): 57.0
Throttle plate (%): 88.6
Timing (deg): 35.5
KNOCK DETECTED at 2020-11-21 11:51:08 AM
AFR: 11.8
Boost (psi): 10.50
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 7
Injector PW (ms): 12.0
Load (g/rev): 1.87
MAF (g/s): 164.90
RPM: 5281
Speed (kmh): 34.0
Throttle plate (%): 80.0
Timing (deg): 30.0
KNOCK DETECTED at 2020-11-21 11:29:27 AM
AFR: 11.5
Boost (psi): 12.60
FKC (deg): -2.11
FLKC (deg): -1.76
IAM: 7
Injector PW (ms): 14.3
Load (g/rev): 2.10
MAF (g/s): 170.70
RPM: 4876
Speed (kmh): 50.0
Throttle plate (%): 65.9
Timing (deg): 22.5
KNOCK DETECTED at 2020-11-21 11:15:25 AM
AFR: 12.9
Boost (psi): 3.40
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 6
Injector PW (ms): 7.9
Load (g/rev): 1.33
MAF (g/s): 54.65
RPM: 2463
Speed (kmh): 87.0
Throttle plate (%): 100.0
Timing (deg): 24.5
KNOCK DETECTED at 2020-11-21 11:14:07 AM
AFR: 11.3
Boost (psi): 15.90
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 8
Injector PW (ms): 15.4
Load (g/rev): 2.22
MAF (g/s): 214.53
RPM: 5791
Speed (kmh): 125.0
Timing (deg): 26.5
KNOCK DETECTED at 2020-11-21 11:14:03 AM
AFR: 11.3
Boost (psi): 15.30
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 8
Injector PW (ms): 15.1
Load (g/rev): 2.21
MAF (g/s): 217.71
RPM: 5910
Speed (kmh): 91.0
Throttle plate (%): 96.5
Timing (deg): 27.0
subarufanjdm is offline   Reply With Quote
Old 11-23-2020, 10:52 AM   #2
knesek
Member#: 508145
2007 WRX Wagon
Satin White Pearl
I'm pretty new to things like that but to me at least the knock is fine. There's going to be knock, if it reads none then your sensor would be broken. What's your DAM?
knesek is offline   Reply With Quote
Old 11-24-2020, 10:13 PM   #3
subarufanjdm
Member#: 520438
here is a log of pull
it didn't knock but lemme know if the values are loooking ok
https://i.imgur.com/DbcNwEo.jpeg
Old 11-25-2020, 12:55 AM   #4
Bluestreak03
Member#: 125887
2001 EJ207 RSTi, Blo
Mica Blue
AFR: 14.7
Boost (psi): 3.80
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 7
Load (g/rev): 1.37
MAF (g/s): 105.19
RPM: 4598
Speed (kmh): 57.0
Timing (deg): 35.5
AFR: 11.8
Boost (psi): 10.50
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 7
Load (g/rev): 1.87
MAF (g/s): 164.90
RPM: 5281
Speed (kmh): 34.0
Timing (deg): 30.0
AFR: 11.5
Boost (psi): 12.60
FKC (deg): -2.11
FLKC (deg): -1.76
IAM: 7
Load (g/rev): 2.10
MAF (g/s): 170.70
RPM: 4876
Speed (kmh): 50.0
Timing (deg): 22.5
AFR: 12.9
Boost (psi): 3.40
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 6
Load (g/rev): 1.33
MAF (g/s): 54.65
RPM: 2463
Speed (kmh): 87.0
Timing (deg): 24.5
AFR: 11.3
Boost (psi): 15.90
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 8
Load (g/rev): 2.22
MAF (g/s): 214.53
RPM: 5791
Speed (kmh): 125.0
Timing (deg): 26.5
AFR: 11.3
Boost (psi): 15.30
FKC (deg): -2.11
FLKC (deg): 0.00
IAM: 8
Load (g/rev): 2.21
MAF (g/s): 217.71
RPM: 5910
Speed (kmh): 91.0
Timing (deg): 27.0
holy info overload... Yep pulling timing in certain load cells
Bluestreak03 is offline   Reply With Quote
Old 11-29-2020, 09:08 PM   #5
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Fill in your profile brother
AliBenn is offline   Reply With Quote
