Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 12-09-2019, 02:00 AM   #1
lochenjons
Member#: 455781
Default Which tire size on '18 STI with 18x9.5 wheel?
I've searched. Not really found the answers I'm looking for. Stock tire/wheel size is 19x8.5 with 245/35/r19 on my 2018 STI
Wanting to get Titan 7 T-S5's which are 18x9.5 +40
What would be a better tire? 255/40/18 or a 255/35/18? Does anyone have experience running this on a 2015+ STI with stock suspension?
I like this guy's setup below he's running a 255/40/18 on the wheel I want but I'm not sure if he's rubbing anywhere at all.
Here's a link to his thread: https://forums.nasioc.com/forums/sho....php?t=2889020
lochenjons is offline   Reply With Quote
Old 12-10-2019, 10:49 AM   #2
Thugmufin
Member#: 477190
2018 WRX STI
Lapis Blue Pearl
Might be easier to read through his thread or ask him since he is running the exact setup you want and is lowered.... just a through...
Thugmufin is offline   Reply With Quote
Old 12-10-2019, 03:12 PM   #3
Mach V Dan
Member#: 12029
255/35R18 is 3.1% shorter than stock. A 265/35R18 is a better choice, and fits. It's a very popular size. A 275/35R18 is the closest to the stock diameter, but that's fairly wide and not many people run that size.
Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 12-11-2019, 01:15 PM   #4
lochenjons
Member#: 455781
I tried reaching out to him a while ago but no response. I did think of that ha ha.
Old 12-11-2019, 01:16 PM   #5
lochenjons
Member#: 455781
Originally Posted by Mach V Dan View Post
255/35R18 is 3.1% shorter than stock. A 265/35R18 is a better choice, and fits. It's a very popular size. A 275/35R18 is the closest to the stock diameter, but that's fairly wide not many people run that size.
Dan
Mach V
FastWRX.com
Exactly the info I was looking for, thanks
Old 12-21-2019, 11:33 PM   #6
Corellian_STI
Member#: 509567
2019 STI
ISM
I run a 255/35 on 18x9.5 TS10’s and wish I had done the 265 or bigger. Chipped the lips up quick
Corellian_STI is offline   Reply With Quote
Old 12-23-2019, 08:44 PM   #7
lochenjons
Member#: 455781
Good info ! any pics of your setup ?
Old 12-26-2019, 01:03 PM   #8
2000Subaru2.5RS003
Member#: 508899
Car looks awesome!
2000Subaru2.5RS003 is offline   Reply With Quote
Old 01-08-2020, 01:46 AM   #9
STIposer
Member#: 509888
2017 WRX STI
Lapis Blue
Dan
Mach V
FastWRX.com
Dan,
Is running a 275/35r18 too wide? What rim width and offset have you seen work with this tire size? I'm trying to research optimal wheel width, offset and tire sizes that will not disrupt handling with OEM shocks and lowering springs.
STIposer is offline   Reply With Quote
Old 01-09-2020, 10:09 AM   #10
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
I have run 275/35 re71's on 18x10 +38 rpf1 with oem suspension, no rubbing. And also on coil overs, pretty low with -2.5 camber up front and -2 in the rear, slight rubbing on rear before fender rolling. It is a pretty aggressive tire size but it matches the oe diameter
milab21 is offline   Reply With Quote
Old 08-18-2020, 10:46 PM   #11
zensti
Member#: 169179
Originally Posted by milab21 View Post
I have run 275/35 re71’s on 18x10 +38 rpf1 with oem suspension, no rubbing. And also on coil overs, pretty low with -2.5 camber up front and -2 in the rear, slight rubbing on rear before fender rolling. It is a pretty aggressive tire size but it matches the oe diameter
Just curious, my 2020 also on Ohlin coils, how to set -2 in the rear? did you change the rear lower control arms to adjust cambers?
zensti is offline   Reply With Quote
Old 08-24-2020, 06:28 PM   #12
Mdoonan
Member#: 515079
What did you do about the rear bumper clip? I’m lowered .75” on 265 tires, rolled fenders, but rubbing like crazy on the clip... I trimmed it a bit, but nervous to take out too much
Mdoonan is offline   Reply With Quote
Old 08-29-2020, 11:19 AM   #13
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
SPL lower control arms in the rear for camber adjustments.
Also I never rolled my rears or shaved any bumper tabs, it rubbed and I only drove it a short time, decided to run less aggressive wheels
Old 09-04-2020, 11:55 AM   #14
bobca222
Member#: 499478
I run Michelin Sport 4S @ 265/35ZR18
bobca222 is offline   Reply With Quote
